o ring chain lube
stranger12
PostPosted: 13:30 - 28 May 2013    Post subject: o ring chain lube Reply with quote
hellooo,
can i ask what lubricants do you normally use as chain lube ? i bought the following which think it is also good for o ring chain
https://www.ebay.co.uk/itm/Silkolene-Motorcycle-Motorbike-Semi-Synthetic-Chain-Lube-Oil-Aerosol-500ml-/300817802018?pt=UK_Motorcycle_Parts&hash=item460a236322
any specific brand which you think it is better or are they all the same
thanks
SV650 Red
R6 Red
Copycat73
PostPosted: 14:30 - 28 May 2013    Post subject: Reply with quote
on the middle of chain & "0" rings
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_217764_langId_-1_categoryId_165705
on the outside plates
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219101_langId_-1_categoryId_165705
caveat emptor
Islander
PostPosted: 14:43 - 28 May 2013    Post subject: Reply with quote
EP90 gear oil is cheap as chips, heavy enough not to fling and does the job well. Apply with an old paintbrush after a run to warm the chain up, leave to soak in for a few minutes, wipe the excess off with a rag.
Diesel or paraffin to clean. Thumbs Up
fozzym
PostPosted: 14:44 - 28 May 2013    Post subject: Reply with quote
Pretty much anyrthing that lubricates the chain whilst sticking to it will do the job. The trick is to keep and eye on it and keep it cleaned and lubed.
You can use cheaper stuff perhaps more often or a better quality and a bit less often. Its a waste of time buying an expensive lube and only using it once a year!
J.M.
PostPosted: 15:10 - 28 May 2013    Post subject: Reply with quote
Chainsaw chain oil from B&Q. Works fine for me!
2004 R1 & 2018 XSR900
Mark65
PostPosted: 19:00 - 28 May 2013    Post subject: Reply with quote
As above about £5 a litre I pay lasts ages, on with a brush.
stranger12
PostPosted: 20:24 - 28 May 2013    Post subject: Reply with quote
i think the oil approach is very cheap and maybe more effective
no need to worry about the o ring type etc
so i guess i just get a bottle of oil from tesco or asda ( their own brand ) from 2 3 pound and that is better than the spray
btw, when do you guys apply it ? is it ok to do it when the chain is cold or just before you are about to set off? or does it have to stay on it overnight ?
with the oil method i guess you just stick the toothbrash in the oil and rub it on the chain
SV650 Red
R6 Red
Islander
PostPosted: 20:42 - 28 May 2013    Post subject: Reply with quote
Ahem...
Ed Case
PostPosted: 20:59 - 28 May 2013    Post subject: Reply with quote
Used engine oil works nicely and it's effectively FREE just don't drown the chain with it, if necessary wipe off any excess with a piece od rag. Any oil is better than no oil !.
Turkish
PostPosted: 21:31 - 28 May 2013    Post subject: Reply with quote
Get a wash bottle like this
https://scienceessentials.com.au/images/uploads/products/144087_-_Wash_Bottle_Isopropanol.jpg
Fill with oil.
Warm the chain and lube the sideplate overlaps and edges of the rollers. The easiest way to do this is position the nozzle, squeeze bottle and rotate the back wheel.
It take less than a minute. Do it as often as you can stand, at least every 200 miles, but 100 would probably be best.
ZX-6R G2
CBR125R RW6
The last post was made 12 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 69.45 Kb
