Author |
jimmyd |
 jimmyd Renault 5 Driver
 Posted: 08:38 - 12 Jul 2013 Post subject: Changing fork seals - how to lift front end? |
Any tips on how to get the front of the bike up safely so I can do the fork seals?
I have a front paddock stand but it fits to the bottom of the forks, which isn't going to help if I'm taking them out..!
I don't have a garage/winch/anything, driveway only  |
Back to top |
supZ |
 supZ World Chat Champion
Back to top |
Ichy |
 Ichy World Chat Champion
Back to top |
supZ |
Back to top |
Islander |
 Islander World Chat Champion
 Posted: 09:05 - 12 Jul 2013 Post subject: |
As above, axle stands or concrete blocks under the footpegs makes a good stable stand as a temporary solution. Check to see if the pegs are hinged first though! Someone on here suggested reversing the pegs to lock them if this was the case.
Long term solution? Treat yourself to an ABBA stand - no more paddock stand gymnastics, simple single person operation and it's very very stable. It's good for both front and rear - you can just chock the bike up under the header pipes with blocks of wood or similar if you need the front off the ground.  |
Back to top |
barrkel |
 barrkel World Chat Champion
 Posted: 09:08 - 12 Jul 2013 Post subject: |
Another option is an Abba stand or equivalent, which acts like a centre stand when you don't have one.
Once it's hoisted on that, you can tie down the rear to lift the front.
There is an Abba stand attachment which lifts the front up, but it's not really necessary if you have a luggage strap or similar and a couple of solid points to attach it. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
Back to top |
mudcow007 |
 mudcow007 World Chat Champion
Back to top |
Islander |
Back to top |
stickybackbob |
 stickybackbob Trackday Trickster
Back to top |
moppy |
 moppy World Chat Champion
Back to top |
andym |
 andym World Chat Champion
 Posted: 17:58 - 12 Jul 2013 Post subject: |
Back to top |
jimmyd |
 Posted: 19:22 - 12 Jul 2013 Post subject: |
Thanks all good ideas. Thinking about your suggestions and the things I have, I think i can use the front paddock stand to lift the bike straight (yep, no centre stand), then put bricks under where the engine is, lower it back down and go from there.
Now to read as many guides as I can on replacing the seals themselves....! |
Back to top |
moppy |
Back to top |
jimmyd |
Back to top |
stickybackbob |
 Posted: 21:47 - 12 Jul 2013 Post subject: |
It's an easy enough job. Just remember to loosen (not remove) the top caps whilst the forks are still in the yokes. You may need to undo the top pinch bolts to allow this.
Next, use a good fitting tool on the damper bolt at the bottom of the forks. You may need to give it a sharp tap but don't round it off.
Getting the seals out shouldn't be difficult but try not to chew them up as you can use them again to knock the new seals into place.
Depending on the type of forks you have, the stanchion may need to be in the fork leg before fitting the new seal. If this is the case, use a bit of a plastic bag over the top of the stanchion so that there are no sharp edges to rip the new seal as you slide it over.
Do the job yourself and you'll be satisfied, have some beer money and you'll know your bike that little bit better  |
Back to top |
Ichy |
Back to top |
Yoyo |
 Yoyo Brolly Dolly
Back to top |
stickybackbob |
Back to top |
andym |
 Posted: 11:05 - 13 Jul 2013 Post subject: |
I've said it before and I'll say it again, if you know the forks are ok internally there is no need to remove the stanchion.
Remove the forks, remove the spring, tip the whole front wheel and forks upside down to remove the old oil, punch the old seal with a screwdriver and lever it out, use the old seal to push the new one into place, use a measuring tape rather than jug to replace the oil and reassemble.
Rounded bolts = 0
Time to complete = 45 minutes (even if you haven't got a clue what you're doing)
So far I've used this method on all of my bikes (intruder, diversion, GPz, zxr), and I imagine if I was to try it on the VFR it would be just as easy |
Back to top |
janner_10 |
 janner_10 World Chat Champion
Back to top |
Skudd |
 Skudd Super Spammer
Back to top |
Raffles |
 Raffles World Chat Champion
Back to top |
janner_10 |
Back to top |
jimbob005 |
 jimbob005 Nova Slayer
 Posted: 07:51 - 14 Jul 2013 Post subject: |
Back to top |
The last post was made 12 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
