KTM 525 EXC
Irn-Bru
PostPosted: 08:01 - 03 Jun 2013    Post subject: KTM 525 EXC Reply with quote
Going to have a look at one next weekend, mates neighbour is selling it. Comes with supermoto & off road wheels.
It will be a second bike so the servicing being in hours isn't a huge deal. It should work out to an oil change every 500 - 600 miles on the road from what I've read.
He wants £2,200 for it but I don't know the year of mileage/hours yet. What sort of price do they usually go for?
I saw a KTM 660 SMC locally as well but I never knew those things didn't have an ignition and were kick start only. Plus they want £3,100 for it and don't even know the true mileage but does look very clean.
PostPosted: 08:09 - 03 Jun 2013    Post subject: Reply with quote
Seen a few within 20 miles go for around 2k. Seem to command a higher price at the minute elsewhere though.
I'd probably pay that for it sub 5000 miles.
Irn-Bru
PostPosted: 14:18 - 08 Jun 2013    Post subject: Reply with quote
Ended up going for it.
£2,200
'52 plate
115 hours
Both set of wheels with some nice sticky tires on as well. Only downsides are no tax or test and the front brake is just a 2 pot brembo from the off road wheels I think? Got a few other bits and bobs with it as well, locks and stuff, the usual I seem to acquire from bike sales these days Razz
delvey91
PostPosted: 16:02 - 08 Jun 2013    Post subject: Reply with quote
It will be the earlier 520 if its an 02, Engines are solid on those just keep an eye out for oil coming out the waterpump weap hole.
2016 Honda Africa Twin
2006 KTM 200 EXC
PostPosted: 17:55 - 08 Jun 2013    Post subject: Reply with quote
The two pot is pretty capable on a 320mm disc with what should be a fairly light weight - never had a problem on my fairly-similar FE501.
Irn-Bru
PostPosted: 20:40 - 08 Jun 2013    Post subject: Reply with quote
Good idea G, would be a lot cheaper than getting a 4 potter. Would need a bracket made though?
Had a bit of a mission getting it home. PO said it had half a tank and I didn't confirm it for some reason. Had a nice 2 mile walk pushing the bike...!
I do like the speedos on these, look quite fancy for a 2002 bike. Wish I knew how to use the fecker though.
EXC-Rider
PostPosted: 19:41 - 09 Jun 2013    Post subject: Reply with quote
you can get a mount for the bigger disc i have one on mine ill try get a pic tomorrow,
owned bikes: DR50, Thumpsta 110 , Honda CR85, Speedfight 100, Yamaha XT125X, Honda CRF450, Honda Hornet '07
current bikes: KTM EXC525 AKA the wheelie machine
A friend in need is a friend indeed but a friend with weed is better!
Irn-Bru
PostPosted: 19:50 - 09 Jun 2013    Post subject: Reply with quote
Cheers Thumbs Up Yours is just the standard 2 pot calliper as well?
EXC-Rider
PostPosted: 19:57 - 09 Jun 2013    Post subject: Reply with quote
mine is a 4 pot, i may have one i can sell you, will have to have a look
The bracket is very standard and should be easy enough to come by - the same bracket could be used on my CCM, KTM and Husaberg, with both pre 2003 and post 2002 KTM wheel spindles etc - so should be plenty around.
Annoyingly, they changed it very slightly for the 690, so you can't swap around. (690 enduro is 300 mm disc as standard, so I just left that on for the SM wheels.)
EXC-Rider
PostPosted: 17:45 - 10 Jun 2013    Post subject: Reply with quote
if this helps you out in anyway but can see the brembo bracket
https://farm8.staticflickr.com/7387/9007947839_b3d22752d2_b.jpg
Irn-Bru
PostPosted: 18:24 - 10 Jun 2013    Post subject: Reply with quote
Looks the same as mine, are they defo 4 potters? Thinking What's the black cable hanging off? Speedo? Also what size is the disc?
Do you have a steering lock with your bike? I discovered mine has one but I never got a key... disc lock is more effective anyway, one kick and they snap. I would never leave the bike in public anyway but would be nice to be able to run in a shop for a few mins.
EXC-Rider
PostPosted: 20:29 - 10 Jun 2013    Post subject: Reply with quote
yeah they mini 4 potters i have another one witch is bigger but still a 4 pot, cable is for a Vapor speedo, disk i think is 310mm and yeah have steering lock but with no key, have no keys at all with his bike. i couldnt fit a disk lock on my front because the disk is to close to the rim so cant fit a lock arround it so mine goes on the back.
Irn-Bru
PostPosted: 20:34 - 10 Jun 2013    Post subject: Reply with quote
Mine has the stock speedo unit on, it's quite good, only thing missing is RPM but has everything else.
I guess I'll be after a 310 disk and the bracket then and I'll be sorted. Also got issues with brake switches but hopefully it's an easy fix, think it's the rear one thats faulty as front looks fine.
EXC-Rider
PostPosted: 20:43 - 10 Jun 2013    Post subject: Reply with quote
quick pic to show the size of calipers,
https://farm9.staticflickr.com/8138/9009388151_c25c03ef35_b.jpg
i got a lot on mine that dont work, electric start broke, headlight broke, rear light dont work (brake light does) RPM on speedo dont work, atm my clutch also dont work Thumbs Up but the amount of fun the bike brings makes up for that, like i said loads of little jobs, engine is sweet as a nut, gear box is great.
Irn-Bru
PostPosted: 21:00 - 10 Jun 2013    Post subject: Reply with quote
Just take the light off, it's only 2 6mm bolts, check the bulb. Mine was caked in mud, not sure how it got in there. Cleaned it up then it started working again but one of the brake switches is dodgy so brake light sticks on I think.
Engine and gear box on mine are good as well. Not as much broken as yours haha
EXC-Rider
PostPosted: 21:19 - 10 Jun 2013    Post subject: Reply with quote
yeah headlight is easy fix just getting round to it, they all easy fix just not enough hours in the day
The last post was made 13 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Offroad & Supermoto All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 91.75 Kb
