Brake pads question
LustyLew
PostPosted: 13:22 - 01 Dec 2004    Post subject: Brake pads question Reply with quote
Hi,
Just a quick question.
What is the difference between 'Standard' and 'Sintered' brake pads?
Thanks Smile
PostPosted: 14:38 - 01 Dec 2004    Post subject: Reply with quote
Sintered pads have bits of metal imbedded in them. Generally work rather better.
mchaggis
PostPosted: 16:50 - 01 Dec 2004    Post subject: Re: Brake pads question Reply with quote
LH-ER5 wrote:
Hi,
Thanks Smile
I'm not exactly sure how Standard pads are made, other than pressing? Confused
Sintered pads are somewhat porous though, as they're made of a big pile of semi-metallic powder plus whatever else goes in (a very odd mixture of things, mainly chalk), put in a press and heated until they almost melt. The powder granules stick together without becoming molten. I imagine their coefficient of friction is higher and that they will clean themselves better perhaps.
Basically, like Keith says, it's primarily a difference in composition (and manufacture) to improve their friction qualities. I'm not sure if they wear faster, but probably.
To cause (metallic powder, for example) to form a coherent mass by heating without melting.
I must not be a troll...
Mmmm, Guinness
Bendy
Mrs Sensible
PostPosted: 17:04 - 01 Dec 2004    Post subject: Reply with quote
I believe that over time, sintered pads will eat your brake discs faster than standard pads, but it's a small price for better braking innit. Smile
PostPosted: 17:06 - 01 Dec 2004    Post subject: Reply with quote
The difference you need to know about is that sintered brake pads have more friction over a greater range of temperatures whereas standard pads can go 'off' if they get too hot. They have higher friction and so are more efficient at slowing you down, the downside of this is that they will wear your discs out more quickly.
Having a lot of metal in them means the pads themselves actually last quite a long time.
Another plus point of sintered pads is that they are unaffected by water on the disc/pads.
To summarise, sintered pads are better but wear your disc out more quickly. Check out the price of pattern discs before you decide to use them.
mchaggis
Ah of course, my memory's pants these days and I'm only 20... Rolling Eyes
Sacrificial braking. Normally your pads are sacrificed (worn) to get a high level of braking. Put on more abrasive pads and your discs will wear more too.
Mmmm, Guinness
LustyLew
PostPosted: 17:48 - 01 Dec 2004    Post subject: Reply with quote
Wow! Plenty of responses... Thanks guys. Think I'm going to stick to standard pads this time round. My damn brakes have decided to go through a 'binding' phase. Due for their annual rebuild I think.
Thanks again. Smile
PostPosted: 18:23 - 01 Dec 2004    Post subject: Reply with quote
If this involves draining down the fluid, and you haven't already done so. I would wholeheartedly recommend the fitting of braided steel brake lines in place of the original rubber ones as the single best thing you can do to a motorbike to improve the brakes. They are not too expensive (like about £15 per line).
mchaggis
PostPosted: 18:33 - 01 Dec 2004    Post subject: Reply with quote
Just had a thought... Would it be possible for braided aftermarket lines to be cheaper than replacement OE rubber ones?
It certainly looks like it, as OE brake lines for an NT650 are 40 odd dollars on a site which I finally managed to find to give a price for rubber lines. $40 for rubber ones, vs. $20-25 for braided? Confused
Mmmm, Guinness
Fortuna
PostPosted: 18:58 - 01 Dec 2004    Post subject: Reply with quote
Yes indeed. OEM stuff is always dear.
BTW don't be off put by sintered having metal in them as it's a very soft metal, softer than your disc so it wears first. BUT it will wear your discs faster than normal pads like everyone else has said.
PostPosted: 21:44 - 01 Dec 2004    Post subject: Reply with quote
You can actually get non OEM rubber hoses, but they are not common.
To be honest I am not that keen on braided hoses. I just find the feel is not so good, but then I do like some travel in the brakes.
In the USA (and probably a few other countries) the bolt together braided hoses commonly sold in the UK are not legal for road use.
LustyLew
PostPosted: 23:57 - 01 Dec 2004    Post subject: Reply with quote
hi ya peeps,
Thanks for the advice so far, it's been a great help. I do however, have a few more questions. Embarassed
My friend and I took a look at my caliper the other day, to try and find out why it was binding so much. We did not have the whole thing apart, but from where we could see, the pistons were not sticking and it seemed to be 'floating' OK(ish).
When I brake I get a noise that would indicate that the pads or disc are rubbing uneven. The noise comes and goes in a rhythmic fashion and looking at one of my pads, its down to the wear marker on one side, but plenty of material left on the other.
I'm hoping that I'm just wrong about it floating properly. My local bike mechanic has said he'd take a look, but has suggested new pistons and seals. Do you think it's also worthwhile replacing the disc? This binding problem has made the surface quite uneven.
Think I'll refer to Korn's guide too, save myselfa few bob. I like getting my hands mucky. Very Happy
Thanks again.
Lewis
The last post was made 21 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 78.53 Kb
