New tyres and fresh forks, feels dangerous...
PostPosted: 13:07 - 29 Jun 2013    Post subject: New tyres and fresh forks, feels dangerous... Reply with quote
So the Varadero was overdue a set of fork seals and a rebuild on the front end along with 2 tyres so I did that today.
All went well, everything seems to be perfect, apart from it feels so damn dangerous to ride.
It feels like it will flop over in the corners, I used to be able to hit corners at 50-60mph and have no worries, this was on square tyres and leaking forks...for about 4 months now.
Would changing the tyres really give me that much of a confidence hit? I genuinely am scared to ride the damn thing, its so eager to want to turn in but it feels far less stable than the R1 and that has a real evil turn in.
Tyres in question, Pilot sporty on the front, conti twist SM on the rear, front is 31psi, rear is 33psi.
Could be because I've got so used to the neutral and bad handling it had that I wasn't aware it could be like this Laughing
MarkJ
PostPosted: 13:11 - 29 Jun 2013    Post subject: Reply with quote
I'd give it time, I've given everything a service in the past and with new tyres felt completely different. Are the head bearings tight?
Hetzer
PostPosted: 13:11 - 29 Jun 2013    Post subject: Re: New tyres and fresh forks, feels dangerous... Reply with quote
That's the most likely explanation. Effectively you're now riding a different bike and aren't used to it.
PostPosted: 13:15 - 29 Jun 2013    Post subject: Reply with quote
Its far sharper than the R1 which is the scary bit, checked all the bearings, they were fine, greased them to be sure anyway.
The bar wobble I had has gone, I put it down to the unbalanced front tyre, but I genuinely felt safer doing any speeds on that bike with its bar wobble, slow punctured tyres and leaking forks Laughing
PostPosted: 14:16 - 29 Jun 2013    Post subject: Reply with quote
_Iain_ wrote:
I can haz a go? Confused
By all means Laughing
DMCpro
PostPosted: 14:30 - 29 Jun 2013    Post subject: Reply with quote
Did you change forking oil if so did you use the right grade? Right amount? Head race set ok? Maybe your just used to having a lot more weight when turning in (1000cc v 125cc)
Honda CB-1, TS125X
VW Golf Estate
PostPosted: 14:43 - 29 Jun 2013    Post subject: Re: New tyres and fresh forks, feels dangerous... Reply with quote
Due to a slight wine o'clock hiccup[*], I accidentally ordered a SM for the GPZ500. The profile looked like a V, and fresh on, it felt like it was going to tip over with the slightest lean. It's calmed down a lot now that I've squared it off a bit though, so MTFU and ride through it, soldier.
[*] "Don't click on the SM, don't click on the SM, don't something on the... something."
Blackwolf
Burgerfist
PostPosted: 14:45 - 29 Jun 2013    Post subject: Reply with quote
Just don't break it.. Laughing
SQL
PostPosted: 14:47 - 29 Jun 2013    Post subject: Reply with quote
Lol paddy I was used to my buggered swing arm and wheel bearing, when i changed em it was like a new bike Laughing
Islander
PostPosted: 14:52 - 29 Jun 2013    Post subject: Re: New tyres and fresh forks, feels dangerous... Reply with quote
In short, yes. Laughing
Give yourself some time to get used to it. Thumbs Up
Islander
PostPosted: 14:54 - 29 Jun 2013    Post subject: Re: New tyres and fresh forks, feels dangerous... Reply with quote
I used to use Dunlop TT100s in the 70s and they had a V shaped profile (Trigonic IIRC). They took some getting used to as they used to make the bike dive into bends and corners like a thing possessed. Laughing
Snorty
PostPosted: 15:34 - 29 Jun 2013    Post subject: Reply with quote
On my old TZR, I was riding it on knackered front and rear wheel bearings, two squared tyres and a shocker that had no damping, would just bounce up and down. I was used to it like that and was even out-pacing my ex on her NSR.
I got all of this sorted at the same time. When I got on the bike it felt like it didn't want to be upright, like it would just tip in from the slightest of input, felt really de-stabilised. I soon realised that is how it was supposed to be. Got some really good cornering out of it after that. Followed by a lowside from getting too confident Razz
The last post was made 13 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 79.18 Kb
