Rust On Exhaust
AaronG97
PostPosted: 13:59 - 03 Jun 2013    Post subject: Rust On Exhaust Reply with quote
Hey,
I've got a small Yamaha CS50 moped - I only got it in March but already the exhuast seems to be going rusty? I don't know why considering it's kept in the garage overnight and I don't go out much in the rain. Is there anything I can do to prevent any more rusting? I've attached an image to show what it's like at the minute.
https://i.imgur.com/Xk3b8D9.jpg
Any advice appreciated!
Cheers,
Aaron
motad_uk
PostPosted: 15:29 - 03 Jun 2013    Post subject: Reply with quote
high heat black paint after a gentle sand off to clear the rust will make it look better- but it may come back as most of the black high heat finishes are porous and tend to rust
DrDonnyBrago
PostPosted: 19:46 - 03 Jun 2013    Post subject: Reply with quote
They all do that, paint it with plastikote BBQ spray paint.
tomh
PostPosted: 00:06 - 04 Jun 2013    Post subject: Reply with quote
As above, Use Plastikote BBQ paint. If you've got a Range nearby, its the cheapest place I've found to buy it.
AaronG97
PostPosted: 15:40 - 04 Jun 2013    Post subject: Reply with quote
Cheers guys, just went to the range to get some, got to the checkout and apparently there's an age restriction on it Rolling Eyes
Will have to order it online
Is it best to take the exhaust off before spraying it?
DrDonnyBrago
PostPosted: 15:55 - 04 Jun 2013    Post subject: Reply with quote
Depends on how well you mask off the rest of the bike, it might be simpler to leave it on, although probably not as neat.
If you do remove it, beware that the bolts holding it on might be heavily rusted and seized to the point of snapping. It will be a major pain in the neck if they snap. You'll also probably need a new gasket to seal it to the engine again.
The last post was made 13 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.25 - MySQL Queries: 13 - Page Size: 45.93 Kb
