Temp gauge problem
5212justin
PostPosted: 21:58 - 19 Jun 2013    Post subject: Temp gauge problem Reply with quote
As soon as i turn the ignition on, on my bike the temp gauge needle shoots right up to the maximum and i have no idea why does anyone know what could cause this please? thank you
bladerunner
PostPosted: 22:20 - 19 Jun 2013    Post subject: Reply with quote
Disconnect the wire from your temperature sender. If that stops it going off the scale then it's a sender issue...if it still shows full scale deflection then you may have a frayed/ trapped part of that wire which is earthing out
5212justin
PostPosted: 22:23 - 19 Jun 2013    Post subject: Reply with quote
well my dad disconnected a lead/wire from what i think was the head? and the gauge went down and then when he connected it back on it went straight back up so which part do i need? the bit that screws into the head? thanks
Islander
PostPosted: 22:25 - 19 Jun 2013    Post subject: Reply with quote
Yep, sounds like a faulty temperature sensor. Shouldn't be too hard to replace. Thumbs Up
5212justin
PostPosted: 23:25 - 19 Jun 2013    Post subject: Reply with quote
cool thank you. If i tell you its a 1990 honda ns125r-k do you retract your comment about hard to replace?? ha
kartl
PostPosted: 00:31 - 20 Jun 2013    Post subject: Reply with quote
I believe its not that hard to find due to some of its parts are shared with other later or newer model bikes.
5212justin
PostPosted: 00:34 - 20 Jun 2013    Post subject: Reply with quote
Oh right thats good to know is there anyone that can point me in the right direction as to which other bike I could get one from? Thanks
The last post was made 13 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 55.42 Kb
