Bandit Engine Swap Fitment Problem
wilz1234
PostPosted: 11:09 - 01 Jul 2013    Post subject: Bandit Engine Swap Fitment Problem Reply with quote
Recently bought my old bandit back. The headgasket went, so the previous owner bought a second engine to swap over.
This second engine was a straight swap, however the exhaust doesn't fit properly because it hits the sump. Is there a difference between exhausts or sumps on different year bandits?
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
Bezzer
PostPosted: 13:52 - 01 Jul 2013    Post subject: Reply with quote
You can swop most of the oil cooled sumps around between models, someone has possibly swopped one on your "new" motor probably to save replacing a stripped sump bolt thread. Headers are also different lengths to allow for the differennt depths/clearance, 1200 ones are longer.
No reason why you can't put the sump off your original on this one as long as you also swop over the oil pick up tube as they are matched for the different lengths to make sure they are the right depth to work.
wilz1234
PostPosted: 17:44 - 01 Jul 2013    Post subject: Reply with quote
Thanks for that Karma
Do you know if it's the same for the bandit 600? Do the 600 and 1200 share sumps?
virus
PostPosted: 18:13 - 01 Jul 2013    Post subject: Reply with quote
the 600 is derived from the gsxr750 and the 1200 is derived from the gsxr1100 as far as I can recall, most parts are compatible between pairs but its only really cams that are compatible/worth changing from the big ones to the little ones.
ask on https://old-skool-suzuki.proboards.com/ for a definite answer.
John
own: 81 xs1100g...
Bezzer
PostPosted: 20:25 - 01 Jul 2013    Post subject: Reply with quote
The 6 and 12 sumps are interchangeable but not sure if they are the same depth, it's easy enough to measure and check if you've still got the old one to compare.
The slabbie 750 motor is the base for ALL the oil cooled motors. There is a bit of mix and match yes, but a lot of stuff won't swop easily. Dot heads and GSXR 750 J&K /GSXR1100 K&L are the standard performance mods.
The last post was made 12 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 45.57 Kb
