peugeot 50cc helpabout starter
badbill
PostPosted: 21:49 - 08 Jun 2013    Post subject: peugeot 50cc helpabout starter Reply with quote
hi all i need more help just fitted a new starter motor ,relay and battery and still doing the same thing starter is turning just very slow not enough to turn engine as if theres no power in the battery but it fully charged what should i check next
peugeot jetforce 50cc c-tech
Linux
PostPosted: 21:50 - 08 Jun 2013    Post subject: Reply with quote
I'm assuming it starts fine on the kick start?
Two wheels are all I need.
badbill
PostPosted: 21:53 - 08 Jun 2013    Post subject: Reply with quote
no not a moment not when cold but it will run if warm
Linux
PostPosted: 21:59 - 08 Jun 2013    Post subject: Reply with quote
Classic speedfight that is, had a 100cc, installed a manual choke in the end because it got so bad when cold starting.
Never saw your old thread so may be asking irrelevant questions.
Have you checked the earth point and the loom for damaged wires?
And have you changed the fuses, HT coil + spark plug?
badbill
PostPosted: 22:15 - 08 Jun 2013    Post subject: Reply with quote
this is the jetforce c-tech it just had new piston & rings ,gaskets,plug air filter compression test and a manual choke and still having problems starting from cold that why i have just bought the new starter, relay & battery to see if it would turn it over quicker to help it fire but they are doing the same as the old ones the starter is turning but not quick enough for it to engage the engine have checked the starter gear all fine does the regulater rectifier have anything to do with starter motor power supply and thanks for your help
badbill
PostPosted: 19:00 - 10 Jun 2013    Post subject: Reply with quote
hi all found the problem is was the earth wire from starter motor which had burnt out now it been replaced works fine Smile Smile Smile now having a rebore as just done a compression test myself and only getting 60psi so fingers cross my starting probs will be gone
The last post was made 13 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 47.69 Kb
