Kawasaki Z250 A3
solemnwarning
PostPosted: 21:25 - 30 Jun 2013    Post subject: Kawasaki Z250 A3 Reply with quote
Three months ago I picked up a 1981 Z250 A3 as a project to replace my YBR125. The engine hasn't ran in several years, but it turns over and has only done 14k, so surely I can get it going again!
Onwards!
This is the first time I've stripped a bike down, very different to the Land Rover I'm used to working on. Most of the bolts come undone with very little effort. Sadly, the others are made of cheese and snap off with similarly small amounts of effort.
Biggest sticking point while stripping it down was the centre stand. The slip-fit mild steel pin had (shockingly) fused to the inside of the stand, resulting in the pin rotating in the frame rather than the stand and wearing the mounting holes slightly oval. After lots of hammering I give in and cut through the pin. Now I'm waiting to have it reamed out and a new pin made up.
Once I've got the bike broken down into convenient bits I decide to start with the rear caliper, a quick and easy job for me to get out of the way...
So, a couple of months later I get a small, cheap compressor from eBay. By combining 8 bar of constant pressure inside the caliper, a mallet and a heat gun the pistons finally come out. Progress!
The master cylinder comes apart much easier, except for needing an 18" pipe wrench to get the lid off of the reservoir.
One more thing...
Has anyone got a grab rail/handle for one of these? Someone replaced it with a generic luggage rack that didn't really fit... until some thin, bent threaded rod and the indicator mounts got involved. Then it just wished it wouldn't fit.
pepperami
PostPosted: 20:59 - 01 Jul 2013    Post subject: Reply with quote
Hmmmm? I see no pictures? Sad
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
UnspeedySam
PostPosted: 23:20 - 01 Jul 2013    Post subject: Reply with quote
Looks like a cool little bike. Good luck getting it on the road! Smile
Stonefly
PostPosted: 16:52 - 02 Jul 2013    Post subject: Reply with quote
Have the tank/tail/side panels been changed? They are A2 colours, not A3.
I will have a look in my garage for a grab rail for you. I know i DID have one lying around a few years ago and it will be a bit rusty if its still there, but you could clean it up and get it rechromed.
If i still have it, its yours for the cost of postage.
Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250
solemnwarning
PostPosted: 18:46 - 02 Jul 2013    Post subject: Reply with quote
The panels haven't been changed as far as I'm aware. It was registered near the start of 1981, so maybe it's an A2? I'm not actually sure what the differences are.
The grab rail would be much appreciated if you can find it, thanks.
spikenipple
PostPosted: 21:46 - 02 Jul 2013    Post subject: Reply with quote
I'm halfway through restoring a Z250 LTD at the moment, great but shitty little bikes these are!
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
RhynoCZ
PostPosted: 14:44 - 04 Jul 2013    Post subject: Reply with quote
I've got a question, is it swift enough, for normal riding? There is one '80 in perfect condition near the place I live and I can not stop thinking about it.
UnspeedySam
PostPosted: 17:34 - 04 Jul 2013    Post subject: Reply with quote
What's normal riding? I would commute on it and ride it around at the weekend if I wasn't in the mood for a fast ride. But I wouldn't take it on long motorway journeys unless you like cruising at 60 to avoid it becoming horribly buzzy. I haven't ridden one but I have ridden similar 250s so could be talking out my arse...
RhynoCZ
PostPosted: 20:50 - 04 Jul 2013    Post subject: Reply with quote
Normal riding = cruising and occasional flat out run on my favourite mountain course. 60 is really not enough Smile
UnspeedySam
PostPosted: 21:26 - 04 Jul 2013    Post subject: Reply with quote
Yeah it'll do 90 according to the specs. But most bikes like this are a bit strained cruising at more than 60-65.
RhynoCZ
PostPosted: 12:08 - 05 Jul 2013    Post subject: Reply with quote
Thank you for the info, I'm gonna look for something else then Smile
solemnwarning
PostPosted: 18:19 - 21 Jul 2013    Post subject: Reply with quote
A busy weekend... I love this country.
solemnwarning
PostPosted: 17:54 - 10 Aug 2013    Post subject: Reply with quote
Got the forks stripped down today
I struggled a fair bit getting them apart and now I can offer some pointers to other noobs:
- Don't try holding the fork between your legs, compressing the cap with your chest and picking the retaining ring out with dental tools. It won't work and it looks rather silly. Clamp the bottom bit in a vice.
- Use a T handled allen key or similar to press the cap down and slip a thin screwdriver under the ring from the top to pry it inwards and out.
- Don't drain the oil before you start (did this on the second one to make less mess), doing so makes the forks compress a bit easier and thus holding the caps down is harder.
- If the cap doesn't shoot out once the retaining ring is removed, hold a rag (or your hand...) over the top of the tube and bounce the fork up/down until it does.
Checked the springs for wear and they're both 25mm longer than the workshop manual says is standard... someone fitted uprated springs maybe? Smile
One of the cap bolts that goes into the bottom and stops the forks flying apart has a chewed up head, I take it grade 8.8 will be fine to replace it? Come to think of it, is there anywhere on a bike where 8.8 is not sufficient?
There is a gap of 1 year, 173 days between these two posts...
alansaxman This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 11 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 87.38 Kb
