balancing carbs
GZXR400
PostPosted: 08:03 - 02 Jul 2013    Post subject: balancing carbs Reply with quote
Hi im going to be balancing my carbs soon and i remember when i last did this that the engine kept reving evreytime a adjustment was made. Bike is a kawasaki zxr 400, how do i stop this happening ?
Thanks
orac
PostPosted: 11:34 - 02 Jul 2013    Post subject: Reply with quote
use less pressure on the screws. the revving is caused by opening th throttle butterflies when the pressure is applied.
also dont forget the revs will chnage as you alte the balance of the carbs.
Fizzer Thou
PostPosted: 19:44 - 02 Jul 2013    Post subject: Reply with quote
After several adjustments it is a good idea to give the engine a good rev then carry on after the revs have settled.
On many engines that I have worked on the adjusting screws are not that easy to turn,so a quick dousing with some WD40 smoothes any further turns.
Always have a 'Plan B'
The last post was made 13 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 35.2 Kb
