| Random13 |
 Random13 Scooby Slapper
| Commuter_Tim |
 Posted: 21:46 - 28 May 2013 Post subject: |
https://www.bikechatforums.com/viewtopic.php?t=272167&highlight=torque+wrench
I do not regret my purchase, however on speaking to people afterwards, it seems its not all as important as I figured it would be.
Also it would probably help someone a bit more knowledgeable to answer your questions if they know what it is you intend to torque
Wheel nut etc
again I would wait for someone more knowledgeable to answer but if you are greasing the wheel nut, I'm pretty sure thats a big faux pas
EDIT: I also got some good transferable advice here...
https://www.bikechatforums.com/viewtopic.php?t=271453&highlight= ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| Islander |
 Islander World Chat Champion
 Posted: 21:51 - 28 May 2013 Post subject: |
The ratchet type of torque wrench clicks when the set torque is reached. Draper wrenches won't break the bank and work well.
You only use a torque wrench for final tightening never to undo or as a general socket driver. Always return the wrench to its minimum setting after use to take the tension off of the spring and maintain accuracy.
Finally, for releasing rusty or seized nuts, don't use WD40 - it's a water dispersant not a penetrating oil. Use plus gas or an oil that's specifically designed for the job.  |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 22:12 - 28 May 2013 Post subject: Wrenches |
Two i got recently, both quite cheap but both seem to work well and cover the vast majority of items on bikes and also cars if you work on your car at all.
13-110nm give or take
https://www.machinemart.co.uk/shop/product/details/cht204-38in-drive-reversible-torque-wre
80-240nm i think this one was, have to double check in store if you need to be specific
https://www.argos.co.uk/static/Product/partNumber/7004243.htm
Would recommend getting one of these too, useful for getting things undone when you've torqued them high
https://www.ebay.co.uk/itm/15-BREAKER-KNUCKLE-FLEXI-EXTENSION-BAR-3-8-DRIVE-/321097367261?pt=UK_Hand_Tools_Equipment&hash=item4ac2e4fedd
Both wrenches are easy to set the torque on, just remember as islander said to re-adjust them to lowest setting after use, and both give a clear click when the torque is reached so just slowly and steadily turn once its hand tight until you hear the click then release the pressure.
I was new to torqueing as well until i got these but wouldnt do a job without them now theyre worth every penny and over the years more than pay for themself.
Also i'm no expert as i only started working on my bike in the past couple of months, but i have been told by a few people [maybe incorrectly] some bolts shouldn't be lubricated which can include wd40/greases etc i think, as when you torque the bolt up the lubrication can make the torque inaccurate if the bolt was originally made to be 'dry' installed. Please let me know anyone if thats incorrect and i'll remove the comment but something a few people mentioned on other forums.
I was recommended by a few people to use Copaslip
https://www.molyslip.co.uk/anti_sieze_compounds/
Which is suitable for preventing seisure apparently and also good at high temps which is useful - again, have used it thus far without a problem, its a bit pricey at i think nearly 10 quid for a tube but it'll last ages if you use it properly.
Definately worth using the torque wrenches though for peace of mind as much as anything haven't had a single problem since using it for tightening/using the bike after working on it, before i was scared to touch the thing
Good luck |
| Random13 |
 Posted: 00:57 - 29 May 2013 Post subject: |
lots of useful posts thank you
the thing is i see that most books says the torque for allen style bolt or nut is this much etc
how can you tight them to spec when you can only use the torque wrench which needs socket
you can only do this for bigger bolt/nut not for anything as the haynes suggest
am i correct ? |
| -Matt- |
| Random13 |
 Posted: 09:52 - 29 May 2013 Post subject: |
thanks again
really useful info and will start cracking on getting my torque wrench
i also like the idea of having a container to put all nuts/bolts in |
| SpeakForYou |
 SpeakForYou Two Stroke Sniffer
| cimbian |
 cimbian World Chat Champion
| SpeakForYou |
| neil. |
 neil. World Chat Champion
 Posted: 06:53 - 30 May 2013 Post subject: |
Copper grease isn't a lube so no problems there.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| cimbian |
| Islander |
| Islander |
| Random13 |
| cimbian |
| Commuter_Tim |
The last post was made 13 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
