rs125 coolant amount?
G19RKE
PostPosted: 12:37 - 22 Jun 2013    Post subject: rs125 coolant amount? Reply with quote
iv drained coolant and put back in the amount i thought it should be but when iv removed the cap under the tank it looked empty.. so i topped it up a little more and ran the bike then checked again and it was empty again!
now when im riding along the temps seem to go right up to 75 ish and its even gone as far as 85 a couple of times... its never gone that high before i changed the coolant tbh..
so if im going to drain the coolant out again and redo it then whats the exact amount i should be putting in and what is the mix ratio of coolant to water....
Aff
PostPosted: 12:51 - 22 Jun 2013    Post subject: Reply with quote
Did you actually bleed the system after you refilled?
Electric Bike Project
G19RKE
PostPosted: 13:32 - 22 Jun 2013    Post subject: Reply with quote
how do you bleed the system on aprilia rs125.. the answer is no i didnt tbh.. Sad
Aff
PostPosted: 13:34 - 22 Jun 2013    Post subject: Reply with quote
There's plenty of videos on Youtube, the process is the same for most coolant systems.
https://www.youtube.com/watch?v=zUpXgAJ1gjU
Make sure you are filling up and bleeding from the radiator cap and not the expansion bottle.
Some engines have bleed bolts so will be a slightly different process.
Aff
PostPosted: 13:44 - 22 Jun 2013    Post subject: Reply with quote
According to the interwebs you should fill from the expansion tank, then there are 2 bleed screws, one on the top left corner of the rad and the other one directly below the left side of the expansion tank.
Loosen these one at a time until coolant seeps out, then re tighten. Top the coolant back up to the fill level and you should be good.
The last post was made 13 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.47 - MySQL Queries: 13 - Page Size: 44.75 Kb
