| dublinclontar... |
 dublinclontar... L Plate Warrior
 Posted: 00:52 - 02 Jul 2013 Post subject: Yamaha YBR 125 check engine light comes on at speed |
I've got a standard 2010 (FI, 12k on the clock) model YBR 125, recently just replace the rear brakes chain n sprockets, gotten a battery charger, cleaned the air filter and spray painted the exhaust pipe.
This is my first bike and I'm probably a sap for doing this but I use premium petrol and fully synthetic oil (changed 250 miles ago, nothing but the best for my little girl).
Commute 70 miles a day(35 each way) and this evening the check engine light would come on anytime I went over 60 on the speedo when typically I'd get up to 75 before "the beast" ran out of grunt.
The light wasn't flashing, i.e. staying on until I let off on the throttle a good bit to bring the speed back down.
Any ideas what the cause might be as I've not got a clue  |
| dublinclontar... |
| ficedula |
 ficedula Scooby Slapper
| gavbriggs |
 gavbriggs Crazy Courier
| dublinclontar... |
| Pigeon |
 Pigeon World Chat Champion
| dublinclontar... |
 Posted: 14:01 - 03 Jul 2013 Post subject: |
I removed all the panels, seat to have a look at all the wiring.
Poked around a little but didn't find anything that looked like a loose wire, after putting it all back on I started it up, and wouldn't you know the check engine light didn't come on.
On my way into work this morning as well, blasting up the A13 at top speed (a blistering 80 on the clock which is...probably about 65 in real life), the light remained off.
Either I accidentally disconnected the check engine light or knocked a loose wire back in place but either way it's "fixed"  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:50 - 03 Jul 2013 Post subject: |
If it comes on again, put a bit of electrical tape over it. Protip.
Well, you're not actually going to check the engine, and the oil is OK, so why not? ____________________ Biking is 1/20th as dangerous as horse riding.
| Dave M |
 Dave M Scooby Slapper
 Posted: 15:36 - 03 Jul 2013 Post subject: |
If it was me I would take it to a dealer yes a dealer to do a diagnostics check on it just in case there IS something niggling away that could end up being a more expensive job? I think it cost less than £30 to have this check done but make sure your with the mechanic when he's doing it in case he tries to pull a fast one on you!!! Use a semi synthetic oil of 10W40. |
| YBR Ric |
 YBR Ric Spanner Monkey
| dublinclontar... |
| ADSrox0r |
 ADSrox0r World Chat Champion
| ficedula |
| dublinclontar... |
 Posted: 00:07 - 05 Jul 2013 Post subject: |
| ficedula wrote: | It wasn't too difficult to get my YBR125 to indicate 75, given a (very) long enough run up and a flat road.
I'm fairly sure it wasn't doing much over 65 in reality, but the speedo certainly went up to 75. |
I've had the speedo up to 83 (about 10.5K RPM, inside the redline) for about a minute.
This was me glued to the tank, downhill, tailwind on the A13
It certainly felt like it was doing over 70 (unless my car is also well off on the speedo). I've not done any tinkering, just kept it well serviced, adjusted and lubed chain.
10w40 Castrol fully synthetic oil that I've changed far too often. Shell's VPower Nitro+ (they should add "super mega optimal hyper ultra" to the name, I don't think it's long enough) fuel at 99 octane.
Everyones going to say I'm wasting my money, I probably am but it's only £8 for a full tank of the really good stuff, same for the oil.
As I'd mentioned before this is my first motor transport and I'm kind of in love with the thing, your first may be a dog but she'll always be your first. |
| cb1rocket |
 cb1rocket World Chat Champion
The last post was made 13 years, 118 days ago. Instead of replying here, would creating a new thread be more useful? |
