| freestyler_onli |
 freestyler_onli World Chat Champion
| scottc1088 |
 scottc1088 Renault 5 Driver
| JonB |
 JonB Afraid of Mileage
 Posted: 00:08 - 07 Dec 2004 Post subject: Re: New Bike- Getting Started |
| scottc1088 |
 Posted: 00:10 - 07 Dec 2004 Post subject: |
| Quote: | WD40 on your brake discs will increase your braking power by 25% |
mite try that, seems like a good idea  ____________________ 2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
Breaking 2000 senda r |
| freestyler_onli |
 Posted: 01:07 - 07 Dec 2004 Post subject: |
LOL.
Well i'll let him try it out then.  |
| Rollins |
 Rollins Trackday Trickster
 Posted: 01:25 - 10 Dec 2004 Post subject: Re: New Bike- Getting Started |
| freestyler_onli wrote: | Ok. I got a brand new Aprilia RS125. Apart from riding it in/filling it up as per dealers instructions, are there any hints/tips you guys have on how to ease it in for smooth riding???
Also 1 Q: Someone said that spraying WD-40 on the wheels gives you better grip in cold conditions. Not that i ever would-does anyone know if this is true??
Ta. |
Make sure you warm it up properly in the morning, especially now it's the winter - did they recommend 60 degrees before you pull away? (as time goes on, you don't need to get it so warm, my RS has done 4200km since brand new this year and I normally pull away on about 45-50 degrees, but I don't go over 6000rpm until it reaches 60).
That's the only major thing really. Oh, also keep it clean & lubed, and use Scottoiler FS365.
BTW, you don't really need to stick to the max. rpm quoted in the manual, otherwise you won't go anywhere. Just don't redline it for the first 1000 miles and you're fine. Use slightly more revs every time you ride. And remember to turn on the fuel tap!
Tank range isn't a lot, between 80-100 miles before the reserve cuts in (with half a tank of petrol still in it ). Use BP Ultimate or Optimax if you can afford it - they both give better response and generally make the engine feel 'healthier'. But you can still get 50mpg fairly easily.
On the contrary to the stereotype - it is a reliable bike (even in torrential rain), as long as you look after it, not run it into the ground like most 17 year old 'learners'. Mine has been used nearly every day since January, the only problem has been a leaky fork seal. ____________________ "... I wouldn't mind doing 130 up to a T junction, but unfortunately my bike tops out at 120 which is gay..."
2005 CBR600RR |
| Flip |
 Flip Super Spammer
| stryker |
 stryker Brolly Dolly
| freestyler_onli |
 Posted: 18:46 - 10 Dec 2004 Post subject: |
It's funny you lot should mention this. I turned it on cold, kept it running for 5 mins say as i put my gloves and helmet on. Then i was riding off maybe 3 miles later when all power cut out. Everything powered down. I tried to restart and 'COLD' flashed up on the screen. Fair enough- then it said it was optimum temprature so off i went only for it to cut out again. So i guessed that petrol was to blame so i filled her up. No probs for the next 10 miles or so. Just gotta make sure i warm it up a bit first i guess.  |
| Barker-CBR 600 |
 Barker-CBR 600 Could Be A Chat Bot
 Posted: 19:14 - 10 Dec 2004 Post subject: |
On the general riding note.
There are a lot of advanced courses etc that are great, and even a few video's etc that really teach you things that would otherwise come with years of experience.
But theres the money factor, and if (like me) you cant afford the most expensive courses, and find that the video's etc are a lot for what they are then my one tip to you is find the Bike/Ride mags sections that they ran a month of two ago.
Was along the lines of 'perfect riding' or something similar, basically some real good tips on counter steering, road positioning, the sacred vanishing point ( )
Another idea is simply ride with, or more like behind, someone who's done these courses or benefit from years of experience. After only 3-4 rides following my dad on his VFR (20+ years biking and done several courses etc) i found i had tightened my line, smoothed out nasty habits that were beginning to emerge after only about 2 weeks on the CBR!
Thats my 2 cents, only one way you'll ever get it all right though... thats to get out that chair and on the bike!  ____________________ Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?' |
| freestyler_onli |
 Posted: 23:05 - 10 Dec 2004 Post subject: |
Yeah thanks for that-sounds like good advice/tips there- ill look it up.
On another note- i just couldn't get the bike started tonight. I don't think the battery's flat as i only had it a few days. Besides-i wouldn't know if it was flat- i mean the lights/instrument panels light up fine. It kept saying 'COLD' which i couldn't do anything about so i had to call of 2 important trips.
Bloody bike!  |
| Barker-CBR 600 |
| freestyler_onli |
The last post was made 21 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
