Keeping tyre pressure after pumping.
Bike Chat Forums Index -> The Cycling Forum
Linux
PostPosted: 04:14 - 11 Jun 2013    Post subject: Keeping tyre pressure after pumping. Reply with quote
I have a pump that fits both presta and shrader valves, that uses a two sided adapter, when I pump my road bike tyres up so say 110psi, I can't get the pump off quick enough and they go down to about 95psi, what pumps are you all using to maintain the pressure when you're finished inflating?
Two wheels are all I need.
J4mes
PostPosted: 06:38 - 11 Jun 2013    Post subject: Reply with quote
Pump them to 125psi and let them drop to 110 while you undo the valve?
PostPosted: 12:32 - 11 Jun 2013    Post subject: Reply with quote
Air shouldn't be coming back out of the valve and even if it does, there should be a check valve in the pump. Where is the air escaping from?
I use a BBB airstorm 160psi track pump. It cost £18 four years ago:
https://www.wigglestatic.com/images/bbb-bfp-22-pump-med.jpg
The last post was made 13 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 35.41 Kb
