Time???????????
Bike Chat Forums Index -> Random Banter Goto page 1, 2, 3 ... 29, 30, 31  Next
Skudd
PostPosted: 15:52 - 07 Jun 2013    Post subject: Time??????????? Reply with quote
I was driving last night and had Radio 4 on as usual. They were talking Einstein stuff and got on to time being a funny old thing, I wasn't listening too hard, but they did say something about putting a clock in a plane, flying somewhere and back with the clock then showing a different time to the clock that stayed still, also something about twins, one going to space and aging differently to the one on earth when they got back. They also talked about rubber mats a bowling ball and light, but I was going through road works at the time so didn't listen.
Does the plane thing actually work in reality and has anyone actually seen it themselves in action?
Tungtvann
PostPosted: 15:58 - 07 Jun 2013    Post subject: Reply with quote
Time slows down the faster you go. Supposedly, what the fuck does this Einstein guy know.
https://en.wikipedia.org/wiki/Time_dilation
Here you go, yes, it's real.
DrDonnyBrago
PostPosted: 16:00 - 07 Jun 2013    Post subject: Re: Time??????????? Reply with quote
It is called time dilation, it does work, but you'd need atomic clocks to notice it as the differences are measured in nanoseconds (billionths of a second).
https://en.wikipedia.org/wiki/Hafele%E2%80%93Keating_experiment
PostPosted: 16:24 - 07 Jun 2013    Post subject: Reply with quote
They've proven it by building two identical atomic clocks, putting one on a space station and another underground. They then drift out of sync from each other.[/list]
Derivative
Yes, the plane experiment has been done. The change is on the order of nanoseconds but it has been measured (we have very accurate clocks nowadays).
Special and General Relativity are fairly well tested.
https://en.wikipedia.org/wiki/Shapiro_delay
Massive objects delay light signals.
https://en.wikipedia.org/wiki/Gravitational_lens
They also pull light in as if it were massive.
Loads of other experiments out there.
I have an exam on special and general relativity in a week's time.
https://www.amazon.co.uk/Wonderful-World-Relativity-precise-general/dp/0199694613
This book is good reading and as I recall it doesn't really need anything other than basic GCSE level algebra to get through.
Its' mathematical big brother is our course material.
If you're wondering why the effect on planes is so small, it's because relativity produces weird effects in proportion to speed - but the benchmark is the speed of light (300,000,000 metres per second). A plane travels something like 300 metres per second (I had to double check that one because it sounds mental. But 600mph is about 1000km/h is about 0.3km/second).
PostPosted: 16:29 - 07 Jun 2013    Post subject: Reply with quote
Yes, it's been tested and it does happen. A fast clock runs more slowly.
They can now measure this effect by having two super accurate clocks as little as 12" above one another (the higher clock is moving faster as the earth rotates).
C.W. Chou, D.B. Hume, T. Rosenband and D.J. Wineland. Optical Clocks and Relativity. Science. Sept. 24, 2010.
Islander
PostPosted: 16:40 - 07 Jun 2013    Post subject: Reply with quote
Oh it works - GPS signals have to compensate for it. The concept has been verified experimentally using atomic clocks too. Gravity wells affect time as does velocity. Thumbs Up
Copycat73
PostPosted: 16:48 - 07 Jun 2013    Post subject: Reply with quote
I saw that star trek episode aswell Laughing
caveat emptor
Lord Percy
PostPosted: 17:04 - 07 Jun 2013    Post subject: Reply with quote
Also there's length contraction. So the clock in space my have a longer life, but it is then shorter than its clock brethren!
PostPosted: 17:14 - 07 Jun 2013    Post subject: Re: Time??????????? Reply with quote
I believe that was describing the fabric of space-time - I was only in the car for a couple of minutes as was stopping in at the shops on the way home.
Robert Heinlein wrote a book about telepathic twins, one of which went in to space and the other stayed on earth - thanks to near light speed travel, the one who went in to space aged a lot slower and outlived his brother by some considerable amount.
Being Heinlein, the surviving one of course married one of his relatives when he returned.
Oh and yes, space-time makes my head hurt Sad.
Another fun one is that the speed of light is constant (I think that was mentioned last night), so if you shone a torch forward in your space ship going at 1mph below the speed of light, the beam would only be creeping in front of you.
Islander
PostPosted: 17:23 - 07 Jun 2013    Post subject: Reply with quote
No, the beam would be travelling at the speed of light with respect to the person holding the torch even if they were travelling at 99.9% of the speed of light themselves. It's all to do with referential frames. Laughing
daemonoid
PostPosted: 17:29 - 07 Jun 2013    Post subject: Re: Time??????????? Reply with quote
No, it's weirder than that... If you were travelling at near the speed of light and turned on your torch it would travel away from you at the speed of light although other observers would see it moving only fractionally faster than you. That's the bit that really makes my head hurt.
As for speed's affect on time - nearly all of us have a device that relies (well corrects) for it... satnav. The effect is so great that if there was no correction was made for it your position would creep by meters each day.
The bit I really like is that we are all travelling through 4 dimensions* (3 spatial + time) at the speed of light. This relates back to the increase in speed modifying your speed of travel through time.
The speed of light is slightly misnamed - light doesn't really have anything to do with it any more than a motorbike has to do with the existence of 70mph... The speed of light is actually the cosmic speed limit defined by the transfer of information from one place to another, the fact that light travels at that speed is just a by product of it's lack of mass.
current: ducati monster 750
Derivative
PostPosted: 17:31 - 07 Jun 2013    Post subject: Reply with quote
Yes.
The point is that the beam travels at c in all frames.
So if you have a laser pointer on your spaceship travelling 0.999c, you observe the laser beam travelling at c.
A guy on a stationary rock watching you doesn't see the laser beam at 1.999c or 0.001c, he sees it travelling c. So he reckons you're going nearly as fast as the beam.
The bit that does change is that he'd see it doppler shifted (i.e it'd change in wavelength and thus colour).
PostPosted: 17:36 - 07 Jun 2013    Post subject: Re: Time??????????? Reply with quote
The speed of light is constant BUT light does not travel at a constant speed.
It can go at walking pace in some substances and can even be stopped then restarted. It'sa still travelling at the speed of light.
The important thing to remember is that it is a constant (c) in that substance. It's the fastest thing that can travel in that substance and will always be travelling at the same speed relative to anything else in that system, regardless of how fast and in which direction that object is moving.
Weirded out yet?
Frost
PostPosted: 17:43 - 07 Jun 2013    Post subject: Reply with quote
It's confusing because light traveling at any speed is by definition going at the speed of light. Lightspeed on the other hand is the maximum speed anything can ever travel at and is the speed light travels at in a vacuum.
keggyhander
PostPosted: 18:00 - 07 Jun 2013    Post subject: Reply with quote
I know my chemistry and biology but this physics stuff is beyond me.
Sload
PostPosted: 18:19 - 07 Jun 2013    Post subject: Reply with quote
Er...
https://advanceproprecovery.com/wp-content/uploads/2013/01/Thinking-man-stop-my-sale.jpg
https://meremortalblog.files.wordpress.com/2012/11/mind-blown.jpg?w=412
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Skudd
PostPosted: 18:40 - 07 Jun 2013    Post subject: Reply with quote
I blame Radio 4 for making me think about stuff.
Women's hour is a mine field. Shocked
PostPosted: 18:44 - 07 Jun 2013    Post subject: Reply with quote
Frost wrote:
Lightspeed on the other hand is the maximum speed anything can ever travel.
Not strictly true. Light used to travel faster when everything in the universe was closer together and hotter.
It's also increasingly likely that some objects can move instantaneously between two points in space in a non-linear manner.
It would be more accurate to say lightspeed it is the maximum speed we can observe a non-quantum object travelling at within the current system and timeframe we occupy.
A photon can, for example, demonstrably be in two different places at once.
Just read that last sentence again...
cimbian
PostPosted: 18:58 - 07 Jun 2013    Post subject: Reply with quote
Demonstrably, yes, but measurably, no... Now that is weird. Smile
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
Derivative
PostPosted: 19:05 - 07 Jun 2013    Post subject: Reply with quote
Source?
Space has expanded, but I'm not aware of the speed of light being different in the past.
PostPosted: 19:23 - 07 Jun 2013    Post subject: Reply with quote
It could be. You can demonstrate that it was in one place or the other.
This about where Hetzer can chime in. Very Happy
Me, I can't wait for an entangled pair Ansible. Or can I? Thinking
Skudd
PostPosted: 19:26 - 07 Jun 2013    Post subject: Reply with quote
I bet you a joy to play against at scrabble.
mcgoogle
PostPosted: 19:40 - 07 Jun 2013    Post subject: Reply with quote
what was the experiment someone setup where the act of observing said experiment change the results
current bike - CBR600fv
trevor saxe-coburg-gotha
PostPosted: 20:13 - 07 Jun 2013    Post subject: Reply with quote
Schroedinger's cat? That was just a thought experiment though.
The last post was made 13 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 31
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 133.29 Kb
