| ws4936 |
 ws4936 World Chat Champion
| Blackwolf |
 Blackwolf Burgerfist
| -Matt- |
 -Matt- World Chat Champion
 Posted: 18:27 - 01 Jul 2013 Post subject: |
Muc off brush set.
Autoglym bike soap/degreaser/intensive tar remover [good for oil spots on wheels etc].
Wurth chain cleaner and dry chain wax.
Microfibre clothes to dry and another to polish with muc off speed polish.
Then of course assortment of throw away toothbrushs/rags for wiping sh-t off stuff...
And of course water
Be careful if using pressure washers etc to turn it right down and not spray certain parts like the chain/wheel bearings/near electrics/openings bla bla bla or you will make a lot sh-t for yourself than what you wash off
I just use a hose/bucket personally |
| j.silvs |
 j.silvs World Chat Champion
 Posted: 18:30 - 01 Jul 2013 Post subject: |
My routine:
1. Jet wash to get dirt removed
2. Apply castrol bike cleaner all over the bike and leave for 10mins
3. Jet wash it off and dry with a large leather shammy
4. Apply muc off polish to all metallic paint parts, leave for 5 mins and then buff it off
5. Wash mirrors, dials and light housings with glass cleaner
6. Use muc off chain cleaner on the wheels, and swing arms
7. Use muc off Leather cleaner to clean the seat
8. Once all is dry go for a quick blast to warm the chain
9. Degrease the chain
10. Apply muc off chain lube
Done  |
| ws4936 |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 21:58 - 01 Jul 2013 Post subject: |
Apply paraffin to the bits that are greasy that I no longer want to be greasy and wash off. Rinse the rest well then Autoglym shampoo. Once in a blue moon I'll go to town on it with SRP and then seal with HD wax. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| trevor saxe-coburg-gotha |
| j.silvs |
| Turkish |
 Turkish Crazy Courier
| -Matt- |
| Sako |
 Sako World Chat Champion
| Lyam |
 Lyam Spanner Monkey
| killa |
 killa Won't Shut Up
 Posted: 09:58 - 02 Jul 2013 Post subject: |
I like my bike looking tidy but not show perfect. I have perfected my 3 stage method over time…in my opinion anyway
Here’s what I use every time.
Kit
Paddock stands (preferable)
Karcher Power Washer
Halfords red bucket
Halfords Valeting cloths x 4 (the ones that are like flannel material)
Kitchen towel
Polishing cloth (stuff you cut off the roll)
Muck Off
Engine degreaser
WD40
ACF50
Stage one
Firstly, spray Muck Off all over the bike and let it soak the dirt. Doesn’t matter where, the formula is perfect for all over. - [5 mins]
Whilst it is doing its job, I set up the power washer. - [Approx. 10 mins]
Power wash the bike (avoiding concentrated aim on vital parts) - [5 mins]
Leave the bike wet and go fill the bucket with warm/hot water. I spray Muck Off about 4-5 times in the water, you don’t want this strong. - [5 mins]
Put bike on paddock stands
Stage 2
Using one of the valeting cloths for the top half of the bike, using plenty of water, wipe the bike down. - [5 mins]
Using the kitchen roll, wrap a few sheets around the hand and quickly get rid of excess water - [5 mins]
Using a separate valeting cloth, go to work on the lower half of the bike (metal work) – [5 mins]
Same again with paper towels. – [5 mins]
I usually work on the cockpit now with more kitchen towel and WD40. This is just great for switches and excess water. [5 mins]
This is where I use dilute engine degreaser on the under tray, wheels and some metal work. The rear is always splattered with chain lube and literally wipes clean with an application of degreaser. This is made easy on paddock stands. - [Approx. 5 mins]
Stage 3
The bike should be dry and clean enough for polishing now. I haven’t used all the great polishes but I find Autoglym good enough.
Using the polishing cloth cut from the roll, I use a side for application and a side to buff. [Approx. 10 mins]
Lastly I sometimes go around with some remaining kitchen towel, squirt ACF50 on a couple of sheets and apply to fixings and areas that see harsh conditions.
Special attention to hoses and clips, swing arm area and forks. [Approx. 10 mins]
Total time: Approx 1Hr 20 mins
Stand back and admire your handy work
https://i.imgur.com/zbBTm8X.jpg
https://i.imgur.com/5KnLQEv.jpg
https://i.imgur.com/10oaxWx.jpg
https://i.imgur.com/y6m2Taz.jpg ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| TwoWheelsDail... |
 TwoWheelsDail... Scooby Slapper
 Posted: 10:10 - 02 Jul 2013 Post subject: |
My routine, Every Wednesday no matter what the weather.
1. Wet bike with hose
2. Apply Autobrite Snow Foam
3. Fill 2 buckets whilst snow foam is dwelling - 1 with warm water and Britemax Shampoo, the other with cold water.
4. Wash off snowfoam with hose
5. Apply Muc Off Bike Cleaner + bug/tar remover if needed
6. Get stuck in with a sponge/wash mit - use cold water bucket to rinse sponge each time - reduced chance of grit scratching paintwork.
7. once bike has been gone over with sponge - get out the tooth brushes, Muc Off brushes and Autoglym Brushes - use high concentrate Muc Off Bike Cleaner (1:1 water:Bike Cleaner) to get into the hard to reach places.
8. Autoglym Custom wheel cleaner on rear wheel as its a pig to clean and the wheel cleaner foams up and jsut disolves dirt.
9. Muc Off Chain Doc - Clean the chain using chain doc then use microfibre/rag to wipe off excess fluid
10. Snowfoam again
11. Rinse again.
12. Lube chain using Muc Off Chain Lube or Tutoro Chain Oil
13. Dry bike with Microfibre or AutoFinesse Waffle Towel
14. Apply Chosen Wax ( Im a wax-A-holic so have a fair few- Dodo Juice SuperNatural, Kleen Freaks Wax, Bullet Polish spray on wax, Muc Off Speed Polish, AutoGlym HD Wax to name a few)
15. Wait for wax to haze then Buff off with Microfibre
16. If needed for extra shine repeat steps 14 and 15.
17. Use autoglym metal polish on exhaust downpipe and end can and any other shiney bits.
18. Admire bike
If your stuck for which products are for you have a look at www.waxybox.co.uk they supply all sorts of samples. I get one every month  ____________________ Suzuki GSR 750 - 33BHP (Restriction Ends 17/12/2014)
KTM Duke 125 - SOLD
www.facebook.com/TwoWheelsDaily | www.twitter.com/TwoWheelsDaily | www.instagram.com/TwoWheelsDaily |
| garth |
 garth World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:07 - 02 Jul 2013 Post subject: |
| garth wrote: | Bunch of tarts. My bikes get cleaned once a year, for the MOT or when I sell them, whatever comes first. |
Mine are gleaming right now for those very reasons.
Products, eh, whatever's cheapest at Morrisons. Car shampoo and some squirt on wax, sponge and a big roll of workshop paper. ____________________ Biking is 1/20th as dangerous as horse riding.
| calyx |
 calyx World Chat Champion
 Posted: 22:50 - 02 Jul 2013 Post subject: |
My bikes get cleaned ones. Before selling.
Had to clean a bike twice. 1st ebay buyer didn't collect  ____________________ Boris - London |
| iMark |
 iMark World Chat Champion
 Posted: 22:58 - 02 Jul 2013 Post subject: |
Depends how often it rains.
Rained today maybe 4-5 times this week?
https://i.imgur.com/tiUlBaW.png
Leaving it outside in the rain counts as washing it right? ____________________ K8 GSXR 1000
"G" : you got him to have a look at a forum which seems to have established a picture of an erect penis in a cat's mouth as it's mascot and thought he might consider it ok? |
| snomag |
 snomag Trackday Trickster
 Posted: 07:01 - 03 Jul 2013 Post subject: |
Wow, I'm shocked
Mine usually gets cleaned when it's being serviced, as they usually have no choice at that point, but to to so :p
Other than that, I'm not too bothered. Maybe I wash it once a year if I've got absolutely nothing else to do. |
| P.addy |
 P.addy Red Rocket
| keggyhander |
 keggyhander World Chat Champion
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
