Can't fit Clutch cable
MissBex
PostPosted: 13:17 - 07 Jun 2013    Post subject: Can't fit Clutch cable Reply with quote
Heya all,
Just trying to put a new clutch cable on my 98 bandit. I've hooked the bottom end on already but now I don't seem to have enough cable to fit into the lever end?
The metal casing bit on the cable is just in the way of the groove on the adjuster, I've pulled it through as much as possible, any advice?
Cheers
Direct Access Passed - 30/05/14
00' Honda Hornet 600
mudcow007
PostPosted: 13:23 - 07 Jun 2013    Post subject: Reply with quote
a. sure its the right cable?
b. is it routed properly?
have you got adjusters on the cable, if so have you loosened em?
MissBex
PostPosted: 13:34 - 07 Jun 2013    Post subject: Reply with quote
Ah I see I needed to loosen the bottom. I've got it to fit in but now once the lever is pulled in it doesn't flick back out?
Islander
PostPosted: 13:40 - 07 Jun 2013    Post subject: Reply with quote
Check the routing and make sure it's not snagged anywhere.
MissBex
PostPosted: 13:52 - 07 Jun 2013    Post subject: Reply with quote
It doesn't seem snagged anywhere but upon looking it up I've noticed that there is a spring on all other pictures of others bikes attached to the the arm, however mine doesn't have a spring at all, is this normal?
When taking the cover off initially there wasn't one there which I can see as I've filmed it, but I've ridden it fine before.
EDIT: Ah, I've got it to spring back by fiddling with the adjusters some more.
MissBex
PostPosted: 14:32 - 07 Jun 2013    Post subject: Reply with quote
Hmm ok, next problem is now it's all installed the clutch isn't engaging(?), In first gear I can let it all the way out and nothing happens.... Maybe the adjusters again, I'll have another fiddle.
Islander
PostPosted: 14:35 - 07 Jun 2013    Post subject: Reply with quote
That's adjustment. You've gone from too loose to to tight. Laughing
The last post was made 12 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 50.21 Kb
