Riding With No Hands
bren_9311
PostPosted: 13:06 - 14 Jun 2013    Post subject: Riding With No Hands Reply with quote
I was riding to work this morning and i had to sort my zip on my jacket so i let go of the handle bars and they started to wobble like crazy, it stopped immediately, when i put my hands back on.
I know its not normal so what could be cause? Something worn, need replacing ?
Cheers Brendan
My opinion is neither copyrighted nor trademarked. If you like, I'll trade for one of yours.
Currently bikeless. Sad
Ps4- bren_9311
Nexus Icon
PostPosted: 13:09 - 14 Jun 2013    Post subject: Reply with quote
Worn head bearings?
Lost bar-end weight?
Soft tyre?
Those would be the first three suspects..
Greetings from Shitsville!
MarkJ
PostPosted: 13:44 - 14 Jun 2013    Post subject: Reply with quote
What Nexus said, also possibly wheel bearings or wheel weights.
I had it before where just changing the front tyre cured the wobble.
PostPosted: 13:46 - 14 Jun 2013    Post subject: Reply with quote
Have your forks been leaking recently, have you dropped your bike?
All 3 listed by Nexus are fine on my bike and it wobbles like an epileptic at a rave. Laughing Not saying it can't be those though Thumbs Up
alun111
PostPosted: 13:54 - 14 Jun 2013    Post subject: Reply with quote
A squared-off rear tyre, or a topbox used to do it to my hornet 600.
Acemastr
PostPosted: 14:07 - 14 Jun 2013    Post subject: Reply with quote
Just to add, I do this all the time and it doesn't wobble at all Smile also great fun getting it round corners without touching the bars
2016 Toyota Tacoma Limited
bren_9311
PostPosted: 14:57 - 14 Jun 2013    Post subject: Reply with quote
It didn't do it until I fitted a top box. So I'm going to check. Without the box fitted.
And the check everything else. Also I'm of on a 400 mile trip what should I check before setting off?
Ps4- bren_9311
PostPosted: 15:01 - 14 Jun 2013    Post subject: Reply with quote
Tyres, brakes and lights.
Oil if you haven't bothered Wink
Snorty
PostPosted: 15:07 - 14 Jun 2013    Post subject: Reply with quote
Steering head bearings. Get the front wheel off the ground somehow and turn your handlebars left to right. See if they have a bit they "stick" on.
That's what caused it on my old bike.
bren_9311
PostPosted: 15:32 - 14 Jun 2013    Post subject: Reply with quote
Oil checked, Lights, brakes all work.
I have gone for a quick ride to asda to get my lunch and its has stopped, since i took the top box off, its a 58 liter to box so it pretty wide.
Ps4- bren_9311
sidewinder
PostPosted: 16:24 - 14 Jun 2013    Post subject: Re: Riding With No Hands Reply with quote
Cheers Brendan
It's not a divvy is it ?
bren_9311
PostPosted: 17:10 - 14 Jun 2013    Post subject: Re: Riding With No Hands Reply with quote
Cheers Brendan
Yeah 1993 model. ?
Ps4- bren_9311
Derivative
PostPosted: 17:25 - 14 Jun 2013    Post subject: Reply with quote
My top box causes this on the CB at 40mph (fine below 35 or above 45-50).
There is a tiny bit of wobble without the box. With it, you can't let go at 40.
Skudd
PostPosted: 17:29 - 14 Jun 2013    Post subject: Reply with quote
Same with my Varadero 1000,although my rear shock is knackered now and this too causes a head wobble.
sidewinder
PostPosted: 17:41 - 14 Jun 2013    Post subject: Re: Riding With No Hands Reply with quote
Cheers Brendan[/quote]
It's not a divvy is it ?[/quote]
Yeah 1993 model. ?[/quote]
https://www.bikechatforums.com/viewtopic.php?p=3596985&highlight=#3596985
keggyhander
PostPosted: 18:08 - 14 Jun 2013    Post subject: Reply with quote
Most likely wheel imbalance.
Mine used to wobble like mad until I removed the wheel weights and put DynaBeads in the tyres. Now it tracks like it's on rails when I ride no-handed.
Riding no-handed down Slack Hill with nothing but a dab of back brake is hilarious.
PostPosted: 18:11 - 14 Jun 2013    Post subject: Reply with quote
I think you'll find it's most likely the top box, since it's stopped doing it since the OP removed it. Wink
BigDan1190
PostPosted: 18:12 - 14 Jun 2013    Post subject: Reply with quote
Of all the things above, it is most likely tyre wear, or low PSI.
bren_9311
PostPosted: 18:13 - 14 Jun 2013    Post subject: Re: Riding With No Hands Reply with quote
https://www.bikechatforums.com/viewtopic.php?p=3596985&highlight=#3596985[/quote]
checked the folks out they seem ok, I'm at work until tomorrow=, so i will take a proper look tomorrow. Thumbs Up
Ps4- bren_9311
Alpha-9
PostPosted: 18:16 - 14 Jun 2013    Post subject: Reply with quote
Tyres, my 97 xj600 does the same as does a few other people's, is normal, trick is to keep your hands on the bar when decellerating Wink
Although I do enjoy braking to a halt no handed and grabbing the clutch at the last second Razz
Check tyre pressures.
Fzr-600 1999
PostPosted: 18:21 - 14 Jun 2013    Post subject: Reply with quote
A worn, but not necessarily illegal BT45 on the front will cause this kind of behaviour.
Alpha-9
PostPosted: 18:23 - 14 Jun 2013    Post subject: Reply with quote
Heh heh heh
how did he know Shifty
Fzr-600 1999
Skudd
PostPosted: 18:39 - 14 Jun 2013    Post subject: Reply with quote
How do they work?
Saw the web site for sales.
https://www.dynabeads.co.uk/autobike.php
The last post was made 13 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 128.63 Kb
