how to replace brake fluid, bike stored for years?
jordey
PostPosted: 22:40 - 21 Jun 2013    Post subject: how to replace brake fluid, bike stored for years? Reply with quote
okay so my tzr 125 has been dry stored for years. i tried filling the rear reservoir up with brake fluid, pressing the pedal, and opening the bleed screw to let it all come through. now though, the rear brake is very stiff, and its difficult to turn the wheel. the pads also barely move when i try and press the pedal which is also stiff. why is this?
also, i tried taking off the front reservoir lid but one of the screws is stripped, how do i go about getting it off?
flumpy7
PostPosted: 09:13 - 22 Jun 2013    Post subject: Reply with quote
You should have tubing on the bleed nipple and best to have the other end submerged in brake fluid in a jar so you don't inadvertently suck in air. Open the nipple, pull/push down the lever, keep the lever pulled/pushed down, close the nipple, let go of lever. Keep doing this until clean fluid is coming through the tubing, remembering to keep the reservoir topped up so no air is sucked in that way.
An easier way is to buy a cheap one-way valve bleeder kit so you don't have to keep opening and closing the nipple.
Anyway, if you've done all this and you've still got problems, I would look at popping the piston/s out of the caliper and cleaning and rebuilding with new seals and potentially new pistons if they are knackered. The pistons could be being prevented from retracting because of built up crap around the seals.
2012 Sinnis apache
PostPosted: 10:04 - 22 Jun 2013    Post subject: Reply with quote
Stripped screw = impact driver or if it's too far gone for that, drill the head off, take the top off the reservoir and get some mole grips on the stump.
dansp1
PostPosted: 10:21 - 22 Jun 2013    Post subject: Reply with quote
A trick i use on the crappy master cylinder cap screws is to hit them with a pin punch so that 1, you shock the thread and
2, close up the damaged slots
then get a really good fitting screwdriver, tap the end of the screwdriver with a hammer at the same time and/ or use mole grips on the handle for a bit more leverage.
I am not a huge fan of impact drivers, i have seen too many delicate parts broken by their use.
The last post was made 13 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 39.61 Kb
