Exhaust wrapping....Why?
Ariel Badger
PostPosted: 21:30 - 15 Jun 2013    Post subject: Exhaust wrapping....Why? Reply with quote
I can see the point on a car with an enclosed engine bay but not on a bike. A two stroke maybe but on a 4T I see no point other than fashion. Please explain how this modification gains any advantage/power.
Lone-Wolf
PostPosted: 21:41 - 15 Jun 2013    Post subject: Reply with quote
Wotcha.
On my B31 and my Bullet the downpipe is lagged - nothing to do with power gain or anything similar . . . . it's just that the chrome had gone on both pipes and I wasn't ready to spend money on something shiny. OK - I don't mind spending more for stainless - the B33 has a full stainless system.
On the Ford trike the first few feet of exhaust is lagged purely to keep the starter motor wires from getting too hot . . . . the VW has a full stainless system.
Cheers.
L.W. - www.moonshiners.org.uk
Nexus Icon
PostPosted: 21:45 - 15 Jun 2013    Post subject: Reply with quote
As far as I know it works best on turbocharged systems on cars to lower ambient temps under the bonnet but I can't see any reason, other than cosmetic, for it on a bike.
Greetings from Shitsville!
cg125erinit
To make a total minger in to something edgy and 'cool'. I use it on a cg header I cut myself to hide the horrific pitting/scratches. I don't understand why everyone hates it personally. I think it looks old skool and kinda neat on old bikes or cafes.
Islander
PostPosted: 21:50 - 15 Jun 2013    Post subject: Reply with quote
Except for the fact that 'old school' bikes inevitably had shiny chrome exhausts...
Each to their own I suppose.
-Matt-
PostPosted: 22:47 - 15 Jun 2013    Post subject: Reply with quote
The wrap deflect solar rays, which bounce off the bikes frame, resulting in solar-charging of the entire engine. This typically gives an extra 5bhp, and also 10mpg on average.
Or the fact wrap can look better than a rusty-titanic of an exhaust.
Other than that - who knows Mr. Green
PostPosted: 00:08 - 16 Jun 2013    Post subject: Reply with quote
There's a very good reason, though it's effectiveness in real terms is dubious on all but long headers. Turbochargers are driven not by simple exhaust gas volume but by the heat energy contained within the exhaust gas. Any heat lost from the header is less to drive the turbo.
TheSmiler
PostPosted: 05:33 - 16 Jun 2013    Post subject: Reply with quote
It makes uncool bikes look cool for example this CX500 Cool
https://i.imgur.com/3HKcVvF.jpg
PostPosted: 08:03 - 16 Jun 2013    Post subject: Reply with quote
I used it to cover up some ropey welds and make my pipe look a bit fatter (matron). Rusted the hell out of the zorst though.
Marmalade
PostPosted: 08:07 - 16 Jun 2013    Post subject: Reply with quote
[quote="TheSmiler"]It makes uncool bikes look cool for example this CX500 Cool
For me, this cx looks shit, but that's my individual taste.
stoke-gaz
PostPosted: 08:16 - 16 Jun 2013    Post subject: Reply with quote
To stop my exhaust ruining another pair of textile jeans.
Within an hour of picking up my new bike 8 ish weeks ago I'd managed to burn a hole through my textiles. Black wrap is going on at the end of the month.
Gaz.
Ex: GZ125HS, Current: Yamaha xv535 virago, Suzuki GSF600.
CBT: passed 30/09/2012 Theory: passed 02/02/2013 MOD 1: 27/03/2013 MOD 2: 18/04/2013.......CAT A LICENCE IS MINE!!!!
dansp1
PostPosted: 08:23 - 16 Jun 2013    Post subject: Reply with quote
Exhaust extractive inertia is the answer, it can in some instances give a marginal improvement in performance
I have the downpipes wrapped on my SP1 because i have relocated electrics very close to the engine and don't want to cook them too much!
stevo as b4
PostPosted: 10:37 - 16 Jun 2013    Post subject: Reply with quote
I'm not really a fan of exhaust heat wrap TBH, but on a 2stroke engine in some situations I can see the logic why you might want it for a couple of reasons.
On a 4stroke, unless it's done to protect electrics, plastics or keep heat away from the fuel tank or rider's leg I see no point. Old Café racer's look best with matt black exhaust headers and always will!
I've actually got some heat wrap on the screamer pipe on my car. The problem is that it wasn't wrapped all the way down, and it almost touches a radiator hose. I don't know if when I fit my new red coolant hoses if I should extend the wrap further down the exhaust gas exit pipe, or if I should wrap a bit of heat reflective foil tape around the coolant hose in this area?
Or am I right in thinking that If I keep driving like a pussy that the screamer pipe will never get hot enough to burn anything? Laughing
Walloper
PostPosted: 11:08 - 16 Jun 2013    Post subject: Reply with quote
It is purely insulating the heat in the exhaust gas from escaping to the atmosphere.
Some cnuts think it looks the Dog's Bollcoks/Cat's Pyjamas, some think it is boosting power.
It does two main practical things.
1) Insulates fleshy bits from hot melty bits.
2) As pits says, insulates the heat energy in the exhaustg gas from escaping to atmosphere before doing it's intended work of pushing the turbine of a turbocharger around.
It is 'purely' the heat energy of exhaust gas that we use in a turbocharged engine. The 'mechanical' effort of the engine 'pumping' gas through actually uses energy. But since there is so much heat energy going to waste in in exhaust gas it can be harnessed and used to 'supercharge' the inlet with oxygen rich air at above atmospheric pressure. And allow a T-charged engine to put out 200% Horsepower. Normally aspirated 100BHP T-charged (and aftercooled) 200BHP. Waste gates are fitted to reduce the increases exhaust gas energy that a turbo helps produce. Unlimited a turbo will blow (no pun) an engine to pieces. Or push a metal leg out the bed.
stevo as b4
PostPosted: 11:24 - 16 Jun 2013    Post subject: Reply with quote
Walloper, are some of the Big Diesel's you work around, using free floating turbochargers?
We have various sized Gen sets for back up power at work, most of them are real old things, but they don't get much use unless there's a powercut for several hours. Some of the bigger straight 6 or V8 engines are turbocharged and most of the turbo's I've seen on our 1500rpm engines are always free floating.
I understand why you could never make a free floating system work properly on a high revving petrol engine though!
dansp1
PostPosted: 13:09 - 16 Jun 2013    Post subject: Reply with quote
Hot gases flow better, this improves the exhaust extractive inertia, on some engines (even normally aspirated ) it can give a small increase in power.
Walloper
PostPosted: 15:43 - 16 Jun 2013    Post subject: Reply with quote
We use Caterpillar 3500 series engine now land and off-shore. We eventualy moved away from the old 398/9 V12-V16 as the 3500 ave electronic fuel control meaning faster response/less droop when asked to work (by the muppet with the Big Slipper who's on the brake). The cat turbo floats on an oil film as the shaft hardly touches meal to metal do to the centrifugal/gyro which keeps it central. The oil really only cools things and provides lube for start-up and stopping when oil pressure is low. So I would guess 'Floating' would be the description.
Another very important use for lagging the exhaust is to reduce engine room temperatures. Hot exhausts will heat the air the engines breath, hot air has less oxygen.
On marine application turbos and manifolds can be cooled either by engine coolant (Jacket water) or from the sea/river/lake (Raw Water). Engine cooled by Raw water can have much higher performance than jacket water cooled. The two systems can be used on exactly the same engines but with diferent fuel settings. More oxygen mean you can burn more fuel. Burn more fuel means more power. More power means you can have better ladies. Cool
Edit: Apparently, as evidenced in my recent posts, it looks as though I have finally gone 'Full Retard'.
This is not so. My work's PC has a Retarded Keyboard and I am but a victim of its inadequacies. Embarassed
Alpha-9
PostPosted: 15:50 - 16 Jun 2013    Post subject: Reply with quote
I was gonna put a bit on mine to stop them rattling against each other, pretty sure that's what's happening, overlapping new downpipes the previous owner put on, making some funky sounds, but that's about it
Doesn't it get wet and rot the exhaust?
Fzr-600 1999
lihp
PostPosted: 18:17 - 16 Jun 2013    Post subject: Reply with quote
There have always been used to keep exhaust gas temperatures up by stopping it radiating to the atmosphere.
However, is it really necessary with modern materials?
defblade
PostPosted: 18:38 - 16 Jun 2013    Post subject: Reply with quote
That's why I wrapped the end of my standard can. Kept burning my hand putting the chain through. Then I got a smaller can with a carbon tip which doesn't get hot instead Smile
PostPosted: 19:45 - 16 Jun 2013    Post subject: Reply with quote
Gives a fuck all increase in power on a motorcycle, or all the race lads/moto gp would be using it.
Useful to keep the skins on your legs from melting to the exhaust, or rusting your headers through. That's about it.
dansp1
PostPosted: 20:10 - 16 Jun 2013    Post subject: Reply with quote
Modern race engines tend to use ceramic coatings which achieve
the same thing
PostPosted: 20:12 - 16 Jun 2013    Post subject: Reply with quote
the same thing
Show me a ceramic coating on the headers of any current race bike. Thumbs Up
Last time I looked they were running naked Titanium.
Ariel Badger
PostPosted: 20:28 - 16 Jun 2013    Post subject: Reply with quote
Thank you for the replies, this started in the pub last night. My argument was that it made some sense in an enclosed space like a car engine compartment, to keep the energy in the pipe for a turbo or on a 2T. On a normally aspirated four stroke it is just pure vanity. I thought my mate was going to thump me Very Happy
lihp
PostPosted: 23:50 - 16 Jun 2013    Post subject: Reply with quote
Most GP bikes run steel exhausts as Titanium makes the bike too light, so most teams use Steel exhausts rather than run with Ballast
The last post was made 12 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.09 - MySQL Queries: 15 - Page Size: 131.67 Kb
