space between hub and sprocket
Random13
PostPosted: 22:12 - 01 Jul 2013    Post subject: space between hub and sprocket Reply with quote
Hello,
I have recently changed my rear shoe pads and had to take the wheel off.
Out of curiosity I also opened my sproket and bolted it back in.
I have put it all together but the space between wheel hub and either the brake side or sprocket looks quite big. I have taken a pic so you guys can comment whether this is normal or I have done something wrong.
When tightening the sprocket bolts, in my haynes it says 55nm torque for 13mm socket. I did tighten my to 40nm and thought is it going to snap if pushed further so stoped, is that dangerous ?
isn't 55nm too much ? I did use the torque by putting pressure on end of the wrench
or maybe my wrench needs to be recalibrated as I did turn the grip thing all the way down and also below the lowest setting which I have heard can mess the torque wrench up
Thank you in advance
space from brake cover to hub
https://i41.tinypic.com/wjjapt.jpg
space from sprocket to hub
https://i39.tinypic.com/x0wkgm.jpg
The last post was made 12 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 32.45 Kb
