Chain tension
GZXR400
PostPosted: 09:41 - 10 Jul 2013    Post subject: Chain tension Reply with quote
Hi i have a Kawasaki ZXR 400L i am was wondering if 10-15mm of chain slack sounds too tight ?
The manual says 5-10mm is correct, too tight is less than 5mm and too loose is more than 15mm.
This sounds far too tight however i have noticed the way i have it now the chain can hit the swingarm when pushed fully upwards.
Im not asking how to adjust it just about the 5-10mm chain slack ?
Thanks
speedyspeedyb...
PostPosted: 15:09 - 10 Jul 2013    Post subject: Reply with quote
Remember to sit on it when testing the tension. Your weight adds a bit more tension, obviously this will vary depending on your weight and bike. Sit on it and bounce around.
Country lane warrior
Lexmoto lsm125
Quote Me Happy
PostPosted: 15:33 - 10 Jul 2013    Post subject: Reply with quote
Don't necessarily do this. Set it how the manual says - if it says set it with the bike on the side stand then set it on the side stand.
5mm-15mm does seem tight though.
Ilyin
PostPosted: 16:08 - 10 Jul 2013    Post subject: Reply with quote
Yeah I thought 25mm-35mm is a general "rule of thumb".
I always go for the 35mm end tbh.
-Matt-
PostPosted: 02:12 - 11 Jul 2013    Post subject: Reply with quote
Could a shorter/longer swingarm/chain make it a different spec that most maybe? Just follow the manual it should be fine
neatbik
PostPosted: 08:30 - 11 Jul 2013    Post subject: Reply with quote
Yeah, 5-15mm does seem very tight.
I always aim for about 3-35mm.
Dont forget to check for any tight spots.
BikerMatt
PostPosted: 10:11 - 11 Jul 2013    Post subject: Reply with quote
beatnck2 wrote:
I always aim for about 3-35mm.Thumbs Up
3mm's? Wonder what kind of chain are you using Mr. Green
So many bikes..
neatbik
PostPosted: 10:30 - 11 Jul 2013    Post subject: Reply with quote
Note to self - Engage brain!
30-35mm should do it.
Timmeh
PostPosted: 10:39 - 11 Jul 2013    Post subject: Reply with quote
Just be aware that the Japs sometimes measure things from different points. 5-10mm might be correct somewhere.
Like others have said if do what most do which is measure the chain at the tightest point in the centre of the swingarm then 25-35mm is a far better option.
treeno
PostPosted: 13:45 - 11 Jul 2013    Post subject: Reply with quote
I think it depends on the bike and it is best to stick to the manual. On mine, anything more than 20mm and the chain will start scraping on the chain guard!
The last post was made 13 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 63.04 Kb
