ybr 125 horn switch
the1andonly
PostPosted: 14:26 - 08 Jul 2013    Post subject: ybr 125 horn switch Reply with quote
horn problems again
the horn does what it should when feed 12v
the voltage to pink brown wires was only 3.6V
open switch squirt with WD40 now approx 5V
battery charged still approx 5V
all other electrics inc indicators (on same return black wire) work hunky dory.
How do I dismantle the switches to clean up connections properly
as a minimum i want to remove the individual switches from the housing leaving the indicator switch in one piece
thanks
Islander
PostPosted: 15:08 - 08 Jul 2013    Post subject: Reply with quote
Try some switch cleaner (Servisol or similar) sprayed into the switch then work the button repeatedly.
the1andonly
PostPosted: 18:09 - 08 Jul 2013    Post subject: Reply with quote
Just had a good squirt and press as suggested using 2 different cleaners (lying about in shed) an HFE flux cleaner then carb cleaner (probably methanol based).
Results:
repeated switch on gives 10-12.5V initially.
this results in horn working intermitantly
time for a brew.
Thanks Islander
long time since i've seen Ogri
The last post was made 13 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 34.25 Kb
