Open brake fluid container
The Disapproving Brit
PostPosted: 19:58 - 10 Jul 2013    Post subject: Open brake fluid container Reply with quote
I changed my brake fluid at the weekend, and now I have most of a bottle of DOT4 left. From what I gather, brake fluid is hydroscopic, and shouldn't be stored once opened. Is that the kind of advice that should actually be followed, or is it bollocks?
If it's now unusable as brake fluid, does it have any other use other than the obvious paintwork based revenge?
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Hetzer
PostPosted: 20:03 - 10 Jul 2013    Post subject: Reply with quote
It's bollocks. I've used stuff in half-empty cans/bottles I've had for years and it's worked fine. Make sure the lid's done up nice and tight and keep it somewhere cool.
Raffles
PostPosted: 20:44 - 10 Jul 2013    Post subject: Reply with quote
If it makes you feel better then you could always decant it into a smaller container.
Personally, I'm with Hetzer and struggle to accept that brake fluid significantly deteriorates due to exposure to air*
*Awaits incoming flak from more knowledgeble people that will disagree with me and point out that the fluid can boil and cause brake failure when contaminated with water and everyone's likely to die as a result.
totalllama82
PostPosted: 21:08 - 10 Jul 2013    Post subject: Reply with quote
Have to admit, i've used old stuff on cars before and found no real difference.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
PostPosted: 00:06 - 11 Jul 2013    Post subject: Reply with quote
It does absorb fluid pretty rapidly. But I would still reuse some from a bottle which had been securely resealed fairly recently. But I would be dubious about a bottle that had been opened and closed a few times over 6 months.
Found this that might interest you:-
https://www.iwsti.com/forums/gd-braking/44252-brake-fluid-101-a.html
bikenut
PostPosted: 15:10 - 11 Jul 2013    Post subject: Reply with quote
yes it is hygroscoptic......and absorbs water........which lowers boiling point and causes corrosion...........you change the fluid once a year or every other like on a merc??
neatbik
PostPosted: 16:18 - 11 Jul 2013    Post subject: Reply with quote
I completely agree.
PostPosted: 16:51 - 11 Jul 2013    Post subject: Reply with quote
Cheers guys. For it's next full change it'll be a new jar again, but I only had time to bleed the front on my day off. I still want to bleed the rear and clutch, but won't get chance for a couple of weeks, so wanted to be sure it's still going to be fine to use the same fluid.
On a related note - I know brake fluid eats paint. Does it render the surface unpaintable in future?
Hetzer
PostPosted: 17:10 - 11 Jul 2013    Post subject: Reply with quote
Maybe if it was plastic and the stuff soaked into it. On anything metal or suchlike, no.
The last post was made 13 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 61.45 Kb
