Bought a Jawa
Ariel Badger
PostPosted: 16:20 - 30 May 2013    Post subject: Bought a Jawa Reply with quote
Just need to build the rest of it now.
PostPosted: 16:23 - 30 May 2013    Post subject: Re: Bought a Jawa Reply with quote
is that new?
Ariel Badger
PostPosted: 16:36 - 30 May 2013    Post subject: Reply with quote
Second hand but professionally maintained . It is 500cc and designed to run on methanol. It is a speedway motor.
Teflon-Mike
tl;dr
PostPosted: 16:53 - 30 May 2013    Post subject: Reply with quote
I'm not sure if I'm disappointed. Confused
I expected it to be a 350 two-smoke twin... after your LC thread....
But... what do those OHC Speedway engine's pump these days? About 70bhp? And I bet it weights about as much as a Smiler-trap!
So what's the plan?
It going to gain a gear-box?
Mono-cock sheet ali frame?
Who was it that made them for grass-track? Was it Hagon?
How far over can you cant them? They're splash lubed aren't they?
Will they run as a lay-down, or has it got to be a sloper?
Ariel Badger
PostPosted: 17:10 - 30 May 2013    Post subject: Reply with quote
Hi Mike.
I was toying with a smoker twin but my heart will always be with a big four stroke single. I want a bike that will go through the standing 1/4 very quickly and these motors are well suited to do that. It will be matched up to a gearbox and I will build a frame to suit.
Expect an epic in Show and Tell.
pepperami
PostPosted: 17:22 - 30 May 2013    Post subject: Reply with quote
I`m pleased you`ve bought a Jawa lump and are going to do something with it Thumbs Up
I am disappoint that it`s not a tatty old 350 twin Smile
If it was I might of learnt something from your posts?
PostPosted: 17:51 - 30 May 2013    Post subject: Reply with quote
He is teaching by example. You're just not learning by your mistakes.
Don't buy Jawa twins.
Teflon-Mike
tl;dr
PostPosted: 19:17 - 30 May 2013    Post subject: Reply with quote
Dedicated straight-liner, or another sprint bike?
You going to go for a classic unit box, like a Sturmey or Burman, or get creative & mill crank chambers off something more contemporary?
Lay-down or conventional? Rigid or sprung? Steel? Ali? Carbon? Tubular or sheet?
You're getting me all intrigued!
We do! We Do! NOW!
Ariel Badger
PostPosted: 20:17 - 30 May 2013    Post subject: Reply with quote
This one will be a dedicated straightliner in a laydown frame. I see no point in suspension as all it will do is slow me down with its weight so it will be in a rigid frame. My present concept is to have the box and motor in a plate aluminium alloy monocoque assembly suspended in a lightweight steel tubular frame with the front member and steering head from a Greeves. Gearbox will in all probability be Burman as I am used to working on them but could be BSA or Norton. Forks will be lightweight such as a BSA Bantam and wheels built on to Honda Chicken Chaser hubs.
It works in my head.
Musketeer
PostPosted: 21:11 - 30 May 2013    Post subject: Reply with quote
Waiting to see the photos of the rest of the bike hopefully in the near future Thumbs Up
Shaft
PostPosted: 00:25 - 31 May 2013    Post subject: Reply with quote
I fully appreciate you prefer the path less often trodden, but wouldn't it be easier to start with a grass/long track frame, which is already set up for the engine and gearbox, if only to act as a datum?
Ariel Badger
PostPosted: 22:02 - 01 Jun 2013    Post subject: Reply with quote
I have considered that but I like a challenge. The frame will not be the same as a Grasstracker as there is no need for it to corner.
Shaft
PostPosted: 23:11 - 01 Jun 2013    Post subject: Reply with quote
I was just working on the basis that, whenever I've built anything unusual, it's easier to start with something rather than nothing, even if the end result bears no resemblance to the original.
A longtrack frame would give you the basic dimensions, then you can strengthen, kick out the headstock and extend the rear triangle to your heart's content.
Lone-Wolf
PostPosted: 23:46 - 01 Jun 2013    Post subject: Reply with quote
Wotcha.
Nice engine. . . . it has just enough cylinders Laughing
https://www.moonshiners.org.uk/images/LWMElatin.jpg
Cheers.
L.W. - www.moonshiners.org.uk
Ariel Badger
PostPosted: 23:48 - 01 Jun 2013    Post subject: Reply with quote
I am starting with something simple, my brain!
Ariel Badger
PostPosted: 00:00 - 02 Jun 2013    Post subject: Reply with quote
Lone-Wolf wrote:
Wotcha.
You can't beat the rush of opening up a big single, I will add mount points for wheelie bars on the rear loop as I doubt I will be able to keep it down any other way.
Shaft
PostPosted: 00:37 - 02 Jun 2013    Post subject: Reply with quote
Having seen your other bike, I don't believe that for a second.
This project does interest me greatly; as a speedway fan, I know the bikes and their engines are designed with a total singularity of purpose, so it's good to see this motor being used for something else.
Do you know, is it a short or long stroke lump?
Ariel Badger
PostPosted: 00:55 - 02 Jun 2013    Post subject: Reply with quote
Square, 86X86.
Shaft
PostPosted: 01:03 - 02 Jun 2013    Post subject: Reply with quote
Ariel Badger wrote:
Square, 86X86.
That's unusual, who was running it before?
The last post was made 13 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 111.63 Kb
