Why are Chinese bikes slower?
flumpy7
PostPosted: 18:11 - 19 Jun 2013    Post subject: Why are Chinese bikes slower? Reply with quote
So I've just bought myself an immaculate 2012 sinnis apache 125 to pop to work and back.
Doesn't seem to be the usual sub-standard Chinese stuff; chunky, decent quality fixings, nice plastics, polished alloy swingarm, discs on rear as well as front as seem to be pretty tough, nice alloy wheels and spokes. All together pleasantly surprised.
Anyhow....it'll only reach 55-60mph max, which is fine for my needs, but I was just wondering why.
I don't mean the usual 'cause its Chinese shit' comments, but i''m genuinely interested in the mechanical reasons why these replica engines cant match the speed of the original designs. I mean the apache is based on the GN125/DR125 motor. These could apparently reach 70mph and 75mph respectively so why cant the Chinese version? I believe the same is true of the myriad of cg125 copies.
2012 Sinnis apache
callum94
PostPosted: 18:19 - 19 Jun 2013    Post subject: Reply with quote
It could be due to the gearing, since every Chinese motorcycle I've owned hit 60mph@10000rpm in the highest gear (until I changed the sprockets then it would pull 60+ according to speedo)
I embarrassed a YZF-125 on my Sukida, I saw one pull up to me at a set of lights and when the lights turned green we went for it lol. He was hitting the rev limiter in every gear and I was still right next to him, the look on his face at the next set of lights Shocked
I want to race a YZF-R125 on my Honda since compared to the Sukida it gets to 60mph 6-7 second faster.
Current: CBR 125R 2012 (Black)
Restricted licence (33hp): 09/12/12
stevo as b4
PostPosted: 18:35 - 19 Jun 2013    Post subject: Reply with quote
A lot of them seem to use cheap copy Mikuni/Keihin style slide carbs. I would be quite surprised if any of the air cooled 125cc singles based on the Honda or Suzuki OHC designs make 10bhp or more. Some of the original Japanese engines were closer to 12bhp after the the 1982 law's.
Even those Chinese copy engines based on the Honda CB125T don't seem to make much power, and some even have twin carbs. I suspect that they are built with cheaper lower quality parts and ancillaries generally, and not to Japanese standards of quality control.
Carvel
PostPosted: 18:46 - 19 Jun 2013    Post subject: Reply with quote
That is not something to be proud of
Sable
PostPosted: 18:48 - 19 Jun 2013    Post subject: Reply with quote
The Apache 'should' have a top speed of 65-70. Check your speedos accurate (heard of another Sinnis with a wonky speedo, fixed by warranty).
Trackstar is meant to be the slowest in the range and can manage 65mph. Thumbs Up
callum94
PostPosted: 18:50 - 19 Jun 2013    Post subject: Reply with quote
It is if it's Chinese and has less than 9hp.
Nexus Icon
PostPosted: 19:05 - 19 Jun 2013    Post subject: Reply with quote
Cheap carbs and, possibly, sloppier machining tolerances within the engine.
The predominant reason GP bikes and F1 cars can produce huge power figures without huge displacement engines is the ultra-fine tolerances and balancing within the units themselves. These give lower mechanical losses and the ability to rev higher.
It stands to reason therefore that poor machining of engine internals will result in lower power figures.
That and cheap carbs. Wink
Greetings from Shitsville!
Derivative
PostPosted: 19:12 - 19 Jun 2013    Post subject: Reply with quote
GN125 70mph?
Yeah, okay.
I don't know of any four-stroke 125cc motors that do 70. Maybe the Varadero, but that's a twin.
The CG doesn't do 70. No chance.
edited later: learner legals, the Superdream could probably manage it
flumpy7
PostPosted: 19:20 - 19 Jun 2013    Post subject: Reply with quote
Derivative wrote:
GN125 70mph?
Yeah, okay.
Never ridden the CG admittedly but I started my motorcycling life on an old cb100. That would hit 65-70 on a long enough stretch of road. Most googled specs for the dr125 and gn125 state 70mph.
2012 Sinnis apache
Sable
PostPosted: 19:22 - 19 Jun 2013    Post subject: Reply with quote
I reckon the modern sporty ones can do 70.
passifid
PostPosted: 19:27 - 19 Jun 2013    Post subject: Reply with quote
Derivative wrote:
GN125 70mph?
i'd put money a yzf r125 can doa real satalitte tracked 70, and i would happily provide a satilite track too. in fact i already have one. it will max at around 74-76 on flat, i know it not fast but it can do 70 without too much issue on flat
CBT: 10/2011 | Theory:6/2012 | MOD1: 8/2012
Derivative
PostPosted: 19:30 - 19 Jun 2013    Post subject: Reply with quote
passifid wrote:
Derivative wrote:
GN125 70mph?
Right, so basically the fastest learner legal can just about manage it.
I think '55-60' is a fair description of a CG125, it sounds like the chinese bikes are basically equivalent.
ocatoro
PostPosted: 19:36 - 19 Jun 2013    Post subject: Reply with quote
so it hurts less when it falls apart Thumbs Up
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
flumpy7
PostPosted: 19:39 - 19 Jun 2013    Post subject: Reply with quote
I think a lot of people don't get the most out of 125's cause they don't rev them high enough and change gear too early. Although agreed, 4 stroke 125's are still seriously slow but then....you hopefully didn't buy it for speed.
2012 Sinnis apache
callum94
PostPosted: 19:44 - 19 Jun 2013    Post subject: Reply with quote
The fastest (4 stroke) is the new model CBR125R Wink
https://s2.postimg.org/dm6vkz1px/image.jpg
Timmeh
PostPosted: 20:01 - 19 Jun 2013    Post subject: Reply with quote
Loving the cable routing for the throttle. Way to not go Honda.
All 4T 125s are teh slow, but that's good for people who are still learning.
passifid
PostPosted: 20:06 - 19 Jun 2013    Post subject: Reply with quote
fastest 125 4t is still the vadero
followed probably by the yzf in common bikes as it has 1.2 whole kw(or about 1.6 hp) more which is about 12.5%
again its like argueing the heaviest fly, once they can manage 70 thats all i care about for a 125 speed wise
Lord Percy
PostPosted: 20:10 - 19 Jun 2013    Post subject: Reply with quote
My GN125 was pushed very hard to hit 65. I mean, it was really pushed. A more typical speed was 50.
callum94
PostPosted: 20:13 - 19 Jun 2013    Post subject: Reply with quote
passifid wrote:
fastest 125 4t is still the Varadero.
I agree if the riders were the same weight.
But I would give any 4 stroke 125cc a race, mind you I'm only 9.5st so all bikes have been faster for me. Hit 60mph in under 10 seconds on about 2% incline the other day.
passifid
PostPosted: 20:19 - 19 Jun 2013    Post subject: Reply with quote
i thought we were talking about fastest bikes not fstest bike + rider combos because my mate comes in at around 7 stone and he would probably beat most people riding a 125 on an aubergine
callum94
PostPosted: 20:21 - 19 Jun 2013    Post subject: Reply with quote
Lol is he anorexic or 12? I'm only 5'6 and I have no fat at all.
-Monty-
PostPosted: 20:26 - 19 Jun 2013    Post subject: Reply with quote
This has got to be the best brag on BCF ever.
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
passifid
PostPosted: 20:28 - 19 Jun 2013    Post subject: Reply with quote
doesn't eat only really smokes and is about your hieght, and a very slim build anyhow, i have a 5 11 mate who is 9 st 3, he looks thin but not anorexic, but he has a womans build
TheSmiler
PostPosted: 22:10 - 19 Jun 2013    Post subject: Reply with quote
Derivative wrote:
GN125 70mph?
Yeah, okay.
You do know that the Superdream is legal to ride on a CBT don't you Laughing
The last post was made 13 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 129.93 Kb
