Indicator out, not bulb - relay? CG 125
axelfoley
PostPosted: 17:19 - 08 Jun 2013    Post subject: Indicator out, not bulb - relay? CG 125 Reply with quote
My front right-hand-side indicator is out; the other three work (although the rear right flashes faster), and I've swapped bulbs to confirm that the bulb is OK.
I'm having difficulty locating a new relay as the one on the bike (2005 CG125) has three pins and the ones on ebay (including the one I bought - doh) only have two.
WHilst I source a new one, is there anything else I can try? I've picked the indicator over a bit to see that it's all connected to the bulb fitting, and WD40'd a bit, to no avail. Is the relay a safe bet?
Ta Smile
cb1rocket
PostPosted: 20:07 - 08 Jun 2013    Post subject: Reply with quote
Any 3 pin relay will work as long as it is rated the same wattage as the bulbs
axelfoley
PostPosted: 20:35 - 08 Jun 2013    Post subject: Reply with quote
Ah, that's good to know. Cheers.
sickpup
Old Timer
Its not the relay, check the wiring to the indicator.
axelfoley
PostPosted: 21:00 - 08 Jun 2013    Post subject: Reply with quote
I've checked the connections in the indicator itself, and then it goes off behind the headlamp and is all wrapped up. Looks pretty solid. Not sure how to check that further without making a mess!
What makes you say that? Is the relay a 'works properly or doesn't work at all' part?
cb1rocket
PostPosted: 22:36 - 08 Jun 2013    Post subject: Reply with quote
only other way to check, is get the multi meter out and start probing for continuity in the wires
J.M.
PostPosted: 23:00 - 08 Jun 2013    Post subject: Reply with quote
Yes. Your issue is wiring, somewhere.
2004 R1 & 2018 XSR900
tomh
PostPosted: 00:20 - 09 Jun 2013    Post subject: Reply with quote
If your indicator light is flashing next to the speedo when the non working indicator is susposed to be flashing then the main loom is fine and the problem is the wiring from the indicator to the bullet connector in the headlight shell.
Islander
PostPosted: 00:24 - 09 Jun 2013    Post subject: Reply with quote
This ^^^
The flasher relay is simply switched into each side as required. If one side works and the other doesn't then it's either the bulb or wiring that's at fault.
The last post was made 12 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 64.61 Kb
