Honda cbr 250 and 125 engine swap?
Jay46
PostPosted: 17:43 - 12 Jul 2013    Post subject: Honda cbr 250 and 125 engine swap? Reply with quote
Does anyone know if it is possible put a Honda cbr 250r motor into a cbr 125r?
Thanks Thumbs Up
RhynoCZ
PostPosted: 17:48 - 12 Jul 2013    Post subject: Reply with quote
Question: why? Thinking
EDIT: I just think it's cheaper to get a CBR250 rather than swapping the engine and yes it is possible, people put various of single cylinder engines from endurous into 125cc frames for many years.
BikerMatt
PostPosted: 17:52 - 12 Jul 2013    Post subject: Reply with quote
Don't go off topic, just answer the guys question jheeze
So many bikes..
stevo as b4
PostPosted: 18:02 - 12 Jul 2013    Post subject: Reply with quote
I don't know, it would depend on engine dimensions, mounting points and clearance for various ancillaries etc. You would have to look at a CBR250 and CBR125 together and probably take measurments.
I would guess that dimensionally the CBR250 is very different to the CBR125, and that the two motors are completely different designs.
I would also think that if you were wanting to do an engine swap into a CBR125 that the best option and the most directly related motor would be the CBR150 engine, which I believe is around 20bhp and apart from the 4valve head there are close similarities in design to the CBR125 unit.
watafu
PostPosted: 18:56 - 15 Aug 2013    Post subject: Reply with quote
No you cannot fit a cbr250 engine into the 125 frame unless you are intending to replace every aspect of fueling, electrics, brakes and are particularly good at welding to make new engine brackets. All in all its cheaper to get a bigger bike like a honda hornet or something along those lines.
The biggest engine you can put in the stock frame that will drop in is the cbr150 engine, then buy a big bore kit up to 200cc+, replace your carb, stock ecu ect ect depending on whether its the newer 150 injected engine or the older carbed model like I have.
Now once you have all your parts, if your trying to drop the engine straight in, you are going to find a looooot of differences, the cooling system is slightly different, at the moment I am having to figure out how to make it all work properly (not sure if the carb needs coolant running through it??) and also you will have to buy some additional parts to make the exhaust fit.
All in all its going to cost you an arm and a leg and a lot of time.
pits
PostPosted: 19:52 - 15 Aug 2013    Post subject: Reply with quote
Rob Fzs wrote:
yes, fits straight in, no issues.
I fitted a MK1 Blade engine into a 125 frame, anything is possible.
Timmeh
PostPosted: 21:48 - 15 Aug 2013    Post subject: Reply with quote
I've seen a Gixxer Thou in an Bandit6.
dangerousdave
PostPosted: 22:48 - 15 Aug 2013    Post subject: Re: Honda cbr 250 and 125 engine swap? Reply with quote
Thanks Thumbs Up
that cbr250r motor is much wider than the cbr 125. suspect its a fair bit heavier too, on a featherlight bike like the cbr125 would ruin the handling surely.
Then the brakes wouldn't be up to the job to deal with the extra speed.... etc etc
also, try getting insurance for a 125 fitted with a 45bhp 250cc motor. if they'd insure it, it would be big bucks.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
prawny1
PostPosted: 23:43 - 15 Aug 2013    Post subject: Reply with quote
would be much easier to fit the cbr clone 150 or 200cc engines
hellkat wrote:
Carvel
PostPosted: 21:51 - 16 Aug 2013    Post subject: Reply with quote
Just buy a fireblade you fat fuck.
Kai.Wilson
PostPosted: 23:22 - 16 Aug 2013    Post subject: Reply with quote
Im guessing your only on a cbt
you may aswell buy a cbr250 and put a cbr 125 plate on it, would be much easier
SQL
PostPosted: 23:31 - 16 Aug 2013    Post subject: Reply with quote
Get a CBR600F and put CBR125 panels and plate on it
Teflon-Mike
tl;dr
PostPosted: 23:41 - 16 Aug 2013    Post subject: Reply with quote
CBR250 'single' makes 26bhp.
CBR250R 'four' makes 40ish.
The 250 single motor would be a lot of hassle and effort for not a lot of gain.
The 250 'four; would be a fucking nightmare, and a waste of a classic.
CBR125 is a useful four-stroke, 'sports style' learner-commuter. Its not meant to be fast.
CBR250 single is a moderately useful, 'sports-style' four stroke A2 complient commuter. Its not really very fast either.
If you have a licence to ride a 125 modded beyond Learner/A1 licence restrictions... just get a bigger bike.
If you don't have a licence to ride anything beyond Learner/A1 licence restrictions... fuckit.. just get a bigger bike... might as well be hung for a sheep as a lamb, and you'd probably actually be breaking fewer laws.
The last post was made 13 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 92.62 Kb
