| moppy |
 moppy World Chat Champion
| Hetzer |
 Hetzer Super Spammer
| stickybackbob |
 stickybackbob Trackday Trickster
| Vincent |
 Vincent Banned
| moppy |
| Bezzer |
 Bezzer World Chat Champion
| Hetzer |
 Posted: 15:02 - 12 Jul 2013 Post subject: |
| moppy wrote: | Hmm...Very strange.
I couldn't identify a leak yesterday, so I just drained, flushed a few times and filled up the rad (this time with 50/50 coolant and deionised water). Also filled up the coolant reservoir up to the Full mark.
Went out to go stick the fairings back on today and hey presto, the reservoir is empty. Absolutely bone dry. The bike hasn't been run since I filled it up and I can't find any puddles on the floor (although ofcourse, they could have evaporated).
Curiouser and curiouser.
The temperature gauge moves up and down according to bike temp, so I'm assuming thermostat isn't seized?
I'm so shit at buying bikes, bought this in April, and I've already had to refurb the calipers, forks are gonna need rechroming and now this. 12 month MOT means absolutely nada. |
One assumes you filled it with a specific quantity according to the manual (X amount in the rad, Y amount in the reservoir)? ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| stickybackbob |
 Posted: 15:38 - 12 Jul 2013 Post subject: |
What's the engine oil like? If it's milky brown, you've blown the head gasket or the waterpump is leaking - black, check that the spark plugs are the proper colour and not too clean. If one or two of them are cleaner than the rest, then it suggests head gasket again. If normal, you should be able to breathe a sigh of relief
If the bike hasn't been run since you put the new coolant in it, then check for leaks around the expansion bottle too. If it turns out that the coolant syphoned into the radiator, that would suggest that your radiator cap isn't sealing properly (reasonable if you think of the amount of sludge)
I'd still be checking where the hoses connect up to the engine and thermostat housing as the metal can rot leading to a fine mist of rusty water being sprayed about. |
| moppy |
 Posted: 16:17 - 12 Jul 2013 Post subject: |
Thank you all for the replies, let me try and elaborate.
| Quote: | Might simply be you had an airlock when you drained and refilled it if you didn't do it right |
I followed Haynes instructions, check no bubbles through bled nipple, run engine with rad cap off, hit the tubes to release bubbles etc. But this does seem the most likeliest of explanations for the lack of coolant. I've filled the reservoir up again and keeping a keen eye out for leaks, so will report back again tomorrow when I have to ride the thing to Nottingham.
As for the thermostat...fair point. I reeeeeealy don't wanna take it off yet, but if coolant keeps disappearing, I'm gonna have to dismantle the entire cooling system and have a look to see what's what.
It does have a fan, and it kicks in at the same temp (according to the analogue temp gauge).
| Quote: | One assumes you filled it with a specific quantity according to the manual (X amount in the rad, Y amount in the reservoir)?
| Manuals advice was to simply fill the rad up to the neck and the reservoir somewhere between Low and Full. And I did exactly that.
Engine oil...looks alright? I'm gonna do an oil change in the near future so will have a proper look at that soon. I took the spark plugs out, here have a look, like fuck do I know if it's the right colour or not.
https://s22.postimg.org/rdafkg0nh/2013_07_11_16_50_55.jpg
| Quote: | If the bike hasn't been run since you put the new coolant in it, then check for leaks around the expansion bottle too. If it turns out that the coolant syphoned into the radiator, that would suggest that your radiator cap isn't sealing properly (reasonable if you think of the amount of sludge)
No leaks around expansion bottle, so I'm guessing it's the radiator cap. It is mega rusty. Will give it a proper clean before tomorrow and see what happens.
I had a good look at the hoses, but they all seem to be water tight enough, but it occurs to me now after Ive put the fairing back on that I only really checked when the bike was warming up and wasn't still checking when the fan had kicked in and the bike was truly hot. Damn.
Will update tomorrow, thanks for the help and if people could give me their opinion on the spark plugs, would appreciate. Cheers |
| Hetzer |
| Vincent |
 Vincent Banned
| moppy |
| Vincent |
 Vincent Banned
 Posted: 17:31 - 12 Jul 2013 Post subject: |
Better start praying then  ____________________ Space Is Deep |
| stickybackbob |
 Posted: 17:32 - 12 Jul 2013 Post subject: |
Look good to me, but what do I know Sounding more like a cap problem now though and I think we've eliminated the most expensive failures. |
| Hetzer |
| Hetzer |
| garth |
 garth World Chat Champion
| Hetzer |
| Vincent |
 Vincent Banned
 Posted: 18:59 - 12 Jul 2013 Post subject: |
| misscrabstick |
 misscrabstick Crazy Courier
| Ariel Badger |
 Ariel Badger Super Spammer
| evoboy |
 evoboy World Chat Champion
 Posted: 00:56 - 13 Jul 2013 Post subject: |
My zx7r never used to get over half way on the gauge where the fan would kick in...
Pretty much the same bike as the J model. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| moppy |
 Posted: 15:31 - 13 Jul 2013 Post subject: |
Hmm, went to Nottingham and back today, the temp gauge never went above the mark I've circled in the picture below.
https://s21.postimg.org/jj7y61n6b/zx75_tclk_s.jpg
Still plenty of coolant in the reservoir tank as well...Safe to say all is well maybe?
Will have a close look at the oil when I change it, but hoping it's all good... |
| Hetzer |
| Bezzer |
The last post was made 12 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
