Sparks on New Battery
Bene
PostPosted: 21:10 - 04 Jun 2013    Post subject: Sparks on New Battery Reply with quote
Hi, can anybody help? I've just replaced my old battery because I've been having trouble with it. I've charged my new battery and connected it. Now when I start the bike I'm getting a lot of sparks coming from the negative terminal. The bike starts up, but obviously I'm worried about the sparks, any suggestions?
I've cleaned the connectors. The only thing I'm wondering is that I've had to squash down the positive wire a little, it is a little squashed. This is because the shape of the battery is different to the old one. It is the correct battery for the model. Yam sr125.
Any suggestions please? I've very worried about these sparks.
Thanks.
Raffles
PostPosted: 21:22 - 04 Jun 2013    Post subject: Reply with quote
You did tighten the battery connectors didn't you?
Bene
PostPosted: 21:24 - 04 Jun 2013    Post subject: Reply with quote
Yes they are tight. A friend of mine said I could have got the connections on the wrong terminals is this possible?
Bene
PostPosted: 21:32 - 04 Jun 2013    Post subject: Reply with quote
The problem is the shape of the battery terminals are the opposite way on the new battery, so I have had to swing and stretch the wires to meet the new shape. Is it possible that the terminals should be the other way around even though I am matching + to + and - to -?
andy_uk
PostPosted: 21:48 - 04 Jun 2013    Post subject: Reply with quote
No, don't swap the terminals round!!!
If it starts then it's the right way round.
Is the spark between the battery terminal and the connector or between the wire and the connector?
Bene
PostPosted: 22:06 - 04 Jun 2013    Post subject: Reply with quote
Cheers. I didn't think it was a good idea to swap them around. I have try tried it again and it starts fine, been riding around and stopped it a couple of time and starts OK. I wonder if it was just a little wet or something, though I did clean it. This means it must be the right way around then definitely?
Turkish
PostPosted: 22:24 - 04 Jun 2013    Post subject: Reply with quote
Why didn't you buy the correct battery? Doh!
You shouldn't be getting sparking from the terminals. Apart from being a fire risk it's hardly a nice load for the regulator rectifier to cope with.
ZX-6R G2
CBR125R RW6
Bene
PostPosted: 22:32 - 04 Jun 2013    Post subject: Reply with quote
I did buy the right battery for my model. However when it came the terminal shapes were the other way around. It is difficult to explain, unless you get what I mean. The last time I tired it I didn't get any sparks, so I don't know. Is it possible to start it up and ride it around if it is connected to the wrong terminals? If not then it must be correct.
Bene
PostPosted: 22:37 - 04 Jun 2013    Post subject: Reply with quote
This is the battery I have bought.
https://www.ebay.co.uk/itm/Lextek-Motorcycle-12N7-3B-Motorcycle-Battery-for-Yamaha-SR125-SR-125-/181033584716?pt=UK_Motorcycle_Parts_13&hash=item2a2671484c
It says Yamaha SR125 so it must be the correct one. As you see the terminal plus is on the right hand side in the picture. Well my old battery the terminal + would be on the left hand side. So I have swapped the wires around so + meets + and - meets -.
Turkish
It will not work if it is connected backwards.
Clean up the terminals and smear with vasaline. Do them up tight, but don't strip the threads or snap the terminals off. Try and reroute the cables to get more slack if you can.
But if it's running and no more sparks then you're golden I guess Smile
ZX-6R G2
CBR125R RW6
Nexus Icon
PostPosted: 22:53 - 04 Jun 2013    Post subject: Reply with quote
Do the wires have to reach across the battery, crossing each other, to the correct terminals? Surely spinning the battery through 180 degrees to shorten their path is the way forward?
Keeping -ve to -ve and +ve to +ve of course.
Greetings from Shitsville!
Bene
PostPosted: 23:02 - 04 Jun 2013    Post subject: Reply with quote
Thanks for help. It must be the correct way then. I'll put some vasaline on.
No the wires don't have to cross but one is squashed down a little. Yes I spinned the battery around, but this alters the position of the terminals, again hard to explain, but in the image the terminals are facing you, when you flip it they point the other way. This means that where the wires were it wouldn't fit so I have had to pull the wires around. Do you know what I mean? Hopefully there will be no more sparks. I will take the panels off tomorrow and check when I start it up.
All of this would be solved if the battery was just the same as the old one. I can't understand why manufacturers mess about with such things.
Thanks again for you help.
scotthx1
PostPosted: 07:20 - 06 Jun 2013    Post subject: Reply with quote
can you get pics of your problem
MattEMulsion
PostPosted: 10:31 - 06 Jun 2013    Post subject: Reply with quote
If the terminals are in a different place then it quite clearly is a different battery to the old one, possibly not the right one, don't rely on ebay sellers 100%!
As long as it fits, it is secure and wired up correctly then it will be fine, but you should not be seeing sparks!
Yamaha YZF-R6
andym
PostPosted: 12:03 - 06 Jun 2013    Post subject: Reply with quote
This might sound a bit stupid here, but one I've just noticed on my bike.
Are you using the correct screws for the battery, if they are slightly too long then even though you've tightened them up properly the cables could still be slightly loose and causing them to vibrate slightly.
(this is the one I've noticed on my bike). Is any part of your battery tray metal? Is it near the battery terminals
Bene
PostPosted: 19:32 - 07 Jun 2013    Post subject: Reply with quote
Thanks. It's been fine the rest of this week, the only problem was on the same day I fitted it, so it is possible that there was just some water or something on the connections.
Cheers.
andy_uk
PostPosted: 19:48 - 07 Jun 2013    Post subject: Reply with quote
I've had a thought (yeah, I know - scary!!)
Were the connectors and terminals clean?
It there was a little corrosion then that could cause them to spark initially when starting the bike due to the high current involved.
Bene
PostPosted: 20:40 - 07 Jun 2013    Post subject: Reply with quote
One of the bolts and nut on there is a bit old and rusty. Maybe that could be it?
moonzoomer
PostPosted: 20:46 - 07 Jun 2013    Post subject: Reply with quote
new batteries are normally supplied with new connectors, angled adapters are also available for the battery terminals which may have been supplied in the bottom of the box along with the nuts/bolts
temeluchus
PostPosted: 20:49 - 07 Jun 2013    Post subject: Reply with quote
get yer phone out and take a picture.
moonzoomer
PostPosted: 20:53 - 07 Jun 2013    Post subject: Reply with quote
That battery with front terminals will only suit 1996-1999 SR125 models, what year is your bike and did the original battery have end terminals? I think you need this universal type for SR125 models or you could adapt the battery using the angled terminals supplied in this battery kit
https://www.ebay.co.uk/itm/MotoBatt-QuadFlex-MB9U-Battery-for-a-Yamaha-SR-125-All-Models-1982-2003-/140778664933?pt=UK_Motorcycle_Parts_13&hash=item20c70ff3e5
This kit will adapt your existing battery to suit the wiring layout if your bike is not the 1996-1999 model.
https://www.ebay.co.uk/itm/Motorcycle-Battery-Terminal-Conversion-/180798979244?pt=UK_Motorcycle_Parts&hash=item2a18757cac
Bene
PostPosted: 21:06 - 07 Jun 2013    Post subject: Reply with quote
It's the 1993 model. So that would explain why the terminals are the other way around. I could just buy the adapters I suppose but it is working fine now, so I don't know if to just leave it.
Edit: oh I would take photos but I don't want to be pulling the battery out now that it is working fine. Not broke don't fix!
moonzoomer
PostPosted: 21:13 - 07 Jun 2013    Post subject: Reply with quote
If the bike is working then leave it but make sure the terminals are good and tight as this will effect the battery charging/lighting and engine starting. Your model should have had a battery with end terminals not front terminals, the kit I gave you the link for is cheap so if in any doubt at all just buy and fit it which is a very easy job.
Bene
PostPosted: 21:56 - 07 Jun 2013    Post subject: Reply with quote
Thanks for the link, I have saved it so if I have any issues I can order it. Cheers.
The last post was made 13 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 119.29 Kb
