Derbi Senda 50cc tuning / hesitation
orac69
PostPosted: 15:22 - 04 Jul 2013    Post subject: Derbi Senda 50cc tuning / hesitation Reply with quote
Hi guys, I wonder if I could get some advice please.
I have basic tuning experience, but I am by no means an expert...
My son has an '09 Derbi Senda X-Race 50cc.
Its de-restricted - the standard 17.5mm Dellorato carb now has a 105main jet, GA210 atomiser tube, A22 needle on middle notch.
It also has an after-market pipe, carb plate removed, and a 13T front sprocket.
It runs reasonably well, but I have a couple of minor problems.
1. There is a noticeable stutter / hesitation between 4.5 and 6k RPM - when it gets to 6000, it takes off nicely.
2. On wide open throttle it gets to about 10k, then again stutters a bit..
The plug looks healthy.
Im wondering what to do next to try and get rid of this hesitation ;
1. For the stuttering between 4.5-6k revs, should I move the notch on the needle? Up or down? Could it be something else?
2. Could the main jet be too big? The stuttering feels like its too rich perhaps..?
Thanks in advance.
nathan k
PostPosted: 22:09 - 04 Jul 2013    Post subject: Reply with quote
What plug have you got?
Also if ypu haven't already, best value upgrade is the exhaust.
orac69
PostPosted: 09:10 - 05 Jul 2013    Post subject: Reply with quote
The plug is I think a standard B8ES - although I have one of the newer BR8EIX Iridium ones on order just to be sure.
It already has a aftermarket exhaust.
Its just the hesitation between 4 and 6k which is annoying.
PostPosted: 09:20 - 05 Jul 2013    Post subject: Reply with quote
Don't use the iridium in a 2 stroke.
Have you tried moving the needle up 1 notch?
cb1rocket
PostPosted: 09:40 - 05 Jul 2013    Post subject: Reply with quote
Plug will not make much different, but the fueling is wrong at the mid range point, so as paddy says take the carb needle up a notch and try again.
If you have money to spare get it dyno'ed with a gas analyser
orac69
PostPosted: 10:37 - 05 Jul 2013    Post subject: Reply with quote
Thanks guys, will move the needle up a notch as suggested this evening.
Not to use an Iridium in a 2 stroke? Why not?
thx
SQL
PostPosted: 10:53 - 05 Jul 2013    Post subject: Reply with quote
The thinner electrode is also more prone to failure, and dropping off into your engine, not only causing a slight misfire, but normally a ruined cylinder
"Google"
nathan k
PostPosted: 11:47 - 05 Jul 2013    Post subject: Reply with quote
Wrong plug mate, use a BR9ES if it's derestricted.
In fact someone on another forum had this exact problem a week or so ago and fixed it by putting in a BR9ES plug.
orac69
PostPosted: 13:01 - 08 Jul 2013    Post subject: Reply with quote
Thanks all / nathan k, changing the plug to the BR9ES fixed it..
The last post was made 13 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 57.69 Kb
