battery problems
Dam_buster
PostPosted: 16:04 - 01 Dec 2004    Post subject: battery problems Reply with quote
Right well, i have been having problems with the battery discharging itself and i was told it was the Rectifier.
So i ordered the rectifier had it fit , Had 2 pay £124.99 in total.
I went home thinking the problem had been solved. went inside for dinner , come outside after few hours , attempted to turn moped on, and not much happened a whir and the noise of the starter motor, which gradually got slower, and nothing.
So does anybody no what might be wrong,, sorry for the big paragraph, im in a hurry and trying to type quick
any help will be greatly appreciated
JIM
Yamaha R6 5EB, BMW 328i Touring, BMW 328i Coupe
stryker
PostPosted: 16:41 - 01 Dec 2004    Post subject: Reply with quote
Do you have a multimeter?
Now what?
Dam_buster
PostPosted: 16:45 - 01 Dec 2004    Post subject: Reply with quote
dont no, lol probably not , what does it do?
mchaggis
PostPosted: 16:54 - 01 Dec 2004    Post subject: Reply with quote
It's an electronic device which lets you measure all kinds of electrical parameters such as voltage, current, resistance and other things.
Basically, you can diagnose where the fault lies by the the behaviour of the voltage across the battery when you try to start it.
I'd charge the battery up assuming that it is flat, and try starting it straight off. If the battery still discharges, then I'd complain to the shop as they evidently haven't fixed the problem.
I must not be a troll...
Mmmm, Guinness
PostPosted: 16:57 - 01 Dec 2004    Post subject: Reply with quote
A multimeter measures electrical current, voltage and resistance. You can get a cheap one for a fiver. You will need one if you want to stand any chance of tracking down an electrical fault.
Does it have a spark?
Will it bump/kick start?
If it is 12v try jump starting it.
Dam_buster
PostPosted: 17:12 - 01 Dec 2004    Post subject: Reply with quote
it would kickstart if it worked Sad the gearing is apparently knackered?
130 quid 2 repair
so i cant kick it Sad
i have to keep recharging the battery if i wanna go anywhere, which is silly, and the battery just loses its power,
JIM
PostPosted: 17:16 - 01 Dec 2004    Post subject: Reply with quote
Tried a new battery in it? They don't last forever and this is the time of year when they go duff.
Retro-Man
PostPosted: 20:38 - 01 Dec 2004    Post subject: Reply with quote
multimeter £2.99 in maplins
could simply be that the battery requires a reclamation charge, most modern chargers built within the last 3 years carry out this type of re-charge automatically.
https://domharnessphotography.webs.com
stryker
PostPosted: 11:18 - 03 Dec 2004    Post subject: Reply with quote
Or your bike is not charging said battery. Not really possible to tell without a multimeter.
One question. Are your head lights brighter when the engine is reved when compared to the lights when the engine is off.
Now what?
Dam_buster
PostPosted: 14:20 - 03 Dec 2004    Post subject: Reply with quote
yea they are,.,
doesnt matter now as i took it back 2 the garage who fitted the new rectifier and solved the problem for free
map
Mr Calendar
PostPosted: 14:22 - 03 Dec 2004    Post subject: Reply with quote
Dam_buster wrote:
...solved the problem for free
Which in the end was?
Guest
PostPosted: 15:22 - 03 Dec 2004    Post subject: Reply with quote
They cocked it up but won't admit it? Wink
stryker
PostPosted: 16:11 - 03 Dec 2004    Post subject: Reply with quote
If the lights were brighter with the engine running it does suggest the charging system was working.
Now what?
Dam_buster
PostPosted: 00:31 - 04 Dec 2004    Post subject: Reply with quote
Crying or Very sad i dont get it.!!!! If the garage are saying theres nothing wrong with the battery and its charging perfect then why in the world was it flat when i came out of work today! Mad
this thing is starting to piss me off! and its starting 2 hurt my pocket , alot, might just fix it up and sell the bastard
any ideas on what may be wrong?
GF's dad told me that his kawasaki was having the same sort of problems and he said that it might be the electric ignition (CDI???)
could that be it?
Any help greatly appreciated.
need to get this hunk of junk working as i need transport to work and school Sad
Thanks.....
JiM
PostPosted: 01:03 - 04 Dec 2004    Post subject: Reply with quote
Get your multimeter which by now you will obviously have bought Wink
Set the scale to Volts DC with 12v in the range (usually 0-50v).
Check the voltage accross the terminals of the battery (one lead on positive terminal, one lead on negative), it should be 12v when charged. Now start the bike and check the voltage with the engine running, it should rise to around 14v when revved a little. If this happens your charging system is working.
Now check for an earth leak. Set the multimeter to milliamps. With the ignition OFF, disconnect the positive terminal from the battery and measure the current THROUGH this cable (so one lead on the battery positive and the other on the wire that normally connects there. DO NOT measure between the two terminals of the battery or switch on the ignition or you will fry the meter) Any reading into the 100s of milliamps suggests a resting current leak so either something is staying on somewhere or there is a partial short circuit which is discharging your battery.
Clean the top of the battery with deionised water then dry it and spray a light misting of WD40, I have heard of salty condensation on the top of batteries causing them to discharge at this time of year.
If this checks out OK, I would just replace the battery, they are not all that expensive. In my experience they can go so they will take a charge but not hold it for long. The battery on a scoot with an electric foot takes a hammering, a cheap one could easily be knackered within 18 months.
spacecowboy
PostPosted: 01:58 - 04 Dec 2004    Post subject: Battery Reply with quote
As Stinkwheel says, his checks will show you if the charging system is working, or if anything is shorting the battery. If you find it needs a new battery, an 'Optimate' or similar charger is a great investment.
Just remember even with that, a battery still has a finite life.
Thats why they don't have a very long guarantee.
the Space Cowboy.
'Death is just natures way of telling you to slow down - Grouch Marx'
Dam_buster
PostPosted: 02:01 - 04 Dec 2004    Post subject: Reply with quote
ok guys ill get a multimeter asap and do the things u have suggested This is a lot of help.
Cheers guys and gals!
JIM
The last post was made 21 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 95.94 Kb
