Motorbike Battery
numark1
Scared of girls
PostPosted: 21:13 - 06 Dec 2004    Post subject: Motorbike Battery Reply with quote
I just bought this battery from eBay
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=7938128080&ssPageName=STRK:MEWN:IT
i had to put the stuff in myself. The question is do i now charge the battery?? It did not say anything about what to do once i have put the stuff in the battery.
Rob W
PostPosted: 21:22 - 06 Dec 2004    Post subject: Reply with quote
The stuff? You mean acid?
I would of thought it wont need charging, pure guess though, I'm useless with tech questions
Gazdaman
I did a trackday!!!
PostPosted: 21:35 - 06 Dec 2004    Post subject: Reply with quote
stick a voltmeter across it, my guess is that you won't read anything, I believe it needs charging.
I'd wait until Kickstart or someone similar gives you a definite answer before you go blowing up stuff based on my assumptions.
Gaz
pipnet11
PostPosted: 21:38 - 06 Dec 2004    Post subject: Reply with quote
How did you know what strength acid to put in??? hope you got it right or you could end up with a battery that puts out no-where near 12V.
Anyway, it should be charged if its never had acid in it. Even so to check put a 0.2A current regulated 13.5V supply accross it, it will charge till the voltages equalise then slow to a trickle, this is how I check/charge all my batteries and it is impossible to overcharge them this way.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
numark1
Scared of girls
PostPosted: 21:40 - 06 Dec 2004    Post subject: Reply with quote
i put the whole lot in. why?? it didnt say anything different.
pipnet11
PostPosted: 21:44 - 06 Dec 2004    Post subject: Reply with quote
The amount isnt the problem, its the strength. If you got it with the battery then your OK. Its just when you get it from somewhere else that it can be a problem, mine came from newcastle universitys chemistry lab Very Happy its nearly right, about 12.5V loaded, 13.7 unloaded.
Anyway, if it came with the battery it will be fine.
Barker-CBR 600
PostPosted: 22:08 - 06 Dec 2004    Post subject: Reply with quote
If you can find yourself someone who's got an optimate or something similar, a full battery restoration/maintenance kit in one little grey box.
Basically you can connect it up it can tell you three things -
Charged
Needs charging
De-salinized (i think thats the right term)
which basically means its totally f**ked, or at least it needs something changing/being sorted.
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
mattsmith95
PostPosted: 22:37 - 06 Dec 2004    Post subject: Reply with quote
Put the acid in, leave it for twenty minutes, connect to bike, thumb
start, go go go. Take the bike out for a ride
Don't know the science but after twenty minutes the battery is ready
to start the bike, after that running the bike will charge it normally.
jamie192
PostPosted: 22:52 - 06 Dec 2004    Post subject: Reply with quote
Get a car battery charger and stick it on over night, did me fine Smile
Ride Fast, Brake hard, don't fall off!
numark1
Scared of girls
PostPosted: 23:22 - 06 Dec 2004    Post subject: Reply with quote
i charged it until the light came on on the battery charger to say it was full. I put it in the bike and tested it. Was ok, i will use it properly tomorrow on the way to college. Does anybody know any way to stop the battery getting damaged in the damp?? (if it does get damaged) Thumbs Up
mchaggis
PostPosted: 23:25 - 06 Dec 2004    Post subject: Reply with quote
Vaseline, WD40 or some such oily water resistant/ displacing substance spread/ sprayed on the terminals should keep them from getting corroded. Vaseline has the seal of approval from my mum at least when she used it on batteries whilst living on the west coast of Scotland.
The rest of the battery shouldn't be affected by the damp, it's just a big plastic box. A wipe down every year or two wouldn't do any harm, but is probably not needed.
I must not be a troll...
Mmmm, Guinness
The last post was made 21 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 69.76 Kb
