| jamie182861 |
 jamie182861 Nitrous Nuisance
| -Matt- |
 -Matt- World Chat Champion
| Pete. |
 Pete. Super Spammer
| jamie182861 |
| Timmeh |
 Timmeh World Chat Champion
| jamie182861 |
| Timmeh |
 Posted: 14:24 - 02 Jul 2013 Post subject: |
36? doubt it very much.
Standard 4DLs punt out 26hp and will just about touch the ton on a good day. SPs are several kilos heavier due to their longer, thicker swingarm and realistically only ever managed 30bhp despite the extra engineering Giladoni did on their barrels, although I never really understood why they decided to machine two extra holes in the powervalve.
Just by reading your other post it's running pre-mix and using a Wossner flat-top piston with a 4FU head... well good luck with that. VHSA carbs aren't designed to be run with pre-mix, they have a separate injector circuit and the correct piston for the SP is the Asso. On your piston the ring pins will run past the two extra exhaust ports. The 4FU head, whilst it will fit, isn't the correct one; the SP head has a differently-shaped combustion chamber.
Also I'm really not sure you're asking where to buy spare parts on what, if you believe the advert, is basically a brand-new bike. Also be aware that as that all the engine components have been mixed-and-matched you'll need to inspect the parts before so you get hold of the same ones.
<tl;dr>
There is a great deal of confusion regarding the TZR125 and it's wasn't helped by Yamaha and Belgarda (and other Italians) with their stupid numbers and looky-likey (but different) engine parts. So, just so this thread is educational for all, here's the correct info.
4DL - cases stamped 4DL, head and barrel stamped 3MB*. Domed piston
SP - cases stamped 4DL, head and barrel stamped 4DL. Flat-top piston
Only engines stamped 4DL were made by Moto-Minarelli. Everything else is Yamaha.
*; some 3MB heads were given additional porting work and are stamped with an additional P. These heads are also stamped Y1 or Y2 on the opposite side as they were bored out to the next size before being plated.
56.4mm is the standard bore; +0.25mm for Y1 and +0.5mm for Y2 barrels.
</tl;dr> ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| jamie182861 |
| bladerunner |
 bladerunner World Chat Champion
 Posted: 05:23 - 03 Jul 2013 Post subject: |
36bhp is asking a hell of a lot for a 125 at the wheel.  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| Pete. |
 Pete. Super Spammer
| jamie182861 |
 Posted: 14:13 - 03 Jul 2013 Post subject: |
all engine parts and engine was tunned by a professionally by stan stevens he 2 stroke tuner
https://www.stanstephens.com/ |
| Sako |
 Sako World Chat Champion
 Posted: 14:20 - 03 Jul 2013 Post subject: |
Yeah, but do you have the dyno printout? |
| P. |
 P. Red Rocket
 Posted: 14:21 - 03 Jul 2013 Post subject: |
36hp is possible.
With A LOT of money.
A blank cheque typically..  |
| jamie182861 |
| jamie182861 |
 Posted: 15:00 - 03 Jul 2013 Post subject: |
here all info
yamaha tzr 125r belgarda ,hi for sale is my tzr belgarda [sp] started life as normal 4dl now sp spec,i have spent well over £1200 on this classic.Work been done as follows,powdercoated frame,swingarm,top bottom yokes,all hangers and brackets,wheels ,almost everything i could coat,engine is gen sp engine number is 4dl050----,gilardoni sp cylinder number 4dl00 nicisol barrel with boost ports,crank has been rebuilt,crank bearings ,seals new,all internal bearings and seals renewed,new ebc clutch,top end cylinder was perfect,put new wossner flat top in and mated with 4fu cylinderhead,gen yamaha gaskets used in rebuild,castrol mtx in gearbox and useing castrol 747 as premix,oil pump is there and works i just prefer to pre mix to be sure,carb is sp, was totally striped new jets 170 mains standard sp, pilot,plunger and needle all new and gave it ultrasonic clean,sp reeds new,sp double airbox,front and rear paolli fully adjustable suspension sp,new didi oring chain,new front,rear sprockets standard gearing,brembo calipers front and rear both have been rebuilt and new ebc sintered pads fitted,dunlop sportmax gp front and rear tyres,150,,110,,17,full jollymoto pipe and end can,bodywork has been repainted sp uniform, using yamaha colours,plastics are all oem yamaha,there was a few repairs here and there nothing you wouldnt exspect from 20 year old plastics,looks stunning in sp format,needless to say the engine will need gently run in before you can enjoy it full,when sold it will come with 1 years mot,those who know there tzrs will know how rare sp models are, sp engine and cylinder worth £900 alone |
| P. |
 P. Red Rocket
| jamie182861 |
| Timmeh |
 Posted: 16:11 - 03 Jul 2013 Post subject: |
Even with your paddybodges I'm sure yer R1 would touch that figure (once, at least)
If it really, really has got all that power then I wouldn't expect the engine to last more than a 1000 miles at best and less than 500 at worst. And that's with the right components. Your piston, despite being forged rather than cast, is only the the 4FL which produces 20hp at best (they are, after all, detuned 3MB engines) so I can't imagine how much stress the little end and rings will go through. I've already drawn your attention to the fact that the pins will be in the wrong place.
Having owned and ridden a propa' SP I can safely say their only place is on the track. Yes, they may have lights and indicators but thanks to its zorst and ridiculous porting it produces fuck-all torque at the lower rev range. The powerband is hardly what you'd call manageable, it's just 2000 revs wide and keeping the engine on song whilst cornering on the road is hard work, even for someone who is experienced.
One of the reasons why we're giving you some stick perhaps is english (or lack of) in the advert. We'd all expect a serious TZR tuner and builder to be able to at least use coherent sentences and spell nicasil properly.
| Quote: | engine is gen sp engine number is 4dl050---- ... front and rear paolli fully adjustable suspension sp |
1. All italian license-built engines have the prefix 4DL. There's no 'official' SP stamp. You can't even use the numbers to tell them apart as Giladoni just took random batches through the manufacturing run.
2. Paioli (note correct spelling) suspension units are not adjustable. At all. One leg does the damping, the other does the rebound. Their rates are selected and matched at the factory. The rear shock can be slightly adjusted for preload, but only by a narrow margin to allow for different rider weights. ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
| P. |
 P. Red Rocket
 Posted: 16:29 - 03 Jul 2013 Post subject: |
| Timmeh |
| Calum122 |
 Calum122 Derestricted Danger
 - Super Spammer
| mevy87 |
 mevy87 L Plate Warrior
| P. |
 P. Red Rocket
| mevy87 |
 Posted: 12:08 - 15 Mar 2014 Post subject: Re: TZR125R BELGARDA |
Can't be arsed taking a pic and uploading as I KNOW what this bike does
She has never let me down except when water gets in tank but that can be easily resolved with a new fuel cap outer gasket just trying to find one seems hard....
I paid 50 just for a water coolant tank which i believe to be about 1litre but it was a case of pay it or find another one which took 6 hours of none stop surfin to find
Next job is radiator as there is a small leak which seems to make the engine get too hot over prolonged red lines haha  ____________________ Mr Tin Ed |
The last post was made 11 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
