Clutch doesn't release properly.
G19RKE
PostPosted: 22:14 - 21 Jun 2013    Post subject: Clutch doesn't release properly. Reply with quote
Picking your brains again.
It's an Aprilia rs 125 2000 reg.
The bike starts fine and ticks over nicely and actually rides fie once its moving. I fitted a new clutch cable and removed the clutch basket and everything looked fine and had plenty of life left in it. I have adjusted the clutch basket inside the casing too But it still won't release fully. When i fitted the new clutch cable i had to wind out the adjuster on the clutch lever just to take up the slack. Even with the clutch pulled all the way in the bike is still trying to roll forwards so I end up pulling the brake to stop it and then it cuts out if I don't keep the revs up.
This is making this otherwise enjoyable bike of mine quite annoying to ride when I come to junctions as I'm stalling it 8/10 times. Lol
andy_uk
PostPosted: 22:42 - 21 Jun 2013    Post subject: Reply with quote
The do drag a bit when cold...
Are you using the right grade gearbox oil? (75w90)
PostPosted: 22:45 - 21 Jun 2013    Post subject: Reply with quote
10w40 works fine in them.
They shouldn't drag when cold.
Did you adjust the actual adjuster on the clutch side first. Set the lever so it has no adjustment at all, so all the way in.
Adjust the engine end so you feel some resistance, then back off 1/4 turn. Lock it and then adjust the free play at the lever end.
G19RKE
PostPosted: 22:53 - 21 Jun 2013    Post subject: Reply with quote
Surely it shouldn't drag at all when the clutch Is pulled in. An yes I fitted new cable with adjuster all the way In on the lever and adjusted the clutch at engine end and locked off but engine end is almost at max adjustment now and so is adjuster on lever. Is it time for a new clutch?
G19RKE
PostPosted: 22:55 - 21 Jun 2013    Post subject: Reply with quote
Can't remember what oil it was exactly but it was putoline gearbox oil which was purchased based on the Haynes manual I have for the bike so that cannot be the issue.
R1stu
Shrek!
PostPosted: 22:59 - 21 Jun 2013    Post subject: Reply with quote
Ive got the exact same problem with the ninja. fitted a brand new cable and the adjuster is on last thread both clutch and lever end.
but it still clunks into gear and lever is almost on bar before disengaged enough.
Is that worn plates? the push rod bit is was past center.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
G19RKE
PostPosted: 23:41 - 21 Jun 2013    Post subject: Reply with quote
I thought it could be the plates worn also but it was fine when I removed them to check. It may b the issue with yours if you have put a groove in them but mine were fine so i refitted them back to the bike. I'm thinking of changing the whole lot now though in hind sight.
The last post was made 12 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 51.86 Kb
