Wiring multiple + to battery.
PostPosted: 20:41 - 05 Jul 2013    Post subject: Wiring multiple + to battery. Reply with quote
Shouldn't be done, I know, should be relayed.. I know Laughing
But, I'm currently powering my alarm, a 12V cigarette charger thing and a voltage display so I can monitor the voltage of my battery on the go.
I know I shouldn't wire them direct incase I leave them on etc but is there any real danger, aside from my shit layout of wires that will be sorted tomorrow.
https://i.imgur.com/fkp0gsZ.jpg
and the cool voltage thingy...
https://i.imgur.com/UsDDV8w.jpg
Can this be done a far neater way, i.e single connection to battery for all 3 rather than me bodging it like that. Would prefer a solid single one on there.
charlie74
PostPosted: 22:29 - 05 Jul 2013    Post subject: Reply with quote
personally if it was me i would put one larger cable, then split that off into the 3 you need, each with its own inline fuse holder.
but that comes from a few years of taxi wiring, and that stuff was running almost 24/7 for years
PostPosted: 22:31 - 05 Jul 2013    Post subject: Reply with quote
A fuse might help
PostPosted: 22:43 - 05 Jul 2013    Post subject: Reply with quote
Each has their own in line fuse Thumbs Up
PostPosted: 22:45 - 05 Jul 2013    Post subject: Reply with quote
Fuses should be as close to the +ve as possible. As the section between the +ve and the fuse is unfused and a short there won't blow the fuse.
PostPosted: 22:46 - 05 Jul 2013    Post subject: Reply with quote
Ah, I see, can switch some around tomorrow Thumbs Up
Aff
PostPosted: 22:53 - 05 Jul 2013    Post subject: Reply with quote
I wired my Voltage reader thingy into the back of the clocks, seemed to give a more accurate voltage than running wires from the battery. Also has the benefit of being switched and less wiring.
:edit: You changed your name! I'm so confused!
Electric Bike Project
PostPosted: 23:33 - 05 Jul 2013    Post subject: Reply with quote
It is wired to battery so I can detect when its being fed more than it should as I'm expecting reg/rec failure
Aff
PostPosted: 23:36 - 05 Jul 2013    Post subject: Reply with quote
The same reason I have mine.
delsol
PostPosted: 07:45 - 06 Jul 2013    Post subject: Reply with quote
Where did you get the voltage display thingy Paddy, and how much, cheers.
PostPosted: 07:47 - 06 Jul 2013    Post subject: Reply with quote
ebay, few pennies really.
https://www.ebay.co.uk/itm/360652960291?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Probably find it cheaper from noodle land, but I needed it fast and UK stock is always faster Laughing
Aff
PostPosted: 08:11 - 06 Jul 2013    Post subject: Reply with quote
I used this one.
Exactly the same as Paddys but direct form china, took about 10 days to get here.
PostPosted: 08:20 - 06 Jul 2013    Post subject: Reply with quote
There's no problem with stacking clamp rings on a battery terminal - lots of bikes had a smaller ring on the negative for the loom. You just make sure the starter earth and feed are at the bottom of the pile so you don't pass heavy current through a lightweight ring.
Shinigami
PostPosted: 10:31 - 06 Jul 2013    Post subject: Reply with quote
mines wired to an inline switch then housed in a polymorph plastic casing and glued to the top of my dash, wired direct to the battery, seems to work very well
Islander
PostPosted: 11:27 - 06 Jul 2013    Post subject: Reply with quote
This x100. It's important to remember that fuses don't protect devices, they protect the cables that feed the devices. Thumbs Up
delsol
PostPosted: 14:54 - 06 Jul 2013    Post subject: Reply with quote
Thanks Paddy & Aff, fook moi, cannot go wrong at that price, ordered from china- no rush. Cheers lads.
The last post was made 13 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 88.73 Kb
