 Posted: 12:18 - 11 Jul 2013 Post subject: Fitting aftermarket fairings |
Just got a set of fibreglass fairings for the VFR750 delivered from Poly 26 in France.
Seem well finished and pretty heavy duty.
There aren't any holes for fixings in them, just the plain fibreglass with cutouts for the headlight and flashers.
Any top-tips from people who have fitted them before?
I'm going to try to make as much use of quarter turn fasteners as possible for holding them to the bike itself but how do people normally deal with the parts where, for example, a bit of trim is attached to the fairing using a well-nut or a self-tapper.
The flashers would be a good example. They normally screw into a sort of post moulded into the plastic with a self-tapping screw through a lug on the flasher. This one is just blank. Considering stuff like bonding a setscrew to the inside of the fairing and slotting the flasher over it. The headlight normally attaches to a captive nut in a plastic slot.
Might not look too bad if I even through-drilled it and used countersunk stainless fittings with a nut on the back? (so the head of the fitting would show through on the outside of the fairing).
I'll post pictures later. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| -Matt- |
 -Matt- World Chat Champion
 Posted: 18:27 - 11 Jul 2013 Post subject: |
If all else fails - cable ties  |
| -Matt- |
 Posted: 18:47 - 11 Jul 2013 Post subject: |
I attempted that before on a tail-light [it was actually the tail light that was aftermarket] but the same principle i think would apply - because it was SLIGTLY out of line, and more importantly not attached TO the fairing all vibrations between the 2 items led to slight rubbing and a constant white dust along the meeting lines where it was very very gradually sanding away at itself. Subsequently the light also got faulty - maybe coincidence but im inclined to think it was slowly vibrated to death basically
I'd go with some fixing paste that will 'glue' the lights to the inside of the fairing, but could be cracked/melted away should you need to remove it entirely for some obscure reason.
I used to have a tube of some stuff in the garage but i can't find it and fail to remember the name now  |
| G |
 G The Voice of Reason
| Robby |
 Robby Dirty Old Man
| Timmeh |
 Timmeh World Chat Champion
| -Matt- |
| G |
The last post was made 13 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
