Engine problems - VERY LOUD Rattling/Knocking!!
Richardandsam
PostPosted: 10:14 - 06 Jul 2013    Post subject: Engine problems - VERY LOUD Rattling/Knocking!! Reply with quote
Ive had to have the engine out of the bike twice so far in the past month cause stupidly I ran it on Halfords own Part Syn 10w40 CAR Oil, and its developed a VERY LOUD rattle or knocking if you like.
Ive done all the Valve Clearances, BRAND NEW Clutch Plates/Friction Plates/Damper Plate/Basket/Pressure Plate/Springs, Changed to New Motul Oil, Champion Filter, Clutch Cable.
I originally thought that it might be the whole clutch or the gearbox that had given up or maybe even a simple fix like a bearing that needed to be replaced, but it seems not.
The only thing that I haven't changed is the Clutch Actuator Rod in the bottom of the Clutch Casing, Needle bearings for such or the rod that comes out of the Pressure plate as these all seem spot on with no free play.
Ive done the screwdriver trick all over the engine and determined that its definitley coming from the right side lower of the engine tho.
So I dropped the engine out and split the casings in two. What did I find?
Well, the Starter Gear Ring behind the Alternator Magnet is slightly warped but not enough to cause this racket! The gearbox cogs, bearings, dogs, shafts all seem fine, and like I said above, I changed the WHOLE Clutch assembly to rule that out.
While I was in there with the block upside down on the bench, I noticed that No:3 Lower Crank Bearing Shell had a very small chip out of it, but after talking to a Kawasaki main dealer they say its not enough to cause this racket! So im back to square one!!
Symptoms:
Listen too and watch the video below.
Rattles VERY LOUDLY all the time in idle with Clutch in or out.
Increases with revs when out of gear.
Rattles like this when on the bike but as soon as you hit 3000 to 3500 rpm under load in gear it goes!
So, took it back to main dealer this morning who now reckons that it could be a Big End Shell gone awry on No: 3 or 4 and that the sound is transmitting. Is that a possibility?
Before this lot started, the bike was rumbling and vibrating like a goodun with the car oil in it, in and out of gear and that's what lead me to believe that id destroyed the clutch after realizing my mistake with the bloody oil!
So now im sat here with the bike in the back garden, missing all this good weather, in pain cause of an earlier accident, and getting mad cause the bloody bike is turning to scrap before my eyes and winding me up by nearly pulling my hair out with the agro from it.
Here's the YouTube Video link:
https://www.youtube.com/watch?v=m2NamHeXgYg
Can you diagnose the problem or give some pointers or ideas please??
52,000 with new clock mileage.
Never run it without oil!
Im totally stumped! So you reckon its loose bearings on con rods or crank bearings?
Been told these can be done with lump still in bike by dropping sump, etc?
KWAKA mechanic told me to me to drop sump and have a feel at the bottom of the con rods by the crank for any looseness there. Reckons its easier than dropping the engine again.
I actually don't mind dropping IF i HAVE to, but what does scare me is if i take the head off is retiming the thing!
Any further help before i bite the bullet tomorrow?
Richardandsam
PostPosted: 10:19 - 06 Jul 2013    Post subject: Reply with quote
BLUEX5 wrote:
Is this so important you need to post in both General and workshop forums?
Engine's fucked, get another one.
Sorry mate, didnt mean to upset you, Im new here and didnt know where the best place was to post it?!
Why, as you say, is it 'Fucked' then?
Is there no repairing it then?
c_dug
PostPosted: 10:57 - 06 Jul 2013    Post subject: Reply with quote
Can't offer much on the knocking itself but I very much doubt the oil caused the issue, I've used car oil at some point on every one of my bikes and never had an issue.
PostPosted: 11:07 - 06 Jul 2013    Post subject: Reply with quote
Yeah I'd probably drop the sump because then you should see if there is any swarf in there.
It does sound like big end bearings TBH...
nowhere.elysium
The Pork Lord
PostPosted: 11:08 - 06 Jul 2013    Post subject: Reply with quote
Not economically, no.
Richardandsam
PostPosted: 11:19 - 06 Jul 2013    Post subject: Reply with quote
This is a duel post....Sorry!
Have a look at the main thread in the WORKSHOP forum.
mysterious_rider
PostPosted: 12:51 - 06 Jul 2013    Post subject: Reply with quote
Has it been stored for quite a few years without use then?
KAWASAKIIIII
Richardandsam
PostPosted: 12:53 - 06 Jul 2013    Post subject: Reply with quote
No No, Ive used it every week, come rain or shine as its my only method of transport.
Only had 3 owenrs inc me and its always been used but never abused before me either.
Check my main thread on this in the workshop section on here.
Wonko The Sane
PostPosted: 14:00 - 06 Jul 2013    Post subject: Reply with quote
I've got a spare ZZR600 E engine for sale in Manchester
It's supposedly been completely re-built and dry stored (so needs oil putting in)
I've never run it.
Richardandsam
PostPosted: 14:02 - 06 Jul 2013    Post subject: Reply with quote
I've never run it.
How much??
Look at my thread in the workshop section on here mate and send me a Private Message with contact details please mate?
sickpup
Old Timer
PostPosted: 01:27 - 07 Jul 2013    Post subject: Reply with quote
Big end or main has gone.
When you changed the oil did you change the filter as well? When you started the bike afterwards how long did it take for the oil light to go out?
The last post was made 13 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 82.07 Kb
