DIY tyre change, simple or not?
bridgedino
PostPosted: 13:17 - 28 May 2013    Post subject: DIY tyre change, simple or not? Reply with quote
Will shortly be looking at replacing my rear tyre on my CRF250L. It's a knobbly dual sport tyre on a spoked wheel with inner tube, very much like a large bicycle tyre
So my question is...is it basically like changing a bicycle tyre? Wheel off, couple of tyre levers, tube out, tyre off the fit new, ride off Very Happy
Anyone have any experience?
mudcow007
PostPosted: 13:23 - 28 May 2013    Post subject: Reply with quote
i did my CG tyres my self
i dunno if you have inner tubes, i did an got a pinch puncture. i repaired that aswell
yeah its basically the same as a bicycle tyre
i didn't have any soap for the tyres so squirted everything with wd40 to make the tyres slip on/ off the rims easier, just remember to wash it with washing up liquid afterwards
P.
PostPosted: 13:28 - 28 May 2013    Post subject: Reply with quote
Yeah, be nice and easy on that Thumbs Up
Quote Me Happy
PostPosted: 13:31 - 28 May 2013    Post subject: Reply with quote
Get some decent levers like these Buzzettis
https://www.xrv.org.uk/forums/attachments/wheels-tyres-tubes/13602d1308778078-recommend-me-some-tyre-levers-9074e-4969.jpg.jpg
They have a lip on them to stop you pinching the tube.
If you're having to use a lot of force stop and think and try a smarter way.
Fizzer Thou
PostPosted: 14:00 - 28 May 2013    Post subject: Reply with quote
Tyres on such a bike as the 250L are easy.Just take your time.But using WD40 is not a good idea as it contains chemicals which think affect the rubber.If you get it all over the inside of the rims,when it evaporates it leaves a sticky substance.this could cause the tyre to creep on the rim and pull the valve stem out of the inner tube at any time.Believe me,I have had it happen to me after a shop did not fit a new inner tube correctly.
Tubeless tyres are just as easy except breaking the bead over the safety bump
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/2013-05-05184720_zpsd28e1d3d.jpg
This was the Sunday just before the Mayday Run the next day so I had to bash on with it myself Smile
Always have a 'Plan B'
Islander
PostPosted: 14:51 - 28 May 2013    Post subject: Reply with quote
It's all about technique but it's pretty easy to do. As already said, If you find yourself struggling then change technique. Don't use WD40 on the bead though, use dilute washing up liquid.
BTTD
PostPosted: 15:17 - 28 May 2013    Post subject: Reply with quote
Lots of youtube videos - watch several so you've got different techniques to try out.
Did my first tyre change a few months ago and it was pretty straight forward, will be easier next time.
I used buzzeti levers as mentioned above and soapy water.
Bear in mind that warm rubber is more pliable, something that occurred to me while I was mounting my new tyres in the freezing garage - I could've kept the new tyres in the warm house until they were ready to go on.
PostPosted: 15:26 - 28 May 2013    Post subject: Reply with quote
Or just use the washing up liquid in the first place.
Ariel Badger
PostPosted: 15:54 - 28 May 2013    Post subject: Reply with quote
Changing road tyres is easy, changing MX tyres is not as they are so stiff and it is worse if you use rim-locks. When I have done it in the past I have found that blood makes a decent lube.
PostPosted: 16:31 - 28 May 2013    Post subject: Reply with quote
I have a neat little thingy that goes through the valve hole and screws into the valve with the core removed to pull it through the hole once you have the first bead fitted.
Saves LOTS of swearing and skinned knuckles.
https://www.adventure-spec.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/n/e/neri-01-july-12-1-33.jpg
Liberally applied ordinary household soap is best for lubing the bead. Washing up liquid can go too far and leaves a possability of the tyre rotating on the rim during use (something which rips the valve out and causes an instant deflation).
Remember to check the bead is fully seated. I had to bang the rear on the enfield up to 90psi three times with the valve core out to get it fully seated last time. Tubeless tyres usually have a line marked near the bead which should be the same distance from the rim all the way round.
yen_powell
PostPosted: 16:48 - 28 May 2013    Post subject: Reply with quote
I always put the tube (slightly inflated) into the tyre before the wheel goes near it, then pull the valve through the hole in the wheel and put the lock nut on a few turns before starting to fit it.
XT1200Z and a DR350 in bits
Islander
PostPosted: 17:10 - 28 May 2013    Post subject: Reply with quote
Where the fuck was that when I had a bike with tubed tyres! Laughing
evoboy
PostPosted: 19:09 - 28 May 2013    Post subject: Reply with quote
Race tyres for road bikes are by far the easiest to fit. Dont even need levers! Laughing
Mx tyres can be a right swine to do.
APT Motorcycles
neatbik
PostPosted: 19:17 - 28 May 2013    Post subject: Reply with quote
My favourites are supercorsa's and Racetecs, still warm from the ride over to me - They practically fall off the rim.
MX tyres with rimlocks are the devils spawn.
But i'm getting pretty good at them now, after lots of skinned knuckles.
bridgedino
PostPosted: 19:34 - 28 May 2013    Post subject: Reply with quote
Thanks for all the info
cb1rocket
PostPosted: 21:34 - 28 May 2013    Post subject: Reply with quote
I too have used WD-40, yes I know I shouldn't but then I don't like washing up liquid as it contains salt that eats through the chrome and rim!
What house hold soap would you use? Is there any specific ones to go for?
Supermotard37...
PostPosted: 01:31 - 29 May 2013    Post subject: Reply with quote
I used this guys tactics many times to change tyres on my supermoto Razz hope this helps!
https://www.youtube.com/watch?v=UPaCV_uCi78
Fuck off..!! "You absolute contraception malfunction"
PostPosted: 08:12 - 29 May 2013    Post subject: Reply with quote
Any. I use ordinary green household soap.
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 99.33 Kb
