GPZ 500s brake pads
chrisb
PostPosted: 11:30 - 05 Dec 2004    Post subject: GPZ 500s brake pads Reply with quote
Hi People,
a bit of advice please. I have recently bought a GPZ for winter riding, and I am supprised to say, I love it, my only critisism is the front braking, (it is a single disc version). Just be for stopping say under 10 MPH the brake judders terribly, setting up vibration on the forks? it has the original brake pads as its only done 2.5K. Is this because the pads are rubbish and if so what would peoples recommended replacements be?
Chris Shocked
PostPosted: 13:15 - 05 Dec 2004    Post subject: Reply with quote
Dunlopads seem to work OK in the past, but our old GPZ had major problems with standard EBC pads.
Given that it is juddering check the disk for being warped. I would also say to try and clean the disk up.
iCraig
PostPosted: 14:25 - 05 Dec 2004    Post subject: Reply with quote
Why do you say that?
As I have just put a set of EBC FA129's into my GPZ. Confused
Anyway, back on topic it sounds like your front disc may be warped or buckled, put the bike on its centre stand and get someone to push down on the back of the bike and turn the front wheel whilst looking at the disc and it you see movement from side to side at any point on the disc then its warped.
PostPosted: 14:33 - 05 Dec 2004    Post subject: Reply with quote
Shouldn't be juddering so see above.
I have also had problems with alloy corrosion under the disc which sets it slightly off-kilter. Try taking the disc off and scrape all the powdery white muck off the wheel hub under where the disc bolts on. Smear with copper grease before refitting the disc.
I used EBC HH sintered pads which work well. Braided steel hoses make a big difference to the braking performance.
chrisb
PostPosted: 16:53 - 05 Dec 2004    Post subject: GPZ pads Reply with quote
Thanks guys, I 'll check out the disc for trueness ans scotbright and degrease it. let you know if this does the trick.
Chris Very Happy
PostPosted: 21:01 - 05 Dec 2004    Post subject: Reply with quote
Because on that one using standard EBC pads (not the HH ones), standing on the brakes hard at 90mph with a pillion would result in them fading to nothing by the time you got down to 30mph. Also used to go through them in 3000 miles.
The last post was made 21 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 50.42 Kb
