Ok so it obviously comes in 5's not 3's
Scootaloo
PostPosted: 14:05 - 11 Jul 2013    Post subject: Reply with quote
Burn it all I say.. ALL OF IT.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Timmeh
oh dude...
What do you need a bearing puller for? Find someone with a stick welder and run a ring around the inside of the bearing, when it cools down it'll fall out.
Shinigami
PostPosted: 14:06 - 11 Jul 2013    Post subject: Reply with quote
name and shame the garage, pretty poor form to take the job without the tools and even worse to start the job without the tools and expect you to be fine with it
orac
PostPosted: 14:56 - 11 Jul 2013    Post subject: Reply with quote
how bad was the bearing to knock the centre out.
i have done front, rear and sprocket carrier beaings in my back yard with a drift and hammer, its a 30 min job at most.
stonesie
PostPosted: 15:13 - 11 Jul 2013    Post subject: Reply with quote
This, it's pretty easy and if it's really stuck in there then heat the wheel hub around the bearing and try again...
Also, pop the new bearing's in the freezer for an hour or three, makes fitting them easier but only tap* them around the outer edge, using the old bearing as a drift can work nicely.
* Note that's TAP, not TWAT, if you give them a good twating they will go in quick but not last long.
Chalky.
PostPosted: 15:53 - 11 Jul 2013    Post subject: Reply with quote
So some bloke managed to squeeze you in on the same day, no doubt he didn't realise his mate had the tool at the time, and you're whining like the little bitch you are?
You're such a cunt, try to stop being a cunt and you'll be treated less cuntishly.
PostPosted: 18:10 - 11 Jul 2013    Post subject: Reply with quote
Didn't really read this, but I rate it at 5 Young's Fish Fingers on spirit alone.
J4mes
PostPosted: 18:17 - 11 Jul 2013    Post subject: Reply with quote
If it's such a piece of piss job with the right tools then why not nip to halfords, machine mart, *enter anywhere that sells automotive tools here* and do it yourself?
Neutral
PostPosted: 18:32 - 11 Jul 2013    Post subject: Reply with quote
DivvyDumbarse wrote:
hutchings motorcycles
Hey, the top Google hit for that is some chap bawwwing about how he didn't get his bearing removed. You should probably have read that before going there.
Marmalade
PostPosted: 18:34 - 11 Jul 2013    Post subject: Reply with quote
One front wheel bearing on the pan self destructed, took wheel out and dust cover off and most of it fell out, had to cut the outer ring in half with a dremel type thing to get it out as there was no angle to get a drift (screwdriver) on it to batter it out.
Surprised you didn't do it yourself, never used a puller on bearings.
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 80.96 Kb
