Oil Leak, Gasket Advice
WildGoose
White Van Man
PostPosted: 20:55 - 04 Dec 2004    Post subject: Oil Leak, Gasket Advice Reply with quote
diagnosed...
https://www.bikechatforums.com/files/1_142.jpg
you can see here, my engine, and three gaskets in that area, one i have replaced with official honda (the clutch cover gasket) the other at the bottom of the engine, is the sump gasket, that is fine
the leak is coming from where the two engine halfs meet, from looking at the engine, it seems someone has used instant gasket (something i despise) to seal the two engine halves
now, it doesnt leak a lot, the level of oil never goes down, so i have no intention of sorting this until i have another bike, haynes manual says to split the engine, you have to drop it out of the frame, so its a major job
here is a page from the honda illustrated parts catalogue
https://www.bikechatforums.com/files/2_142.jpg
its the only page that deals with the two engine halves, and is it just me, or is there no gasket detailed there? i've gone through the entire book and there seems to be no gasket for between those two parts
my question is why? is it such a rarely replaced gasket that honda dont make one, and you just have to do it yourself with instant gasket (doesnt seem likely) would a gasket like this blow by itself?
and why would an engine like mine, with apparently such a low mileage (i bought it at 17 000 km's) ever have to be split? harsh life? HPI check indicates the mileage is rougly correct Confused
the leak is fairly minor, it only causes my right boot to be constantly covered in oil, but i'd rather have an engine that didnt leak...
anyone ever split an engine before?
Guest
PostPosted: 21:44 - 04 Dec 2004    Post subject: Reply with quote
It's very rare (off the top of my head I can't think of one) to have a gasket between the two crankcase halves, and a very fine bead of sealant is all that is usually necessary. The makers use their own product (Yamabond, Sukibond etc.) but I always use a very thin film of blue Hylomar and then wipe it nearly all off if I've had an engine apart.
It's a pretty major job to split the engine if you're not used to it so if it's not causing problems I'd leave it alone. I'd have another look at the clutch cover gasket and the mating faces though, make sure they're absolutely clean and un-damaged.
But you say the level never goes down but your boot is constantly covered in oil - can't have it both ways Wink
WildGoose
White Van Man
PostPosted: 22:42 - 04 Dec 2004    Post subject: Reply with quote
well, it would take a fairly major leak to let the oil go that far down between oil changes
but it doesnt take much to get a film of oil on your boot, especially if you never clean them Razz cos i have no fairings, it leaks at the front of the engine, and gets blown round onto the peg area Evil or Very Mad
so there you go...cheers for the advice tho, i hadnt planned on ever splitting an engine, unless totally bored Wink
PostPosted: 23:23 - 04 Dec 2004    Post subject: Reply with quote
I have my doubts as to your diagnosis.
The reason being, the level of oil in the engine is generally below the join in the crankcase halves and I have not seen a leak there before.
If it was an older bike with the crankcases split vertically I would have believed it, BSAs and Triumphs came with an oil leak here fitted as standard. On the plus side, they never seem to cause a problem provided you keep the oil topped up.
From experience, the most likley place for a leak is where the rowl-pin goes through the middle of the gasket (labelled 1). Although there looks to be quite a big drip of oil at the bolt below this (labelled 2).
What I would do is give that side of the engine a bloody good clean in soapy water so you have got rid of all the oil then keep a carefull eye on where it is coming from. A litle silicone RTV or blue hylomar applied to the clutch cover gasket in this area will do no harm providing you don't get loads of it squeezing out on the inside which would block oilways.
For future reference, you can make your own gasket for under the clutch cover by cutting it out of gasket paper or the side of a cardboard cereal box. Simply remove the cover, clean it up then 'stamp' the outline onto your gasket material using a thin smear of oil on the gasket facing as 'ink' then cutting round it. Make sure the two facings are perfectly clean before you fit the gasket and use a THIN smear of hylomar on both sides of the new gasket.
Robby
Dirty Old Man
PostPosted: 16:15 - 05 Dec 2004    Post subject: Reply with quote
Also a slightly different suggestion.
Is it definately oil?
If the design is anything like the NC24, thats right under the thermostat housing and a coolant hose. Decent strength coolant can look a bit like oil when its leaked like that, but isn't brown on your fingers, and tastes sweet.
Not a good idea to drink it, but many of us have had a mouthful when syphoning. Taste much better than petrol.
pipnet11
PostPosted: 01:07 - 06 Dec 2004    Post subject: Reply with quote
Laughing Yup and there still isnt a good way to fix them!!
Would be very surprised if there is a leak here. I would have still been surprised even if there was no sealant at all round it as there is no oil pressure here at all and new engines tend to be build well enough to seal it enough just metal to metal. Instant gasket is something I have never played with, blue hylomar or red hermatite works fine.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
mchaggis
PostPosted: 01:23 - 06 Dec 2004    Post subject: Reply with quote
Is that the blue sticky goop that I had to spend half an hour cleaning off the mating surfaces just to replace the rocker cover gasket? Evil or Very Mad The new gasket was a perfect seal, no need for this sealant crap on a honda engine.
I must not be a troll...
Mmmm, Guinness
PostPosted: 01:45 - 06 Dec 2004    Post subject: Reply with quote
Although the oil level is below there, plenty of oil will be splashed on there and crankcase pressure will push some of it out.
I would also not expect to find a gasket between the 2 halves of the crankcase.
In the line drawing it looks almost like the locating dowel at that corner is seperate from the bolts holding the crankcase halves together. If that is true then it would not surprise me if that is the oil feed up to the top end of the engine.
pipnet11
PostPosted: 13:00 - 06 Dec 2004    Post subject: Reply with quote
Yer, on a Honda just the gasket would be fine, but on british bikes its a god-send!
The last post was made 21 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 8.69 - MySQL Queries: 13 - Page Size: 65.65 Kb
