Monkey / pit bike
Marmalade
PostPosted: 14:36 - 24 Jun 2013    Post subject: Monkey / pit bike Reply with quote
I took my monkey bike out today. 125cc chinky engine that is fitted to most of these things.
It accelerates fine but nearing the top end of the revs it will be popping back through the carb, ease off a little and it clears.
Now after i'd done about 50 mile sat about 55mph I slowed for a roundabout and then it would only reach 40, stopped and there is smoke coming from the back of the engine, i've had a look and can't see a breather so assume it is coming from a leak in the crank case somewhere.
Let it cool for 15 mins, restarted and it did 50mph (my decision to go slower) for 10 miles or so without issue and no smoke.
there is no smoke from the exhaust so don't think it is the rings.
Any ideas? I'm of the mind of just buying a new 140cc stomp / lifan engine to bang in it so i'm not ragging the life out of it to cruise at 60.
cb1rocket
PostPosted: 14:49 - 24 Jun 2013    Post subject: Reply with quote
air filter fine? standard air box? It sounds like the faster you go the leaner its getting. My GP100 (yes its a 2 stroke I know) had the plugs missing to the carb cover and it was leaning out!
Carb clean?
Has this problem developed or was it always like this?
Marmalade
PostPosted: 14:58 - 24 Jun 2013    Post subject: Reply with quote
Carb clean?
I changed a plug on it and it seemed to be after that so i refitted the old one.
Checked ht lead and cap.
Original air filter, clean and untouched.
garth
PostPosted: 15:09 - 24 Jun 2013    Post subject: Reply with quote
There is a crankcase breather at the back of the engine.
Marmalade
PostPosted: 15:21 - 24 Jun 2013    Post subject: Reply with quote
Ah, does seem to be profuse, but why the smoke. Could it be shagged compression ring but oil rings ok, therefore no smoky exhaust but loads of pressure in the case?
But then, why only when it is hot and been ragged for lots of miles?
PostPosted: 15:22 - 24 Jun 2013    Post subject: Reply with quote
Oil thins and creeps past rings/valve stem seals?
Marmalade
PostPosted: 15:28 - 24 Jun 2013    Post subject: Reply with quote
Then the exhaust would be smoky.
PostPosted: 15:29 - 24 Jun 2013    Post subject: Reply with quote
So you get absolutely none from there? 100% sure?
Marmalade
PostPosted: 15:39 - 24 Jun 2013    Post subject: Reply with quote
Yep, clean, just lots from back of the engine
PostPosted: 15:56 - 24 Jun 2013    Post subject: Reply with quote
A quick google suggest blow by of combustion gases. But I'm sure you would be able to diagnose that quite simply?
garth
PostPosted: 16:00 - 24 Jun 2013    Post subject: Reply with quote
With regards to smoke on the overrun, nothing to worry about, every Lifan derived engine I've used after a long flat out session with smoke on a closed throttle slightly.
Crankcase pressure isn't a good thing! How much oil is in there, do you have a cooler fitted?
Marmalade
PostPosted: 16:12 - 24 Jun 2013    Post subject: Reply with quote
Smoky.
Looks like front of engine but its coming out the back of engine, under the tank and out the front of the bike.
https://youtu.be/U4oEAH5gxpk
cb1rocket
PostPosted: 22:52 - 24 Jun 2013    Post subject: Reply with quote
Is the oil at the correct level? Seen video, how smokey! You can see oil on the offside. Where is that coming from?
Marmalade
PostPosted: 22:58 - 24 Jun 2013    Post subject: Reply with quote
It's all part of the same thing, oil is half way up the hatch area of dipstick, can use it but don't really want to be going round at 50mph with twats in cages forcing their way past.
Marmalade
PostPosted: 16:40 - 25 Jun 2013    Post subject: Reply with quote
Now, I feel an engine is in order and thinking an upgrade would be good.
If i sell it as is I'd be lucky to get £300 and then have to put £300 to it to buy another one so may as well spend the cash on an engine.
How about this one? https://www.ebay.co.uk/itm/261189495243?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
140cc stomp engine with all the bits.
Anyone have any experience of these engines or the company selling them?
PostPosted: 17:00 - 25 Jun 2013    Post subject: Reply with quote
Pretty sure binge advised I got one with that cam.
The Molkt is the bog standard carb, they recommend a Mikuni VM26.
I'd buy it if my Lifan shits itself Thumbs Up Only issue is where to mount the cooler.
Marmalade
PostPosted: 17:57 - 25 Jun 2013    Post subject: Reply with quote
Sure I can bodge it on somewhere, i have duct tape and cable ties.
PostPosted: 17:59 - 25 Jun 2013    Post subject: Reply with quote
Wub
garth
PostPosted: 09:09 - 26 Jun 2013    Post subject: Reply with quote
I've got a pit bike in sm form which I ride around go kart tracks (will be racing it soon, next month)
The early ones used to break the kickstart shafts, they're also known for the 3rd gear to slip out, quality control issue really, if you undercut the dogs they won't do it. Same as any chinese engine.
Saying that, mine seems pretty good, fairly punchy for what they are!
I'm just down the road from the one you linked to, it's where I got my bike from. I expect if you phone them up, they'll chuck a Z40 cam in it for the same price instead of the postage...
EDIT, ignore that, it's already got the cam. I haven't in mine, got to follow the rules of the series..
mysterious_rider
PostPosted: 11:09 - 26 Jun 2013    Post subject: Reply with quote
Oh dear. Looks like you have overfilled the oil. Laughing Look at that crap on the side of the engine!
Right, smoke is coming from the crank breather which is located just behind the top engine mount. look between those two pieces on the frame.
Right, time to check the oil level, what CC is it? If its only a 50cc they take a dribble of oil (seriously, I believe they take something like 300ml or less, my one ran on about half a cupful once)
If its a bigger engine I think average is about 750ml.
Don't bother measuring out anything, just look at the dipstick It'll tell you what you need to know..
Just fill it till it reaches the lower line. No doubt yours will seriously overread?
KAWASAKIIIII
mysterious_rider
PostPosted: 11:14 - 26 Jun 2013    Post subject: Reply with quote
If its not the above then it could be shagged seals on the crank or something like that. Just nail the engine until you can afford a new one, also upgrade your sprockets! I believe I went 17-34 with my monkeybike. Possibly even 17-32.
You wont be able to sell your engine for much, IMO its probably worth a genuine £20. I bought a perfect 110 engine second hand for £30.
If you buy a 125, go for a lifan, they are damn near bullet proof. Or try the masai 125 engine, they even have proper heavy duty clutches!
KAWASAKIIIII
garth
PostPosted: 11:23 - 26 Jun 2013    Post subject: Reply with quote
Every 50,70,85,89,107,124 or 140 I've had take roughly the same amount of oil. They're basically all the same crankcases, some (dependant on if they're semi-auto or manual) have different clutch cases, which allow them to take more oil, and some have oil coolers - but again, they don't hold a massive amount more.
Rough oil amount is 800ml - However OP said that he was half way up the level. My 140 with a cooler takes close to a litre.
I've never encountered any C90 derived engine taking as little as 300ml.
Either way, they don't take alot. Change it often.
Marmalade
PostPosted: 15:12 - 27 Jun 2013    Post subject: Reply with quote
Almost went well.
Engine got here in an oil stained box after dpd found it fitted in their van much better on its's side Rolling Eyes
Engine in, stator swapped, neutral light switch swaped, foot pegs swapped and exhaust bodged on, starts lovely, sounds nice but has no neutral.
I've not contacted them yet as the casual, Oh just pop the engine back to us by another shitty courier and we'll send you another one in a week after using god knows how many excuses to blame you for the fault.
so, spent most the day steadily and carefully putting it in, changing bits, making bits and getting it all sorted and i'm going to have to pull it out, send it back and them say "where is the clutch cable guide that was on the engine we sent you?" etc etc
Any suggestions as the the no neutral before I start my quest?
garth
PostPosted: 15:17 - 27 Jun 2013    Post subject: Reply with quote
It wouldn't be the first time an engine has arrived with the shims on the gearbox shafts arranged in the wrong order.
P.s. Luckymx are £30 cheaper for a 140 engine.
PostPosted: 15:24 - 27 Jun 2013    Post subject: Reply with quote
So tempted to get a 140... but I'll need to sort the brakes first, they are dire at best.
The last post was made 13 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 134.4 Kb
