| Mikey7094 |
 Mikey7094 Two Stroke Sniffer
| Nemo |
 Nemo Could Be A Chat Bot
| Walloper |
 Walloper Super Spammer
| Old Git Racing |
 Old Git Racing World Chat Champion
| Mikey7094 |
| lukamon |
 lukamon World Chat Champion
| Mikey7094 |
| Old Git Racing |
| Walloper |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 10:17 - 21 Jun 2013 Post subject: |
first of all make sure you are not swapping components from chinese copy engines , as the bore x stroke is different , and other bits .
If in doubt after measuring , then start with a new / rebored piston and barrel . Be wary of mixing early 6v cg parts with type 2 brazil and later . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Mikey7094 |
 Posted: 17:30 - 21 Jun 2013 Post subject: |
Thanks for your responses.
I've had a look at the cylinder (without micrometer as of yet), and if anything it seems to be too tight, like there is a small amount of resistance in the cylinder. So my latest theory is... Maybe my machine shop man didn't bore it out enough? Is this likely? I've taken some photos, which can be found here (if the link works):
Piston and cylinder photos
(The photos might be a bit big - please tell me if they won't load.)
The first photo is my +0.25mm piston in its rebored cylinder, and there is negligible visible gap between the piston skirt and cylinder wall - I can't even fit my smallest (0.04mm) feeler gauge in there. The second photo is a spare cylinder I have, which hasn't been rebored and I don't know its mileage although I think it's within the wear limits. There is more of a gap between the skirt and cylinder, which is hopefully visible in the photo - the next photo shows a 0.04mm feeler gauge in the gap. This piston moves more freely in the bore.
So maybe the rebored cylinder is too tight, and it's causing the con rod to push/pull too hard, making the piston rock back and forth... Does this sound plausible?!
I also noticed that my oversize piston (which was a genuine one from David Silver Spares) has two fewer holes in the side than the spare, standard size piston (last two photos). To anyone who happens to have a complete encyclopaedic knowledge of CG engines, Is this normal and would it significantly affect lubrication?
Is there anything else that can affect lubrication and/or oil pressure?
Thanks
Mike |
| Old Git Racing |
| Mikey7094 |
 Posted: 14:35 - 22 Jun 2013 Post subject: |
I've measured the ring end gaps - to my nearest feeler gauge, they are 0.2mm, although one seems slightly smaller than the other, so maybe 0.15mm. The Haynes manual says the end gap should be 0.15 - 0.35mm, so I guess this is OK.
However it does say that the piston skirt outer diameter should be 56.45 - 56.48mm, while the cylinder bore diameter should be 56.50 - 56.51mm, suggesting the clearance between skirt and bore should be somewhere between 0.02 and 0.06mm. (The wear limit is a clearance of 0.25mm.) The fact that I can't fit a 0.04mm feeler gauge in the gap suggests is might be too tight.
I'll try and track down some micrometers and measure it properly.
Also, regarding fitting the piston rings, there are two compression rings, one with a tapered edge and one with a square edge. The manual says the square-edge one should go at the top, with the tapered-edge one underneath, but in the pictures they look like they've done it the other way round.
Does anyone know which way round is correct, or whether it makes any difference?
Mike |
| unitynotsocri... |
 Posted: 21:48 - 22 Jun 2013 Post subject: |
it looks wrong ,try and check it for ovality , or the piston may be origionally mishapen .looking at the sht on the piston top it looks like its been eating oil and the scuff marks on the skirt are a bit ott for a rebored barrell / piston . In all fairness it could have seized / warped while being run in . If I ever use a rebore on an engine I always redo the valve guides and seals / valves . Reboring an old engine and not doing the head can leave the engine very vunerable to heat / compression and power loss issues making it more likely to sieze when running in .
Remember the pistons are alloy , and easily melted / distorted , as many bcf'r 2 t sniffers may tell you . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 13 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
