Fully Synthetic?
Crash it for fun
PostPosted: 21:56 - 01 Dec 2004    Post subject: Fully Synthetic? Reply with quote
Hi,
I've just had my bike serviced at lloyd coopers in Hemel Hempstead. On the service sheet it says they've used Putoline Syntec 4 which is a fully synth oil. My bike is a Hornet 600 (2002) and I thought Total sythetic oils were only for superbikes really. Anyone have any comments on this?
Cheers,
Mark
Rob W
PostPosted: 21:59 - 01 Dec 2004    Post subject: Reply with quote
I have no clue myself mate, but I wouldn't of thought it'd do any damage surely?
Claud 14.7 to 1
PostPosted: 22:42 - 01 Dec 2004    Post subject: Reply with quote
Aren't Lloyd Coopers in Watford? Queens road right?
Be happy with the oil. It's more expensive/better and is nice of them to do this. I would have expected them to use semi.
Always found them to have very good service. Thumbs Up
Guest
PostPosted: 23:10 - 01 Dec 2004    Post subject: Reply with quote
Waste of money on a bike for road use in my opinion, and could cause clutch slip on some models.
Claud 14.7 to 1
PostPosted: 23:24 - 01 Dec 2004    Post subject: Reply with quote
Oh hang, on did you have to pay extra for it? Shocked
Clutch slip would be rare IMO on that bike. Especially seeing as its resonably new.
You will know if it slips. People say it would on my: 12 year old Cbr4 with decent mileage. I use semi in mine.
Crash it for fun
PostPosted: 09:08 - 02 Dec 2004    Post subject: Reply with quote
I don't think so. I thought it would be okay I just wanted to check
I have had this but only sometimes when pissing about doing wheelies
PostPosted: 11:30 - 02 Dec 2004    Post subject: Reply with quote
I wouldn't worry about it. The oil is likely to be better for the engine (although whether that is of any relevance for the life of a road bike is another question).
Very unlikely to cause any clutch slip problems. Not really any different to any other oil of the right rating.
Kram
PostPosted: 18:00 - 03 Dec 2004    Post subject: Reply with quote
can i just ask a non related question... how much does a full service cost???
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
spacecowboy
PostPosted: 05:56 - 04 Dec 2004    Post subject: Oil Reply with quote
Fully synthetic oils are just a bit better at holding together for longer and under extreme loads.
They will work ok with less stressed engines, but will tend to be a waste of money. Semi synthetic is likely to be a good choice for modern bikes. Anything from the dark ages (before the mid 90's) will be better off using a good quality multi-grade with frequent changes.
Cracking nuts with a mash hammer is all that you will be doing.
Just remember not to mix oil types, and change your filter at the same time as the oil.
the Space Cowboy.
'Death is just natures way of telling you to slow down - Grouch Marx'
craigT19
Jolly Green Giant
PostPosted: 15:33 - 04 Dec 2004    Post subject: Reply with quote
yeah the only time i was told not to use fully synth was when breaking the engine in as i was told it tends to polish the internals and rings meaning the seals cant hold oil
spacecowboy
PostPosted: 05:00 - 05 Dec 2004    Post subject: Rings 'n' things Reply with quote
Thats about right, although not so much with really modern engines. Initially your rings and bearings actually have to wear a bit to get the two surfaces to bed in.
I don't know what the factories do with the engines, but performance motors usually come with recommended fully synthetic oil already in from the start.
Another thing to mention, you can screw up older clutch plates with oil additives (Slick50, molyslip etc.) as well as fully synthetic oil.
Very slippy stuff. Wink
the Space Cowboy.
stevo123
PostPosted: 23:37 - 05 Dec 2004    Post subject: Reply with quote
https://www.mototuneusa.com/break_in_secrets.htm. As the title says-controversial. If you take time to read it with an open mind and a half decent understanding of what breaking an engine in is all about it makes sense. If I had shelled out for a brand new machine would i have the balls to do this though?..... Hell yeah Surprised
jay12329
Dr. Evil
PostPosted: 16:35 - 06 Dec 2004    Post subject: Reply with quote
I also have a 2002 hornet, its slightly younger than yours its on a 03 plate. For its first two services it had Minaral oil in it, i have recently chaged the oil to castrol gps, which is a semi synth oil. From my experence the hornet is only susseptable to clutch slipping when being ridden very hard and you are using clutchless gear up shifts.
Most people use semi synth in the hornet.
HTH
J
The last post was made 21 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 77.38 Kb
