XR400 lost compression after rain
noodnurd
PostPosted: 06:04 - 19 Jun 2013    Post subject: XR400 lost compression after rain Reply with quote
Hello. I have a 2001 model XR400 which is (was) in very good condition; never flogged, well maintained, premium fuel, etc.
I recently left the bike out in the rain for 2 nights in a row. Not normal behavior however circumstances couldn't prevent it. After this, I can no longer start the bike.
The strange thing about this is that I seem to have lost almost all compression. A couple of days ago it was perfect; nice and stiff and easy to start. Now I can kick through freely as if there's no plug installed... The bike had been sitting all afternoon before the rain began and wasn't hot at all, so nothing should have cracked.
It's possible there's still some water in it although I can't see how that could affect the compression.
Any advice or tips very welcome!
https://s24.postimg.org/79c8so3o1/20130619_123950_Medium.jpg
https://s24.postimg.org/pmcu38e4x/20130619_124030_Medium.jpg
https://s24.postimg.org/olcle3x5d/20130619_124042_Medium.jpg
Ariel Badger
PostPosted: 06:44 - 19 Jun 2013    Post subject: Reply with quote
Could it be that you have compression but water has got into the clutch causing it to slip?
robstat
PostPosted: 06:58 - 19 Jun 2013    Post subject: Reply with quote
It's nothing to do with the clutch it would still kick over properly, if you took the clutch out you would just get no drive also I doubt it's anything to do with the rain, it could be a few things assuming the plug is still there it's probably a valve stuck open.
PostPosted: 07:01 - 19 Jun 2013    Post subject: Reply with quote
I cannot kickstart my little bike if the clutch is not working as it should. Could be the same in this case.
doggone
Will there be a decompression thing on these to help it start turning?
How does it engage/disengage
noodnurd
PostPosted: 07:05 - 19 Jun 2013    Post subject: Reply with quote
A small lever above the clutch controls compression in the XR400. If I pull this in I get even less resistance so there is *some* compression but nothing like a couple of days ago.
Note that the bike has not been tampered with as it's been with me, just unused.
noodnurd
PostPosted: 07:10 - 19 Jun 2013    Post subject: Reply with quote
I don't think it's the clutch. I rolled it down a hill and released the clutch in 2nd. The engine turned over a good 15 or so times but no sign of ignition at all. Clutch didn't slip - it's only a week old!
I'm guessing it's electrical but hell, a bit of rain shouldn't bother that.. Why is it that I can ride through creeks and do 4 hours enduro in the Cambodian monsoons without issue, but if I park the bloody thing in the rain it can't handle it?!
robstat
Maybe not on your engine but gearbox/clutch is on the other side of the crank (think pre unit) and has no affect on compression unless there is some kind of safety built in to the clutch so you can't start it in gear, but that only takes away the spark and not compression.
Thinking back on the lines of valves as someone else has said it could be your de-compression lever (valve lifter) stuck.
noodnurd
PostPosted: 07:15 - 19 Jun 2013    Post subject: Reply with quote
Note this photo:
https://postimg.org/image/sini87ubx/
The cable going into the alternator/dynamo was wet upon inspection. The sheath also contained some water. It's possible that water seeped in here and got the dynamo wet, preventing it from functioning. But now I'm just stabbing in the dark.
Update: If I kick it over and hold in the horn button I get sound from the horn, so there's definitely power going through it.
PostPosted: 07:29 - 19 Jun 2013    Post subject: Reply with quote
I hate to say it... but if you can feel the engine turning over in gear whilst rolling on a hill, I reckon it is safe to say that something has failed and the engine needs to be looked at. I couldn't bump my big single in 5th, it just locked the wheel
noodnurd
PostPosted: 07:36 - 19 Jun 2013    Post subject: Reply with quote
The other side to the issue is that I live in Cambodia and all the mechanics in my area look like this:
https://s14.postimg.org/5g1y6vnwd/5960585_Cambodian_mechanic_and_gas_station_0.jpg
I do most of the work myself for obvious reasons. A visit to a 'real' mechanic would be very time-consuming...
Any more advice on what I could do to diagnose further?
iooi
PostPosted: 20:08 - 19 Jun 2013    Post subject: Reply with quote
Spark plug out.
Place Something in the hole. So that hits the top of the piston and SLOWLY push the kickstart down and see what happens.
Or place finger over hole.
Cam cover off and check valves are moving as they should.
Quote Me Happy
PostPosted: 20:18 - 19 Jun 2013    Post subject: Reply with quote
I'd be focusing on the auto decompression system. Have you checked it's working and the cable is adjusted OK?
Fizzer Thou
PostPosted: 22:23 - 19 Jun 2013    Post subject: Reply with quote
I would go with what Joe has said.If you disconnect the decompression cable that connects to the handlebar lever,you should get full compression back.
It sounds as though the cable has seized up,causing the right hand exhaust valve to stick open slightly.Hopefully it has not bent that valve if it was held open too far.
Always have a 'Plan B'
kartl
PostPosted: 00:29 - 20 Jun 2013    Post subject: Reply with quote
Compression test would be the best thing to do to check your engine compression. Im guessing that the may be really out due to internal damage. Or it could be a head/block leak.
The last post was made 13 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.06 - MySQL Queries: 13 - Page Size: 83.64 Kb
