Battery not charging with lights on
Trylski
PostPosted: 14:46 - 22 Jun 2013    Post subject: Battery not charging with lights on Reply with quote
Honda CBR600f '99
The battery doesn't charge when being ridden, so I have to keep charging it with a mains charger every couple of days.
The charged battery voltage is 12.7v, fine according to the Haynes manual.
Followed the test for current leakage, which seems to be zero.
When doing the output test @5000rpm I got two readings:
Lights OFF = 14.85v
Lights ON = 12.8v
The range in the manual says 14.7 to 15.5v. I've tested the regulator as described in the manual and it's fine, I wanted to ask if there's any chance that there is a fault with the lights that causes them to draw more power than they should.
Otherwise I'm fairly certain I need to pull out the alternator which is gonna be a pain.
So, what do?
Current Bike: Suzuki Bandit N600 '99,
- CBT: Passed 02/2008 - Theory : Passed 24/02/09 Test: Passed 09/03/09 - 2011 33bhp over
martyn107
PostPosted: 14:54 - 22 Jun 2013    Post subject: Reply with quote
Guessing all the wiring looks ok?
Trylski
PostPosted: 15:42 - 22 Jun 2013    Post subject: Reply with quote
I've only given it a quick look over, will be having a proper look tomorrow. I didn't notice anything obviously damaged
Ed Case
PostPosted: 16:31 - 22 Jun 2013    Post subject: Reply with quote
It's fairly normal that when the lights are on and the engine is being used that the power consumption and power generation are about quits. Obviously that depends on the battery being in good condition.
Walloper
PostPosted: 16:57 - 22 Jun 2013    Post subject: Reply with quote
Probably the generator insulation breaking down. Bad insulation will result in power leakage to ground and low output under load.
The volts mean less than amps in ths case.
Trylski
PostPosted: 17:11 - 22 Jun 2013    Post subject: Reply with quote
So pull it out and have a look?
martyn107
PostPosted: 17:32 - 22 Jun 2013    Post subject: Reply with quote
Beat me to it!
Walloper
PostPosted: 03:59 - 23 Jun 2013    Post subject: Reply with quote
martyn107 wrote:
Beat me to it!
That may be so for a ped but this is a 600cc bike. It should have a bit more 'electrical' puff than be just able to keep lights on.
Even our CG125 pumps out enough AVOs to 'bile wash' a few pairs of soiled under-crackers... Smile
trevor saxe-coburg-gotha
PostPosted: 05:47 - 23 Jun 2013    Post subject: Reply with quote
Which is useful. Mr. Green
jjdugen
PostPosted: 08:29 - 23 Jun 2013    Post subject: Reply with quote
Standard issue Honda charging system.
It will be, (in order of likely hood:-
Regulator / rectifier with one phase fried.
Alternator stator with one phase fried.
Poor connections in the fuse box, especially the main fuse on the starter solenoid.
You will need to measure the output voltage of the three AC outputs from the alternator. If they all show about 50 - 70 volts AC at 2000 rpm, then it will be the reg/rec.
J.M.
PostPosted: 10:27 - 23 Jun 2013    Post subject: Reply with quote
My guess wold be a short somewhere on the lighting circuit considering that it's charging properly with the lights off.
That said, 12.8v is usually sufficient to start and ride a bike if your battery isn't toast. Has your battery actually run flat by riding with the lights on or have you just noticed the voltage is down?
2004 R1 & 2018 XSR900
Trylski
PostPosted: 13:27 - 23 Jun 2013    Post subject: Reply with quote
Did some searching on google last night, realised I'd only checked the wiring for the regulator (Doh!) and that the regulator is probably to blame. I've ordered a new one just in case.
The battery was charged with a main chargers up to ~12.7. After being ridden a few times and trying to start her up, all that would happen is the neutral light would dim a little when I press the starter. Never bothered to check the battery voltage when it went flat.
Nothing but standard electrics and a datatool alarm
andym
PostPosted: 13:36 - 23 Jun 2013    Post subject: Reply with quote
Forgive the ignorance here, did you say you've actually checked the voltage when the bike is running and it's fine?
Have you made sure all the wires that should be connected to the battery are?
Only reason I'm saying, my battery died the day after I got my bike, so borrowed a spare which wouldn't hold a charge, so bought a new one, charged it up and went for a ride 65 miles later I stopped the bike and it wouldn't start again (but would bump OK), when I got home I checked the battery (after checking the reg/rec etc) and found I hadn't connected one of the small wires to the earth terminal Embarassed
On idle I get about 14.6v when I turn the lights on it drops to about 12.8v which to begin with I thought was a bit much, but since connecting the battery properly it's started fine every time
Trylski
PostPosted: 19:37 - 27 Jun 2013    Post subject: Reply with quote
Just fitted the new regulator and checked the output voltage @5000rpm. Now reads 14.65v lights off and 14.6v with lights on.
Hopefully that's it all sorted. Cheers very much for all the help!
The last post was made 13 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 3.74 - MySQL Queries: 13 - Page Size: 87.87 Kb
