| Sload |
 Sload World Chat Champion
 Posted: 18:05 - 28 May 2013 Post subject: Pitted stanchion |
Just an opinion from those who have dealt with this. Fed up of messing with oil seals and poor braking due to oil leakage.
Purchased some unpitted top condition used replacement forks for the bike, and they are pitted. Needless to say I cannot return them now.
https://i148.photobucket.com/albums/s12/TrIcK361/Speed%20Four/468943_10151356787476706_1521310096_o.jpg
That is one of the stanchions I have attacked with wet and dry 1200. Im thinking time wise to sack it off and get it either re-plated or just change the tubes. Re-plating is about £140ish from philpots but I could get replacement tubes for £200 from wemoto.
Has anyone had any good luck with the re-plating, I'm talking a good few years worth or should I just throw some more money at and get the new stanchions and gator the bugger up? ____________________ Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx |
| Poseidon |
 Poseidon World Chat Champion
 Posted: 18:13 - 28 May 2013 Post subject: |
I used araldite and the "Stinkwheel" patented method for sorting out pitted stanchions. I took the bike off the road 12 months after doing it and the seals were still tip top! (even made it through an MOT without so much as an advisory!)
| stinkwheel wrote: |
You can do a bodge repair on pitted forks that is very effective although not all that aesthetic.
Firstly, clean all the rust off, down to bare metal, make sure you get rid of any flakes of chrome and scrape the rust out of the pits with a stanley knife blade.
Degrease the stanchions thoroughly using a solvent, you must completley remove all traces of oil clinging to them.
Now get some Araldite epoxy resin, it is improtant to use the original slow setting stuff (now marketed as precision?), NOT araldite rapide which absorbs water and swells over time.
Mix it up and skim over all the damaged parts of the fork stanchions, try to use as little as will fill the defects whilst still having it standing a little proud of the surface.
Leave to set for AT LEAST 24 hours.
Now using progressivley finer grades of wet and dry paper, polish down the araldite 'till it is perfectly smooth and level with the rest of the chrome surface, finish off with a cream polishing agent like autosol then a wax polish.
This works, I have done it many times. The critical parts are 1) How clean and grease free you get the surfaces. 2) The amount of elbow grease expended polishing.
From here
Obviously not a permanent fix, but will buy you quite some time whilst you figure out which way you want to go.
If you are dead set on replacing them, I would spring the extra quids and get new. Seems daft to spend so much getting old (and possibly bent etc) stanchions redone when new are not that much more. ____________________ 1977 Honda CG125
2002 Ducati Monster S4 (currently restoring) |
| STONEY! |
 STONEY! Brolly Dolly
| Sload |
| STONEY! |
| mentalboy |
 mentalboy World Chat Champion
| ian505050 |
 ian505050 Traffic Copper
| sickpup |
 sickpup Old Timer
| jjdugen |
 jjdugen World Chat Champion
| Sload |
| sickpup |
 sickpup Old Timer
| Sload |
| sickpup |
 sickpup Old Timer
| moppy |
 moppy World Chat Champion
| cb1rocket |
 cb1rocket World Chat Champion
| Sload |
| mentalboy |
| Sload |
| Sload |
 Posted: 20:54 - 17 Jun 2013 Post subject: |
Well rebuilt with new seals, bushes, washers, replacement sliders with free adjusters. Picked the best two of the four stancions I have and did what I could. Levelled, and then air gapped correctly, compression and rebound set to stock. Just had a good 100 mile run and it doesn't feel like it's trying to kill me finally. Hopefully that's something else knocked off the list for now.
Although I tracked down the knocking at the front, my floating disks have a lot of play in the bobbins, FML  ____________________ Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx |
The last post was made 12 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
